2024+ 4th Gen Tacoma - Adding & Saving Trailer Profiles
The 2024+ Tacoma lets you save up to 10 different trailer configurations through the Multi-Information Display. Each profile stores trailer-specific settings like length, brake type, and hitch configuration. The Integrated Trailer Brake Controller, Trailer Backup Guide, and Blind Spot Monitor automatically adjust for whichever trailer you're towing. Set it once, and the truck remembers everything.
(Reference: Owner's Manual, pg. 103, 112, 311)
Trailer Profile Settings, Save Trailer Configuration, Trailer Memory System​
Location: Multi-Information Display (instrument cluster)
The Trailer Settings screen displays:
  • Currently selected trailer name, OR
  • "No Trailer Selected" if no profile is active
This screen provides access to all trailer profile functions through the instrument cluster controls.
Creating a New Trailer Profile​
Maximum Capacity & Parameters​
The system can store up to 10 trailers in memory. Each profile stores trailer-specific parameters that remain saved even when the trailer is disconnected.
Configurable Parameters:
  1. Trailer Name - Custom label for easy identification (e.g., "Boat Trailer", "Cargo Utility", "RV")
  2. Trailer Length
    • Manual entry: Enter exact length
    • "Auto" mode: System uses Trailer Length Detection (TLD) to estimate length using Blind Spot Monitor sensors
    • TLD requirement: Make at least two 90-degree turns after connecting trailer for accurate length detection
  3. Hitch Type - Specifies your hitch receiver configuration
  4. Brake Type - Indicates trailer braking system:
    • Electric brakes
    • Electric-over-hydraulic brakes
    • No brakes (turn trailer brakes off for that trailer)
  5. Number of Axles - Single axle vs tandem/triple axle configuration
Important: The parameters available for configuration depend on which trailer systems are installed on your specific Tacoma:
  • Integrated Trailer Brake Controller
  • Trailer Backup Guide system
  • Trailer Mode BSM (Blind Spot Monitor)
Step-by-Step Profile Creation​
  1. Connect trailer to 7-pin connector (if equipped)
  2. Start engine (system may auto-detect trailer via 7-pin connection)
  3. Navigate to Trailer Settings screen on Multi-Information Display
  4. Select "Add New Trailer"
  5. Enter trailer name
  6. Set length to "Auto" (or enter exact length if known)
  7. Select hitch type, brake type, number of axles
  8. Confirm and save profile
  9. If using Auto length: Drive and make two 90-degree turns for TLD learning
  10. Profile is now active and saved for future use
Selecting an Existing Saved Trailer​
When connecting a trailer you've already configured, select its profile from the Trailer Settings screen.
When to Select:
  • When connecting a trailer you've previously saved
  • System can auto-detect 7-pin equipped trailers
Effect of Selection:
  • Trailer Brake Controller uses stored brake type
  • Blind Spot Monitor extends detection zone to match stored trailer length
  • Trailer Backup Guide knows trailer dimensions for guidance
  • Trailer Driving Assist features activate with trailer-specific parameters
Editing Saved Trailer Parameters​
You can modify the parameters of any previously saved trailer:
Editable Parameters:
  • Trailer name
  • Trailer length
  • Hitch type
  • Brake type
  • Number of axles
When to Edit:
  • Correcting initial setup mistakes
  • Updating trailer length if measured incorrectly
  • Changing brake configuration after trailer brake upgrades
  • Adjusting after trailer modifications
Deselecting the Currently Selected Trailer​
The system includes a "Deselect" function to manually indicate no trailer is connected.
When to Use:
  • After disconnecting a 4-pin trailer (system cannot auto-detect 4-pin disconnection)
  • When trailer is detached but system still thinks it's connected
  • Before entering a car wash
Important: 7-pin trailer connectors can be detected automatically by the Trailer Brake Controller, but 4-pin connectors require manual deselection.
Automatic Trailer Detection (ATD) System​
The Trailer Driving Assist system includes Automatic Trailer Detection that identifies when a trailer is connected.
