2024+ 4th Gen Tacoma - Calculating Tongue Weight & Towing Capacity Specs
Tongue weight isn't just a number. It directly impacts how your Tacoma handles, brakes, and stays stable on the road. Too little and your trailer sways. Too much and you overload the rear suspension and lose steering control. Here's how to calculate it correctly and understand the towing capacity specs for your specific configuration.
(Reference: Owner's Manual, pg. 196, 204-205)
Tongue Weight Calculation, Payload Capacity, Trailer Weight Distribution​
Toyota specifies a 9% to 11% tongue weight ratio for conventional towing:
Formula:
(Tongue Weight ÷ Gross Trailer Weight) × 100 = 9% to 11%
Calculation Examples:
  • 3,000 lb trailer = 270-330 lb tongue weight (9-11%)
  • 4,000 lb trailer = 360-440 lb tongue weight
  • 5,000 lb trailer = 450-550 lb tongue weight
  • 6,500 lb trailer = 585-715 lb tongue weight (9-11%)
Why This Range Matters:
  • Below 9%: Trailer becomes tail-heavy and prone to dangerous sway at highway speeds
  • 9-11% (Target): Sweet spot. Trailer tracks straight, Tacoma maintains steering control
  • Above 11%: Overloads rear suspension, lifts front end, reduces steering response
Towing Weight Rating (TWR) & Gross Combined Weight Rating (GCWR) by Model​
Xtra Cab Specifications:
Code:
Model Code         Bed   Grade           GCWR                  TWR (Max Trailer)
TZNA40L-CRZSZA     Long  SR5             11,115 lb (5,040 kg)  6,500 lb (2,950 kg)
TZNA40L-CRZSZA     Long  TRD PreRunner   11,155 lb (5,060 kg)  6,500 lb (2,950 kg)
TZNA41L-CRZ-STA    Long  SR              8,105 lb (3,675 kg)   3,500 lb (1,585 kg)
TZNA45L-CRZSZA     Long  SR5             11,335 lb (5,140 kg)  6,500 lb (2,950 kg)
TZNA46L-CRZ-STA    Long  SR              8,335 lb (3,780 kg)   3,500 lb (1,585 kg)
Unbraked Trailer Rating (All Models): 1,000 lb (453 kg)
This is the maximum weight for trailers without their own braking system. Most states require trailers over 1,000-3,000 lb to have functional trailer brakes. Requirements vary by state, so check your local regulations.
Find Your Model Code: Certification Label on driver's door jamb (referenced on page 614)
SAE J2807 Compliance: All specifications shown meet SAE International's standardized tow-vehicle trailering requirements (acceleration, braking, grade climbing tests).
How to Measure Tongue Weight Accurately​
The gross trailer weight, gross axle weight and tongue weight can be measured with platform scales found at:
  • Highway weighing station
  • Building supply company
  • Trucking company
  • Junk yard
Measurement Methods:
Method 1: Platform Scales (Most Accurate)
  1. Weigh your Tacoma alone (without trailer attached)
  2. Weigh your Tacoma with trailer coupled on hitch ball
  3. Subtract measurement 1 from measurement 2 = tongue weight
Method 2: Bathroom Scale (Home Approximation)
  1. Place bathroom scale under trailer jack
  2. Ensure scale is on solid, level surface
  3. Reading on scale = approximate tongue weight
  4. Note: Less accurate for trailers over 3,000 lb
Method 3: Tongue Weight Scale (Purpose-Built)
Use a commercial tongue weight scale designed for trailer hitches (available at RV/towing suppliers).
Understanding Payload Capacity​
Your Tacoma's exact payload capacity is printed on the Tire and Loading Information placard on the driver's door jamb.
This placard shows:
  • Vehicle Capacity Weight (occupants + cargo combined limit)
  • Seating capacity weight
  • Available cargo capacity
Critical Understanding: Tongue weight from your trailer counts against your payload capacity.
Payload Calculation Formula:
Available Payload = Maximum Payload Capacity (door jamb placard)
- Occupant Weight
- Cargo Weight
- Tongue Weight from Trailer
Example Scenario:
Your Tacoma has 1,500 lb payload capacity (verify on your door jamb):
  • Driver + passenger: 350 lb
  • Cargo in bed: 200 lb
  • Trailer tongue weight: 500 lb
  • Total payload used: 350 + 200 + 500 = 1,050 lb
  • Remaining capacity: 1,500 - 1,050 = 450 lb (within limits)
If tongue weight were 800 lb:
  • Total payload used: 350 + 200 + 800 = 1,350 lb
  • Status: Exceeds safe limits, reduces steering control
Typical Payload Capacity by Configuration:
Note: These are general estimates based on owner reports and community data, not official specifications. Always verify your specific vehicle's door jamb placard for accurate payload capacity. Actual capacity varies by trim, options, and configuration.
  • SR base model 4x2: Estimated 1,500-1,600 lb (unverified - check your door jamb)
  • TRD Off-Road 4x4: Around 1,200-1,300 lb (verified from owner's manual)
  • Crew Cab vs Double Cab: Different capacities
  • Bed length (Short vs Long): Affects payload capacity
Real-World Towing Considerations​
Your Towing Capacity is Limited by the LOWEST of:
  1. TWR (Towing Weight Rating): From table above (3,500 or 6,500 lb)
  2. GCWR minus actual vehicle weight: If your loaded Tacoma weighs 5,500 lb and GCWR is 11,115 lb, maximum trailer = 5,615 lb
  3. Hitch capacity: Aftermarket hitch rating must meet or exceed trailer weight
  4. Payload capacity: Must have sufficient payload for tongue weight + occupants + cargo
Example Limiting Factor:
TRD Off-Road with 1,250 lb payload capacity, towing a 6,000 lb trailer:
  • Tongue weight (10%): 600 lb
  • Total: 950 lb payload used
  • Remaining capacity: 300 lb for cargo (doable but tight)
Same scenario with 1,000 lb payload capacity:
  • Total payload needed: 950 lb
  • Status: Exceeds capacity by 50 lb
  • Even though TWR is 6,500 lb, you cannot safely tow this trailer
This is why payload capacity often limits towing more than TWR rating.
