2024+ 4th Gen Tacoma - Checking & Replacing Fuses
Something stopped working? Before you head to the dealer, check the fuses. Most electrical problems trace back to a blown fuse, and most fuses you can replace yourself in about 5 minutes. Here's how to find, check, and replace fuses in your 4th Gen Tacoma.
(Reference: Owner's Manual, pg. 552-555)
Checking Fuses, Replacing Fuses, Fuse Box Location​
Important Safety Notes​
Fuses protect your truck from electrical fires. Never use a higher amperage fuse than specified, and never use a wire or other object as a temporary fix.
Always use a genuine Toyota fuse or equivalent. Using the wrong fuse creates serious fire risk.
Don't modify fuse boxes or fuse ratings. If a fuse keeps blowing, you have an electrical problem that needs diagnosis, not a bigger fuse.
(Source: Owner's Manual page 555)
Before You Start​
Step 1: Turn the Engine Switch OFF
Always work with the electrical system de-energized. Remove the key fob from the vehicle if possible.
Step 2: Identify Which Component Stopped Working
This helps you locate the correct fuse box and circuit. Check your owner's manual fuse diagram (on the fuse box lid) for specific fuse locations.
Fuse Box Locations​
Your 4th Gen Tacoma has three or four fuse box locations depending on configuration:
  • Engine compartment: type A fuse box
  • Engine compartment: type B fuse box
  • Passenger side instrument panel
  • Under the right-hand rear seat (vehicles with rear seats)
(Source: Owner's Manual pages 552-553)
The 4th Gen Tacoma has two types of engine compartment fuse boxes (Type A and Type B) depending on trim and options. Check which type your vehicle has. Both are accessed similarly but have different fuse arrangements.
Accessing the Engine Compartment Fuse Box​
For Type A or Type B Engine Fuse Box:
  1. Open the hood (see Page 522-523 for hood release procedure)
  2. Locate the black fuse box near the battery (driver's side engine bay)
  3. Push the tabs inward on both sides of the lid
  4. Lift the lid off completely
  5. The fuse diagram is printed on the underside of the lid - reference this to identify the correct fuse
Accessing the Passenger Side Instrument Panel Fuse Box​
  1. Open the passenger door
  2. Locate the fuse box cover on the lower dashboard (passenger side)
  3. Remove the cover by gently pulling it toward you
  4. Remove the lid by pushing the claw tab and lifting
Note: Push the claw tab carefully when removing or installing the lid to avoid breaking it. Multiple forum posts mention this cover is trickier to remove in the 4th Gen than previous generations. Pull at a specific angle until you feel it release.
Accessing the Rear Seat Fuse Box (Vehicles with Rear Seats)​
  1. Raise the bottom cushions (see Page 157 for rear seat operation)
  2. Remove the side cover on the right side
  3. Remove the clips securing the rear seat undercover
  4. Pull the undercover forward in the order A, B and remove it
  5. Remove the clips securing the storage box corner
  6. Lift up the near corner of the storage box to access the fuse box
This fuse box location is specific to Double Cab and CrewMax configurations with rear seats.
Checking a Fuse​
Step 1: Locate the Suspect Fuse
Use the diagram on the fuse box lid. Fuses are labeled by amperage (5A, 10A, 15A, 20A, etc.) and diagrams show which circuit each fuse protects.
Pro Tip: Take a photo of the fuse box lid diagram with your phone before starting. This gives you a reference without holding the lid awkwardly while searching for the fuse.
Step 2: Remove the Fuse
Only type A fuses can be removed using the pullout tool. For Type B fuses, grasp and pull to remove. Type C and D fuses require dealer service — do not attempt to remove them yourself.
(Source: Owner's Manual page 554)
Step 3: Inspect the Fuse Filament
  • Type A fuses: Look through the clear plastic for the metal strip inside
  • Type B fuses: Check the visible metal connection
  • Normal fuse: Metal strip is continuous (intact)
  • Blown fuse: Metal strip is broken or melted (visible gap)
Visual Reference: Page 554 shows comparison images of normal vs. blown fuses for all four types.
