2024+ 4th Gen Tacoma - Engine Coolant Level Check
Your T24A-FTS turbocharged engine generates serious heat. Over 1000°F at the turbo.
Proper coolant level is critical for keeping temperatures under control and preventing catastrophic engine damage. Here's how to check it safely and what you need to know about the pink Super Long Life Coolant your Tacoma uses.
(Reference: Owner's Manual, pg. 527-528, 616)
Engine Coolant Check, Coolant Level, Coolant Reservoir​
Check your engine coolant level regularly as part of routine maintenance, especially:
  • Before long trips
  • If the coolant temperature warning light illuminates
  • If you notice coolant puddles under the vehicle
  • During seasonal transitions (extreme cold or hot weather)
Important: Always check coolant level when the engine is COLD. Checking on a hot engine can result in inaccurate readings and poses safety risks.
Safety First​
Your cooling system holds pressure. Even when cold, there may be residual pressure. Here's what you need to know:
When the engine is hot:
Do not remove the coolant reservoir cap. The cooling system may be under pressure and can spray hot coolant if the cap is removed, causing serious burns. Also don't touch the radiator or intercooler. They stay hot long after you shut off the engine.
About the cooling fan:
With the engine switch in ON, the electric cooling fan may automatically start to run if the air conditioning is on and/or the coolant temperature is high. Make sure the engine switch is off when working near the electric cooling fan or radiator grille. The fan can keep running for a while even after the engine switch is off.
Step-by-Step Checking Procedure​
What You'll Need​
Tools Required:
  • None (visual inspection only for checking level)
Materials Needed (if adding coolant):
  • Toyota Super Long Life Coolant (SLLC), pink coolant
  • Clean funnel (if adding coolant)
Time Estimate: 2-3 minutes for checking, 5 minutes if adding coolant
Skill Level: Beginner-friendly
Locating the Coolant Reservoir​
The coolant reservoir is a translucent plastic tank in the engine compartment with level markings on the side. You can check the coolant level without opening the cap by looking through the plastic.
Reservoir Components:
  • Reservoir cap (with pressure relief valve)
  • "F" (Full) line: Upper level marking
  • "L" (Low) line: Lower level marking
The Checking Procedure​
Step 1: Park on Level Surface
Park your Tacoma on level ground to ensure an accurate reading. An uneven surface will give false high or low readings.
Step 2: Ensure Engine is Cold
The engine must be cold for accurate coolant level checking. If you've been driving:
  • Wait at least 30 minutes after shutting off the engine
  • Hood should be cool to the touch
  • Coolant temperature gauge should be at normal/cold range
Pro tip from the community: Check coolant in the morning before starting the engine for the first time that day. This ensures the engine is completely cold and provides the most consistent reading.
Source: TacomaWorld.com
Step 3: Open the Hood
Pull the hood release lever inside the cab, then release the safety latch at the front of the hood and lift.
Step 4: Visually Check Coolant Level
Locate the coolant reservoir (translucent tank) and observe the coolant level against the "F" and "L" markings on the side of the tank.
Normal Level: The coolant level is satisfactory if it's between the "F" and "L" lines on the reservoir when the engine is cold.
Acceptable Range:
  • Between "F" and "L" lines: Coolant level is good, no action needed
  • At or slightly below "L" line: Add coolant to bring level to "F" line
  • Significantly below "L" line: Add coolant AND investigate for leaks
If Coolant Level is Low: Adding Coolant​
Before opening the cap, review safety warnings above. The cooling system holds pressure even when cold.
Step 5: Remove Reservoir Cap (Engine MUST be cold)
Slowly turn the reservoir cap counterclockwise to relieve any residual pressure. Remove the cap completely.
Step 6: Add Toyota Super Long Life Coolant
Add coolant slowly until the level reaches the "F" line. Do not overfill.
Important about coolant: Coolant is neither plain water nor straight antifreeze. The correct mixture of water and antifreeze must be used to provide proper lubrication, corrosion protection and cooling. Be sure to read the antifreeze or coolant label.
Pro tip from the community: Fill to the MAX ("F") line when the engine is cold. As the cooling system goes through heat cycles, coolant will migrate between the radiator and reservoir. Filling to max when cold accounts for this and prevents needing frequent top-ups.
Step 7: Reinstall Cap and Check for Leaks
Tighten the reservoir cap securely. Start the engine and visually inspect for coolant leaks around the reservoir and hoses.
If you spill coolant: Be sure to wash it off with water to prevent it from damaging parts or paint.
Coolant Type and Specifications​
Toyota-Approved Coolant​
Required Coolant Type: "Toyota Super Long Life Coolant" or a similar high quality ethylene glycol based non-silicate, non-amine, non-nitrite, and non-borate coolant with long-life hybrid organic acid technology.
Coolant Mixture Ratios:
U.S.A.: "Toyota Super Long Life Coolant" is a mixture of 50% coolant and 50% deionized water. (Minimum temperature: -31°F [-35°C])
Canada: "Toyota Super Long Life Coolant" is a mixture of 55% coolant and 45% deionized water. (Minimum temperature: -44°F [-42°C])
Cooling System Capacity:
Total system capacity: 12.6 qt. (11.9 L, 10.5 Imp.qt.) for certain models OR 12.8 qt. (12.1 L, 10.6 Imp.qt.) for other models.
