2024+ 4th Gen Tacoma - Check Engine Light (Malfunction Indicator)
A check engine light can mean anything from a loose gas cap to a serious engine problem. Before you panic or rush to the dealer, here's what the light means for your 4th gen Tacoma and what steps to take first.
(Reference: Owner's Manual, pg. 569, 576)
Check Engine Light, CEL On, Engine Warning, MIL Light, Gas Cap Loose​
The malfunction indicator lamp (check engine light) appears as a check engine symbol on your dashboard, accompanied by a warning buzzer. It monitors three critical systems:
  • Electronic engine control system
  • Electronic throttle control system
  • Emission control system
When the light comes on, one of these systems has detected a fault.
The good news: many check engine lights are simple fixes you can handle yourself.
First Steps (Do This Before Anything Else)​
Toyota tells you to check two things first because they're the most common causes across all vehicles:
1. Check Your Fuel Tank
Is it empty? Running out of fuel triggers codes related to fuel system pressure and delivery. Fill the tank immediately if low.
2. Check Your Fuel Cap
Is it loose? This is the single most common cause of check engine lights on any vehicle. The EVAP system monitors fuel vapor containment, and a loose cap creates a vacuum leak the system detects as an emission malfunction.
Tighten the cap until you hear it click.
3. Wait for the Light to Clear
After fixing the fuel cap, the light won't turn off immediately. The computer needs to verify the problem is fixed over multiple drive cycles (engine start, drive, engine off). Expect 3-5 drive cycles before the light goes out on its own.
If the light doesn't go off after several trips, contact your Toyota dealer.
4th Gen Tacoma-Specific Information​
Known Technical Service Bulletins:
As of November 2025, Toyota has issued TSBs that can trigger check engine lights on the 4th gen:
TSB 24TC06 - Active Grille Shutter
  • Issue: Incorrect seal allows water intrusion
  • Result: Engine warning light
  • Coverage: Warranty repair
Transmission-Related TSB
  • Issue: Transmission failures with specific fault codes
  • Result: Check engine light with transmission codes
  • Coverage: Warranty replacement in affected cases
NHTSA Recall 24V-381
  • Affected: 2024 Tacoma with V35A engine
  • Issue: Machining debris on crankshaft bearings
  • Result: Engine performance issues, potential stalling
  • Remedy: Free engine inspection and repair
Check for open recalls first if your check engine light appears. Grille shutter and transmission issues are known patterns with warranty coverage.
Most Common Real-World Cause: Loose Battery Cables
Multiple 2024 Tacoma owners have reported "12-Volt Battery Charging System Malfunction" warnings caused by loose battery cable connections, particularly the negative terminal. One owner found the negative cable "just swinging in the breeze."
Check your battery terminal connections before visiting the dealer. This simple fix could save you a trip.
T24A-FTS Engine-Specific Codes
The 4th gen uses a new turbocharged 4-cylinder platform (different from the 3rd gen V6). The most common diagnostic code for this engine is P05CE (camshaft position), resolved with ECM reprogramming. Diagnostic patterns are still emerging for this engine.
Critical Safety Warning: Flashing Check Engine Light​
NEVER Continue Driving with a Flashing Light
A flashing check engine light indicates severe engine misfire. Unburned fuel enters the exhaust and can rapidly superheat the catalytic converter to the point of permanent damage, requiring expensive replacement ($2,000+).
Immediate Actions:
  1. Pull over safely
  2. Contact Toyota dealer immediately
  3. Assess if the vehicle is safe to drive or requires a tow
  4. Do not continue extended driving
CRITICAL Warning for Hybrid Owners​
If you own an i-FORCE MAX Hybrid, do not attempt the traditional "disconnect battery to clear codes" method.
Disconnecting the battery on a hybrid requires the dealer to reboot the entire ECU. The hybrid electrical architecture is fundamentally different. Dealer service is required after any battery disconnection.
Warranty Coverage​
Basic Warranty: 3 years / 36,000 miles
  • Covers all dealer diagnostics for check engine light
  • No diagnostic fees during this period
  • Includes loaner vehicle during repairs
Powertrain Warranty: 5 years / 60,000 miles
  • Engine, transmission, drivetrain components
  • Emission control system issues
Emissions Warranty:
  • Major components (catalytic converter, ECM): 8 years / 80,000 miles
  • Other emissions components: 2 years / 24,000 miles
Multiple 4th gen owners have confirmed grille shutter repairs, battery replacements, and transmission issues are covered under warranty with no diagnostic fees.
Modifications and Warranty
Under the Magnuson-Moss Warranty Act, modifications don't void your entire warranty automatically. Dealers must prove that the specific modification caused the failure. The burden of proof is on the dealership.
Highest-Risk Mods:
  • ECU tuning/engine performance chips
  • Exhaust modifications affecting emissions
  • Cold air intake systems
Lower-Risk Mods:
  • Suspension upgrades
  • Cosmetic modifications
  • Lighting upgrades
OBD-II Diagnostic Tools​
Confirmed Compatible Scanner: Carista
Works with 4th gen Tacoma despite the app listing only 3rd gen. Cost: $9.99/month subscription required. User reports: "Plugging it in allows everything to work."
Q: Why does Toyota say to check the fuel tank and cap first?
A: These are the two most common causes of check engine lights across all vehicles. Running out of fuel triggers fuel system pressure codes. A loose fuel cap is the single most common cause. The EVAP system monitors fuel vapor containment, and a loose cap creates a vacuum leak.
Q: How long should I wait for the light to go off after fixing the fuel cap?
A: The computer uses a "drive cycle" concept. After you fix the cap, the fault code remains stored while the computer monitors the EVAP system over multiple starts. If no leak is detected, the code clears and the light turns off automatically. Timeline: 3-5 drive cycles (engine start, drive, engine off).
Q: When is it okay to diagnose codes myself vs. going to the dealer?
A: DIY-Friendly Codes:
  • P0455: EVAP system large leak (often fuel cap)
  • P0420: Catalyst efficiency below threshold
  • P0171/P0174: Fuel trim issues
Dealer-Required Codes:
  • P2135: Throttle position sensor correlation
  • C-codes: Chassis system faults (TSS-related)
  • U-codes: Network communication faults
  • Any code requiring TSS calibration or hybrid system diagnosis
Q: What are the proper voltage parameters for the charging system?
A: Normal charging voltage: 13.5-14.5 volts (engine running)
  • Below 13.5V = Potential charging system issue
  • Above 14.5V = Possible voltage regulator problem
Manual Reference​
Owner's Manual: Pages 569, 576
  • Toyota.com
  • NHTSA.gov
  • Cars.com
  • Tomorrow's Technician
  • Tacoma4G.com
  • TacomaWorld.com
  • 4GTaco.com
This guide is derived from the official 2024+ Toyota Tacoma Owner's Manual with supplementary information from the owner community. Always follow your official owner's manual for warranty compliance.
SELLING OEM TRD OFF ROAD HEADLIGHT SET...
5% all around! 50% on the windshield. Came out...
Proud owner of a pedestrian 25 SR5 2wd Taco...
Howdy folks, I picked up my first new vehicle...