Replacing a Blown Fuse​
For Type A and B Fuses (DIY Replacement):
Type A and B: Replace the blown fuse with a new fuse of an appropriate amperage rating.
Type C and D: Contact your Toyota dealer.
  1. Identify the correct amperage rating
    The amperage rating is on the fuse box lid. NEVER use a higher amperage fuse. This creates fire risk. Example: If the fuse box lid shows "15A," use only a 15-amp fuse.
  2. Remove the blown fuse completely
    Use the pullout tool for Type A. Grasp and pull for Type B.
  3. Install the new fuse of the same amperage rating
    Push firmly until fully seated. Ensure fuse sits flush and secure in the socket.
  4. Test the circuit
    Turn the engine switch ON. Test the component (lights, wipers, etc.). If it works, replacement was successful.
For Type C and D Fuses (Dealer Service Required):
Type C and D fuses are higher-capacity fuses for critical systems. These require special tools and Toyota dealer service:
  • Do NOT attempt to replace Type C or D fuses yourself
  • Contact your Toyota dealer for replacement
  • These fuses protect high-current circuits (starter, alternator, main power)
After Replacement​
When installing the lid, make sure that the tab is installed securely.
If the lights do not turn on even after the fuse has been replaced, a bulb may need replacement.
Note (Before Replacing Fuses): Have the cause of electrical overload determined and repaired by your Toyota dealer as soon as possible.
(Source: Owner's Manual page 555 — NOTICE: Before replacing fuses)
If the replaced fuse blows again, have the vehicle inspected by your Toyota dealer.
Modern Toyotas use intelligent fuse circuits that may integrate with the vehicle's computer systems. If the same fuse blows repeatedly, there's an electrical short or overload that must be diagnosed with Toyota diagnostic equipment.
Understanding Fuse Types​
Why Four Fuse Types?
The 4th Gen Tacoma uses four fuse types to accommodate different current requirements:
  • Type A (Blade Fuses): Most common, 5A-30A, DIY-friendly with pullout tool
  • Type B (Mini Blade Fuses): Compact version, 5A-30A, DIY-replaceable
  • Type C (Cartridge Fuses): High-current circuits (40A-120A), requires dealer service
  • Type D (Mega Fuses): Main power distribution (100A+), requires dealer service
Why the Pullout Tool Only Works with Type A
Type A blade fuses have a raised center section that the pullout tool grips. Type B fuses are too small, while Type C and D fuses require higher pull force and special extraction tools to avoid damage to the fuse box terminals.
Fuse Box Lid Diagrams Are Your Roadmap
The 4th Gen has a complex electrical system with multiple fuse circuits across four locations. The lid diagram shows:
  • Fuse position (numbered)
  • Circuit name (what it protects)
  • Amperage rating (what to replace with)
Tips from Tacoma Owners​
Use Online Fuse Diagram Resources
The 4th Gen Tacoma fuse box diagrams on the lids can be hard to read. Community members recommend using StartMyCar's online fuse location tool for clearer diagrams, or downloading the Factory Service Manual with Electrical Wire Diagram from factorymanuals.net.
Source: Tacoma4G.com
Tweezers Work as Fuse Puller Alternative
If you can't find the Toyota fuse puller tool, regular tweezers work well for removing Type A fuses. Many forum members keep needle-nose tweezers in their glovebox as a backup.
Source: Paul's Travel Pictures (DIY Guide)
Download Fuse Diagrams to Phone
Since the 4th Gen has 4 fuse panel locations, many owners download fuse diagrams from tacoma4g.com to their phones as quick reference. Helpful when troubleshooting at night or in parking lots.
Not Fixing Root Cause Before Replacing Fuse
The most common mistake is replacing the fuse without checking for the underlying problem (short circuit, damaged wiring, faulty component). A December 2024 case on TacomaWorld documented a 4th Gen owner who blew a 30 amp fuse due to faulty trailer wiring. If you don't fix the cause, the new fuse will blow immediately or shortly after installation. This can lead to progressive wiring damage and potential fire risk.