Why Toyota Super Long Life Coolant Matters​
Toyota engineers designed the 4th Gen Tacoma's T24A-FTS turbocharged engine with specific cooling requirements. The SLLC formulation:
  • Provides heat transfer for the intercooled turbo system
  • Protects aluminum engine components from corrosion
  • Maintains proper pH balance over extended service intervals
  • Compatible with the engine's coolant temperature sensors
DO NOT substitute with generic "universal" coolants or older-generation Toyota coolants (red or green). The hybrid organic acid technology (HOAT) in SLLC is specific to modern Toyota engines.
Toyota's pink Super Long Life Coolant uses HOAT (Hybrid Organic Acid Technology) that combines silicates and organic acids to fight corrosion. This formulation provides the extended 100,000 mile/10 year initial service interval. Don't mix with other coolant types as this can reduce the effectiveness of the corrosion inhibitors.
Source: Automotive Tech Info
Toyota Part Number 00272-SLLC2 is pre-mixed with deionized water at approximately 50% ethylene glycol concentration. This provides freeze protection to -31°F (-35°C) for USA spec. Don't dilute further. Always use the pre-mixed formula as-is.
Source: Toyota Official Parts Site
Troubleshooting: Coolant Level Drops Quickly​
If the coolant level drops within a short time of replenishing, visually check the radiator, hoses, engine coolant reservoir cap, drain cock and water pump.
If you can't find a leak, have your Toyota dealer test the cap and check for leaks in the cooling system.
What to Look For:
  • External leaks: Coolant puddles under vehicle, visible wet spots on hoses
  • Reservoir cap: Damaged seal or pressure relief valve failure
  • Radiator: Corrosion, impact damage, fin leaks
  • Hoses: Cracks, bulges, loose clamps
  • Water pump: Weep hole dripping (located on pump body)
  • Heater core: Sweet smell in cabin, wet passenger floor
When to Visit Toyota Dealer:
  • Coolant loss exceeds 1 quart between fill-ups
  • No visible external leaks found
  • Coolant appears contaminated (oil mixed in, rust particles)
  • Engine overheating occurs
4th Gen Tacoma Specific Issue: 2024 Model Coolant Bypass Hose Leaks​
Several early 2024 Tacoma owners reported slight coolant leaks from the coolant bypass hoses connected to the expansion tank (reservoir). Toyota identified this as a "manufacturing/assembly error, the contact between the pipe and rubber is not properly sealing."
The fix involves replacing the coolant bypass hose (top hose) and clamps on either end. These parts experienced nationwide stock shortages with extended wait times.
If you notice pink residue or slight wetness around the top hose connection to your reservoir, have your dealer inspect under warranty.
Source: Tacoma4G.com
Pro Tips from the Community​
Always wear safety goggles when working on coolant system
Even when cold, residual pressure can cause spray. Pink coolant stains and is difficult to remove from skin.
Check radiator first, then reservoir
A common mistake is only checking the reservoir without checking the radiator first. The correct procedure is: (1) Check radiator first when cold, fill to brim if needed, (2) Then check reservoir and fill to appropriate level. Checking only the reservoir can mask a low coolant condition.
Avoid confusion about cold vs hot fill levels
Coolant should be at LOWER line when cold and UPPER line when hot. Checking when warm (not fully hot or cold) leads to uncertainty about whether level is correct. Stick to checking when completely cold for consistency.
Watch for coolant color changes
If coolant turns brown or becomes colorless, this indicates contamination or breakdown requiring immediate fluid flush. If you notice an oily surface film in coolant, immediately have mechanic inspect for head gasket leakage.
How often should I check coolant level?
Toyota official recommendation: Check coolant level at every oil change interval (5,000-10,000 miles depending on driving conditions). For peace of mind, visual inspection every month is recommended, especially during the first 6 months of ownership, before and after off-road trips, and during summer months.
Can the 100,000 mile/10 year service interval be trusted?
Community feedback from owners with high-mileage Toyotas confirms that Toyota SLLC maintains its properties well beyond typical coolant service intervals. The extended interval is not marketing hype. The HOAT chemistry genuinely lasts. However, this assumes no contamination from leaks, no mixing with other coolant types, and proper cooling system maintenance (no overheating events).
Source: BobIsTheOilGuy.com
What if my coolant looks darker or cloudy?
Fresh Toyota SLLC is bright pink. Over time (80,000+ miles), it may darken to light brown (normal oxidation) or develop slight cloudiness (normal). Red flags: Rusty orange color = corrosion occurring (flush needed), milky appearance = oil contamination (head gasket concern), green tint = wrong coolant added (system flush required).
Recommended Products​
  • Toyota Genuine Super Long Life Coolant (Part #00272-SLLC2)
  • Safety goggles for coolant work
  • Clean funnel for adding coolant
Note: Using genuine Toyota SLLC eliminates any risk of compatibility issues and maintains warranty coverage. The pre-mixed formula is convenient and ensures correct concentration.
This thread synthesizes information from:
Pages 527-528: Coolant checking procedure, coolant type specification, safety warnings
Page 616: Cooling system capacity specifications
For the complete procedures and diagrams, consult these pages in your 2024+ Toyota Tacoma Owner's Manual (Document: OM04041U).
  • Primary procedure: Pages 527-528
  • Specifications: Page 616
  • Safety precautions: Page 528
  • TacomaWorld.com
  • Tacoma4G.com
  • Automotive Tech Info
  • Toyota Official Parts Site
  • BobIsTheOilGuy.com
This guide is derived from the official 2024+ Toyota Tacoma Owner's Manual with supplementary information from the owner community and authoritative sources. Always follow your official owner's manual for warranty compliance. This is a reference guide only.
