If your state requires emission testing, your Tacoma's OBD (On-Board Diagnostics) system needs to show "ready" status before you'll pass. Here's what I/M readiness means, why your truck might not be ready, and how to get those readiness codes set.
(Reference: Owner's Manual, pg. 518-519)
Some states require vehicle emission inspection programs that include OBD checks. The OBD system in your 2024-2025 Tacoma continuously monitors the operation of emission control systems to ensure they're functioning properly and meeting emission standards.
What the OBD System Does:
Your Tacoma's OBD system tracks "readiness codes" (also called monitors) during normal driving. These codes indicate that specific emission control systems have been tested and verified to be working correctly. State emission inspectors check these readiness codes to determine if your vehicle is ready for testing.
According to your owner's manual (pages 518-519), your vehicle may not pass the I/M test in these situations:
The OBD system has detected a problem in the emission control system. Your vehicle may not pass the I/M test and needs to be repaired. Contact your Toyota dealer to service the vehicle.
If the check engine light is illuminated, the vehicle must be diagnosed and repaired before it can pass I/M testing.
When the battery is disconnected or discharged, readiness codes that are set during ordinary driving are erased. Also, depending on your driving habits, the readiness codes may not be completely set.
When you disconnect or replace your Tacoma's 12V battery (for service, replacement, or if it died), all readiness codes stored in the OBD system are erased. The system must "re-learn" and set these codes through normal driving before the vehicle is ready for I/M testing.
How long does it take to set readiness codes after battery disconnect?
Takes a mix of city and highway driving over several days to a week. The OBD system needs to see various operating conditions (cold starts, warm engine, different speeds, idle time) to complete all monitors.
Page 518 identifies that a loose fuel cap can affect I/M readiness. The EVAP (Evaporative Emission) system monitor checks for fuel vapor leaks, and a loose cap will prevent this monitor from completing or may trigger a malfunction code.
The error code in the OBD system will not be cleared unless the vehicle is driven 40 or more times.
If the check engine light comes on briefly (indicating a temporary problem) and then goes off, the error code remains stored in the OBD system. The code won't clear until the vehicle has been driven 40 or more times.
What This Means: Even though the light is off, the OBD system remembers the issue occurred. You'll need to accumulate 40 or more driving trips for the system to verify the problem hasn't returned and clear the stored code.
Contact your Toyota dealer to prepare the vehicle for re-testing.
If the malfunction indicator lamp remains illuminated after several complete driving trips, there's a persistent problem in the emission control system that requires diagnosis and repair.
If your vehicle fails I/M testing because readiness codes aren't set (common after battery service or clearing codes), you'll need to:
Some states allow a certain number of monitors to be "not ready" and still pass (typically 1-2 monitors). Check your state's specific requirements.
If your vehicle was repaired for an emission-related issue, the same readiness setting process applies. The technician should perform a "drive cycle" to set readiness before returning the vehicle, but verify all monitors are ready before scheduling your I/M test.
T24A-FTS Turbocharged Engine Emission Controls:
Your 4th generation Tacoma features Toyota's T24A-FTS turbocharged 4-cylinder engine with advanced emission controls:
Each of these systems has corresponding OBD monitors that must complete for full I/M readiness.
TSS 3.0 (Toyota Safety Sense) and Emission Systems:
The 4th gen Tacoma's advanced TSS 3.0 system is completely separate from emission controls and does NOT affect I/M readiness or OBD codes. A malfunctioning TSS component (camera, radar) will not cause emission test failure.
Common Tacoma OBD Monitors:
The specific monitors your Tacoma runs include:
Check Readiness Status Before Scheduling I/M Test
Many auto parts stores (AutoZone, O'Reilly) offer free OBD2 scans that show monitor status. Check a few days before your appointment to avoid failed tests and wasted time.
Source: ToyotaNation.com
Fuel Tank Should Be 1/4 to 3/4 Full for EVAP Monitor
The EVAP (Evaporative Emission System) monitor is one of the most stubborn to complete. It tests the fuel system for vapor leaks and requires the tank to be within this range. Too empty or too full prevents the monitor from running.