Detection Methods​
  1. 7-pin connector engagement: Immediate detection when proper wiring harness connected
  2. BSM sensor detection: Blind Spot Monitor sensors identify trailer presence
    • Requires forward movement at >0.6 mph (1 km/h) for at least 10 seconds
    • System prompts on instrument cluster: "Trailer detected - Press YES to confirm"
    • Once confirmed, BSM detection area extends up to about 50 ft (15m) from rear bumper
Detection Triggers:
ATD function activates at every engine start/stop cycle, or when:
  • Vehicle stopped with shift lever in P or N, OR
  • Parking brake engaged for more than 90 seconds
Detection Limitations:
Trailer detection via BSM sensors can be delayed in:
  • Crowded parking lots (sensor confusion from nearby vehicles)
  • Areas surrounded by trees, like campgrounds (sensor reflections)
  • Environments with objects immediately around truck
Trailer Length Detection (TLD)​
If you save a trailer profile with length set to "Auto", the Trailer Length Detection function will automatically estimate trailer length using the Blind Spot Monitor sensors.
TLD Process:
  1. Connect trailer and select profile (or allow auto-detection)
  2. Set trailer length to "Auto" in profile
  3. Make at least two 90-degree turns while driving
  4. System calculates trailer length based on sensor data
  5. BSM detection zone automatically adjusts to match detected length
Manual Length Entry:
If you enter trailer length manually via the Multi-Information Display:
  • Detection area is adjusted to exceed the specified trailer length
  • No 90-degree turns required
  • Provides immediate, accurate detection zone
Why Length Matters:
  • Trailer Merge Warning (TMW): Alerts you via outside mirror indicators when vehicles enter the extended blind spot zone created by your trailer
  • BSM Accuracy: Detection zone must extend beyond trailer length to catch vehicles in adjacent lanes behind your trailer
Note: Some trailer/bumper combinations can degrade TMW performance depending on trailer dimensions and bumper configuration.
Real-World Tips from the Community​
Answer Trailer Detection Prompts Correctly​
When you hook up a trailer, the Multi-Information Display screen will ask "Do you have a trailer?" Hit YES. When you unhook the trailer, confirm it's not there by hitting YES again when prompted. This helps the system properly track trailer connection status.
Source: Tacoma4G.com community
Disable PKBS Before Backing Up to Hitch​
Before backing up to connect your trailer, go into the settings menu and manually disengage the PKBS (Parking Support Brake) button. The truck's parking sensors won't let you back up close enough to hitch without this.
However, the system will automatically disable PKBS after you answer "yes" to the trailer detection prompt.
Initial Trailer Brake Controller Setting​
Once connected to your trailer's 7-pin connector, use the integrated trailer brake controller (+/- buttons on dash) to adjust the assist level to about 4.5 or 5.0 as a starting point. Fine-tune from there based on your trailer's braking response.
Use Descriptive Profile Names​
In the Multi-Information Display, use specific names like "16ft Boat Trailer" or "25ft Travel Trailer" rather than generic names. This makes quick identification easier when switching between trailers.
Engage Tow/Haul Mode for Trailer Sway Control​
Make sure you select "tow/haul" mode from the dial on console. Engaging Tow/Haul mode activates the trailer sway control system, which helps stabilize the trailer by applying individual brakes to specific wheels if sway is detected.
Common Issues and Workarounds​
Persistent "Trailer Detected" After Disconnecting​
Issue: The truck can continue to indicate a trailer is detected after disconnecting, which turns off several safety systems including lane keeping with cruise control.
This is a known problem by Toyota requiring dealer software updates.
Workarounds until Toyota issues fix:
  1. Hook up the trailer and drive until "trailer detected" message appears, then answer "NO" when prompted
  2. Disconnect negative battery terminal for 5-10 minutes, reconnect, then attach and move trailer before disconnecting again
  3. In some cases, removing the trailer hitch stops false prompts (rear camera can detect hitch as trailer)
Technical Fix: Toyota has a TSB (Technical Service Bulletin) to reprogram the BSM (Blind Spot Monitoring), which is identified as the cause. In some cases, a failed blind spot sensor caused both the trailer detection issue and made lane guidance assist nonfunctional.