Common Tongue Weight Mistakes:
Mistake 1: Loading trailer with too much weight at the rear
  • Symptom: Tongue weight drops below 9%
  • Result: Trailer sway, especially in crosswinds or when passed by semis
  • Fix: Shift cargo forward in trailer, heavier items ahead of axle(s)
Mistake 2: Assuming tongue weight is negligible
  • Reality: 10% of a 6,000 lb trailer = 600 lb tongue weight
  • Impact: Consumes 40% of a 1,500 lb payload capacity
  • Result: Less room for passengers/cargo than expected
Mistake 3: Not accounting for propane/water/gear added at campground
  • Empty travel trailer: 4,000 lb, tongue weight 400 lb
  • Filled with water/propane/gear: 5,500 lb, tongue weight 550 lb
  • That extra 150 lb tongue weight matters for payload calculations
Weight Distribution Hitch Procedure​
If using a weight distributing hitch when towing, return the front axle to the same weight as before the trailer connection.
Adjustment Method:
  1. Measure front fender height above the front axle before connecting trailer
  2. Connect trailer and engage weight distribution hitch
  3. Adjust weight distributing hitch torque until front fender returns to the same height as before connection
  4. Do not reduce front fender height below original measurement
When Weight Distribution Hitch is Required:
  • Trailers over 5,000 lb gross weight
  • Noticeable rear squat when trailer attached (more than 1-2 inches)
  • Headlights aim noticeably upward while towing
Hitch Selection and Installation​
Toyota recommends using a Toyota hitch/bracket for your vehicle.
Critical Requirements:
  • Use only a hitch that conforms to the gross trailer weight requirement of your vehicle
  • Follow the directions supplied by the hitch manufacturer
  • Use the correct trailer ball for your application
  • Lubricate the hitch ball and kingpin with a light coating of grease
Hitch Class Requirements by TWR:
If your TWR is 3,500 lb:
  • Minimum hitch class: Class III (rated 3,500-8,000+ lb depending on model)
  • Ball size: Verify with trailer coupler specification
If your TWR is 6,500 lb:
  • Minimum hitch class: Class IV (6,500+ lb rating)
  • Ball size: Usually 2" or 2-5/16" depending on trailer
  • Weight distribution hitch highly recommended
Never use:
  • Bumper-mounted hitches (prohibited by Toyota)
  • Hitches with lower capacity than your trailer weight
  • Step bumper holes for hitch mounting
Hitch Maintenance:
  • Remove the hitch ball whenever you are not towing a trailer
  • Remove the trailer hitch if you don't need it
  • After removing the hitch, seal any mounting holes in the vehicle body to prevent entry of any substances into the vehicle
Critical Safety Warnings​
Hitch Weight Capacity
Trailer hitch assemblies have different weight capacities established by the hitch manufacturer. Even though your Tacoma can physically tow a higher weight, you need to check the maximum weight rating of your particular hitch assembly.
Exceeding the hitch manufacturer's weight rating can cause serious problems. The hitch itself becomes the weak point that fails.
When installing a trailer hitch, use only the position recommended by your Toyota dealer. Don't install the trailer hitch on the bumper. This can cause body damage.
Storage and Loading Safety
Some items are fire hazards and should never go in the cab:
  • Receptacles containing gasoline
  • Aerosol cans
Loading safety matters for handling and control:
  • Don't stack anything behind the front seats higher than the seatbacks
  • Don't place cargo at the driver's feet, on the dashboard, or on the instrument panel
  • Secure all items in the cab (loose items become projectiles in sudden stops)
  • Never let anyone ride in the bed (it's not designed for passengers and they risk serious injury in sudden braking or accidents)
Capacity and Weight Distribution
Don't exceed the maximum axle weight rating or the total vehicle weight rating. Even if your total load (occupants + cargo) is under the limit, don't load unevenly. Improper weight distribution affects steering and braking control.
Recommended Products for Towing Setup​
  • Tongue weight scale (for accurate measurement)
  • Weight distribution hitch (for trailers over 5,000 lb)
  • Class III or IV hitch (based on your TWR)
  • Trailer brake controller (required for trailers over 1,000 lb)
  • Adjustable hitch ball mount
  • Marine-grade grease for hitch ball
A downloadable PDF containing the exact manual pages referenced in this guide is available for your records.
Pages Covered in This Thread:
  • Pages 204-205: Towing specifications, tongue weight calculation, weight distribution hitch procedure, hitch selection
  • Page 196: Cargo loading safety warnings
  • Page 614: Model code location reference
  • Primary specifications and formulas: Pages 204-205
  • Cargo loading safety: Page 196
  • Model code location reference: Page 614
This guide is derived from the official 2024+ Toyota Tacoma (4th Gen) Owner's Manual (OM04041U) with supplementary context explaining real-world applications. Always follow your official owner's manual for warranty compliance. Specifications shown are for gas-engine models (T24A-FTS). i-FORCE MAX Hybrid specifications may differ—consult Hybrid Owner's Supplement (OM04042U). This is a reference guide only.