Source: Smogtips.com
Generic Toyota Drive Cycle
15 minutes of steady highway driving (55-60 mph) followed by 20 minutes of city stop-and-go driving with at least four 30-second idle periods. This mixed driving helps complete multiple monitors.
Source: Ohio eCheck (Government emission testing program)
OBD2 Scanners Work With 4th Gen Tacoma
Standard OBD2 scanners work with the 2024-2025 Tacoma for checking I/M readiness status. No Toyota-specific tool required for basic readiness monitoring (though Techstream or Carista offers more detail).
Source: Tacoma4G.com
Most States Allow 1-2 Incomplete Monitors
You don't need ALL monitors ready to pass in many states. Check your specific state regulations. Many allow 1 incomplete monitor (California sometimes allows 1 for newer vehicles, EPA states typically allow 1).
Source: MotorVehicleMaintenance StackExchange
Don't Clear Codes Thinking It Will Help You Pass
Clearing trouble codes also resets ALL readiness monitors to "not ready" status. You'll fail for insufficient monitors even if the underlying problem is fixed. Fix the issue first, then let monitors set naturally.
Source: ANCEL.com
Don't Disconnect Battery Right Before Emission Test
This is a common misconception. Disconnecting the battery to "reset" the system actually erases all readiness codes and guarantees an I/M failure. You need 1-2 weeks of varied driving after ANY battery service before testing.
Don't Only Drive Short Trips When Trying to Set Monitors
Monitors require varied driving conditions. Only driving 2-3 miles to work won't complete highway-speed monitors (like catalyst efficiency). You need sustained highway cruising (55+ mph for 10-15+ minutes) to set all monitors.
Source: JustSmogs.com
Don't Ignore Loose or Worn Gas Cap
A loose, damaged, or worn gas cap is one of the most common reasons for EVAP monitor failure and check engine lights. This is an easy fix that prevents test failure. Replace gas caps every 5-6 years or 50,000 miles as preventive maintenance.
Source: Multiple community sources
Why Monitors Need Varied Driving Conditions:
Each OBD monitor has specific "enable criteria" - conditions that must be met for the test to run. For example:
This is why simply idling your Tacoma in the driveway won't set monitors. The OBD system needs to see real-world driving conditions.
Source: Ohio eCheck (Government emission testing documentation)
Cold Start is Critical for Many Monitors:
"Cold start" means the engine has been off long enough for coolant and intake air temperatures to equalize within 10°F of each other and remain below 122°F at startup (typically 8+ hours, ideally overnight). Many monitors ONLY run during the first few minutes after a cold start, which is why short trips throughout the day are less effective than a single cold-start morning commute.
Source: TTORA (Tacoma community)
Emission testing requirements vary by state:
California (Strictest): Most stringent requirements. For 2000+ model year vehicles, all monitors must be ready except EVAP monitor may be incomplete. Biennial testing (every 2 years).
EPA Testing States: Arizona, Colorado, Connecticut, Delaware, Georgia, Idaho, Illinois, Indiana, Kentucky, Louisiana, Massachusetts, Maryland, Maine, Missouri, North Carolina, New Hampshire, New Jersey, New Mexico, Nevada, New York, Ohio, Oregon, Pennsylvania, Rhode Island, Tennessee, Texas, Utah, Virginia, Vermont, Washington, Wisconsin - typically allow 1 incomplete monitor.
No Testing Required: Alaska, Arkansas, Iowa, Kansas, Michigan, Minnesota, Mississippi, Montana, North Dakota, Nebraska, Oklahoma, South Carolina, South Dakota, West Virginia, Wyoming, Alabama, Florida, Hawaii.
Important Notes:
If you recently moved to a state requiring I/M testing, verify your Tacoma's readiness status before scheduling an appointment.
For detailed diagrams and visual references about OBD readiness monitors and emission testing procedures, consult pages 518-519 of your 2024+ Toyota Tacoma Owner's Manual (Document: OM04041U).
Your owner's manual includes system diagrams and detailed explanations of the emission control systems specific to your vehicle configuration.
Can I speed up readiness setting?
No reliable shortcuts exist. Some "drive cycle procedures" circulate online, but the OBD system completes monitors based on meeting specific operating conditions, not following a script. Normal varied driving is most effective.
Will disconnecting the battery clear a check engine light for testing?