False Trailer Detection with Bed Cargo​
The automatic trailer detection system can recognize a "trailer" when there is weight in the bed with the tailgate down, even when no trailer is actually connected. The BSM (Blind Spot Monitoring) sensors can be interpreting bed cargo extending past the tailgate as a trailer.
This is normal behavior, not a malfunction.
Unexpected trailer detection prompts when hauling cargo with tailgate down are expected.
4-Pin vs 7-Pin Trailer Connector Understanding​
Key Differences​
4-Way (4-pin) connector:
  • Basic lighting functions only (running lights, turn signals, brake lights, ground)
  • For boat trailers or utility trailers
  • No trailer brake control capability
  • No battery charging circuit
  • Requires manual profile selection/deselection
7-Way (7-pin) connector:
  • All lighting functions from 4-way
  • 12V circuit for trailer brakes (integrates with Integrated Trailer Brake Controller)
  • Charging line for trailer house battery
  • Auto-detection capability
  • Full trailer profile parameter support
Upgrading from 4-Pin to 7-Pin​
Simple Adapter (Limited Functionality):
A 4-pin to 7-pin adapter provides the 7-pin socket but will only give you trailer light functions. Not brake controller integration or battery charging.
Full 7-Way Upgrade:
For fully functioning 7-way trailer capabilities including electric brake support, you need:
  • Complete 7-way upgrade wiring kit
  • Integrated Trailer Brake Controller (if not factory equipped)
  • Professional installation recommended
Source: etrailer.com, Tacoma4G.com community
Q: Why would I need multiple trailer profiles?
A: If you tow different trailers with varying lengths, brake systems, or weight characteristics, each profile ensures the Tacoma's towing assists (brake controller gain, blind spot detection zone, backup guidance) are tuned for that specific trailer.
Q: What happens if I don't create a profile and just hook up a trailer?
A: The truck will still tow fine mechanically, but advanced features won't be dialed in:
  • Brake controller might not have correct brake type setting
  • Blind Spot Monitor uses default detection zone (might not cover long trailers)
  • Trailer Backup Guide won't have trailer dimensions
  • You'll miss the benefits of Toyota's Trailer Driving Assist suite
Q: Can I have two trailers with the same name?
A: Technically yes, but it defeats the purpose of quick identification. Use descriptive names for easier selection.
Q: Does the profile store trailer weight?
A: No. Profiles store dimensional and configuration data only (length, hitch type, brake type, axles). Trailer weight affects vehicle dynamics but isn't a stored parameter. The truck detects weight through sensors during actual towing.
Q: Will selecting the wrong profile damage something?
A: No physical damage, but functionality can be compromised:
  • Wrong brake type: Trailer Brake Controller won't modulate brakes correctly (safety issue)
  • Wrong length: Blind Spot Monitor detection zone can be too short or too long (false alerts)
  • Wrong trailer entirely: All towing assists will use incorrect parameters
This guide synthesizes information from the following pages of your 2024+ Toyota Tacoma Owner's Manual:
Primary Pages:
  • Page 103: Trailer settings screen overview
  • Page 112: Complete trailer menu options (add, select, edit, deselect)
  • Page 311: Trailer Driving Assist features (ATD, TLD, TMW)
For complete technical specifications and warranty information, always refer to your official owner's manual.
  • Primary procedure: Pages 103, 112
  • Trailer Driving Assist integration: Page 311
  • Tacoma4G.com (4th generation owner community)
  • 4thGenTacoma.com (4th generation forum)
  • TacomaWorld.com (multi-generation community)
  • etrailer.com (trailer accessory technical information)
This guide is derived from the official 2024+ Toyota Tacoma Owner's Manual (OM04041U) with supplementary information from the owner community and authoritative sources. Always follow your official owner's manual for warranty compliance. This is a reference guide only and does not replace professional installation or Toyota dealer guidance for trailer system diagnostics.