Source: TacomaWorld.com
Overloading Circuits with Aftermarket Accessories
4th Gen owners installing LED light bars, auxiliary lights, or high-power accessories without proper relay wiring are blowing fuses. The factory fuses are sized for OEM components. Adding high-draw accessories requires circuit upgrades or dedicated circuits. Even if the fuse doesn't blow immediately, operating near fuse capacity causes heat buildup in terminals and can melt fuse box components over time.
Source: StartMyCar
Assuming All Fuses Are User-Replaceable
Some 4th Gen owners have attempted to replace Type C and D fuses without realizing these require dealer service. Using improper tools can damage high-current fuse terminals. Type C and D fuses protect critical systems (starter, alternator, main power distribution). Incorrect installation can cause no-start conditions or leave the vehicle without proper overcurrent protection.
Why Fuses Blow: Root Cause Analysis​
Community troubleshooting has identified the most common causes:
  1. Short circuits - Damaged, frayed, or pinched wires contacting metal
  2. Defective bulbs - Burned-out bulbs can short internally before fully failing
  3. Aftermarket modifications - LED conversions, accessory lighting, trailer wiring
  4. Water intrusion - Especially in rear seat fuse box during bed usage/off-roading
  5. Faulty relays - Stuck relays cause continuous current draw
Source: YotaTech.com
Q: What if multiple components stopped working at once?
A: If several related systems fail simultaneously (e.g., all interior lights), check the common fuse that feeds multiple circuits. Look for "main" or "power" fuses in the engine compartment. This may indicate a Type C or D fuse issue requiring dealer service.
Q: The fuse looks normal but the component doesn't work. What now?
A: Sometimes fuses can fail internally without visible damage. Replace the fuse anyway with a known-good fuse of the same amperage. If the component still doesn't work, the problem is NOT the fuse. Check the component itself (bulb, relay, module).
Q: Why does my 4th Gen have more fuse locations than my old Tacoma?
A: The 3rd Gen Tacoma (2016-2023) had two primary fuse boxes (engine and interior). The 4th Gen adds locations because of more electronic systems (TSS 3.0, digital displays, multiple cameras), distributed electrical architecture that places fuses closer to the components they protect, and easier serviceability by separating frequently-accessed fuses from rarely-accessed main fuses.
The rear seat fuse box primarily serves: rear entertainment systems (if equipped), trailer brake controller, auxiliary power outlets (bed outlet), and some off-road systems (rear diff lock, SDM).
Q: Where can I buy replacement fuses?
A: Genuine Toyota fuses are available at your Toyota dealer or parts.toyota.com. Quality aftermarket fuses (Bussmann, Littelfuse) that meet Toyota specifications are also acceptable and available at any auto parts store.
Recommended Products​
  • Genuine Toyota fuses or equivalent (Bussmann, Littelfuse brands)
  • Fuse assortment kit for glovebox (5A, 10A, 15A, 20A, 25A, 30A)
  • Needle-nose tweezers (for fuse removal)
  • Low-profile fuse tap adapters (for interior fuse box installations with limited clearance)
This thread references the following pages from your 2024+ Toyota Tacoma Owner's Manual:
  • Primary pages: 552, 553, 554 (fuse box locations, checking/replacing procedures)
  • Supporting pages: 555 (safety warnings, post-replacement guidance)
For downloadable PDF of these exact pages, see ready-to-publish folder.
  • Fuse box locations and access procedures: Pages 552-553
  • Checking and replacement procedures: Page 554
  • Safety warnings and post-replacement guidance: Page 555
  • Tacoma4G.com (4th Gen Tacoma community forum)
  • TacomaWorld.com (established Tacoma owner community)
  • YotaTech (Toyota enthusiast resource)
  • StartMyCar (fuse diagram reference)
  • Paul's Travel Pictures (DIY automotive guides)
This guide is derived from the official 2024+ Toyota Tacoma Owner's Manual (OM04041U) with supplementary information from the owner community and automotive resources. Always follow your official owner's manual for warranty compliance. This is a reference guide only.
For safety-critical electrical issues, consult your Toyota dealer. Improper fuse replacement can cause vehicle damage or fire risk.