Terrible idea. While it clears the light temporarily, it also erases all readiness codes, guaranteeing an I/M test failure for "not ready" status. States know this trick - that's why they check readiness.
What if one monitor won't set?
Some monitors (especially EVAP) can be stubborn. Verify:
If one monitor remains incomplete after extensive driving, check your state's allowance rules. You may still pass with 1 incomplete.
How do I check my readiness status myself?
Visit any auto parts store (AutoZone, O'Reilly, Advance Auto) for a free OBD2 scan that shows monitor status. Or purchase an inexpensive Bluetooth OBD2 scanner (works with 4th gen Tacoma) and use a smartphone app to check anytime.
Does my new 2024-2025 Tacoma need emission testing?
Most states exempt vehicles under 3-5 years old. Your new 4th gen Tacoma is likely exempt initially. Check your state's DMV website or emission testing program for specific age exemptions.
This guide synthesizes information from pages 518-519 of your 2024-2025 Toyota Tacoma Owner's Manual.
You can download these specific pages as a PDF for offline reference: [Attach pages-reference.pdf when posting]
This guide is derived from the official 2024-2025 Toyota Tacoma Owner's Manual (OM04041U) with supplementary information from the owner community and authoritative sources. Always follow your official owner's manual for warranty compliance and verify state-specific emission testing requirements with your local DMV or emission testing facility. This is a reference guide only and does not replace official documentation or professional advice.
Emission Inspection, I/M Readiness, OBD-II Testing
When Your Tacoma May Not Pass I/M Testing
Situation 1: Malfunction Indicator Lamp (Check Engine Light) is On
Situation 2: Battery Was Recently Disconnected or Discharged
Situation 3: Fuel Tank Cap is Loose
Situation 4: Temporary Malfunction Indicator Lamp
What to Do If Your Vehicle Doesn't Pass
Check Engine Light Still On After Multiple Trips
Failed I/M Test Due to "Not Ready" Status
- Drive the vehicle through varied conditions - Mix of city and highway driving
- Complete cold starts - Each trip should start with a cold engine
- Allow the system time - May take 1-2 weeks of normal driving
- Avoid repeated code clearing - Don't disconnect the battery again
Re-testing After Repairs
4th Gen Tacoma Emission System Details
- Direct injection system (high-pressure fuel delivery)
- Three-way catalytic converter
- EVAP system with canister purge valve
- PCV (Positive Crankcase Ventilation) system
- Secondary air injection (if equipped)
- Catalyst Monitor - Verifies catalytic converter efficiency
- EVAP Monitor - Checks for fuel vapor leaks (affected by loose gas cap)
- Oxygen Sensor Monitor - Verifies O2 sensor response
- Comprehensive Component Monitor - Checks inputs/outputs
- Misfire Monitor - Detects engine misfires affecting emissions
Tips from the Tacoma Community
Source: ANCEL.com
Understanding Drive Cycles and Readiness
- Catalyst monitor needs sustained highway speed (40-60 mph) to measure converter efficiency
- EVAP monitor needs the vehicle parked overnight (cold soak) then driven to check for vapor leaks
- Oxygen sensor monitor needs multiple cold starts and warm-up cycles
State-Specific Testing Requirements
Important Notes:
- Many states only require testing in certain counties (usually metro areas)
- Most states exempt vehicles under 3-5 years old from testing
- Some states require emission test when vehicle changes ownership
- Always verify current requirements with your local DMV or emission testing facility
Additional Information
Common Questions
- Gas cap is tight (replace if old/cracked)
- Fuel tank is between 1/4 and 3/4 full
- You've completed several cold-start highway drives
- No pending codes are preventing the monitor from running
Manual Pages Reference
- Primary content: Pages 518-519 (Emission inspection and I/M readiness)
- ToyotaNation.com (Toyota community forum)
- Tacoma4G.com (4th generation Tacoma forum)
- Smogtips.com (Emission testing specialist)
- Ohio eCheck (Government emission testing program)
- MotorVehicleMaintenance StackExchange (Technical Q&A)
- ANCEL.com (OBD tool manufacturer)
- TTORA (Tacoma community)
- JustSmogs.com (Smog testing service)
