2024+ 4th Gen Tacoma - Fuel Pump Shut Off System
2024+ Tacoma - Fuel Pump Shut Off System: What It Is and How to Reset​
This thread expands on page 567 of your owner's manual, explaining the fuel pump shut off system - a collision safety feature that prevents fuel fires by automatically cutting fuel supply when your Tacoma detects a severe impact or engine stall.
What is the Fuel Pump Shut Off System?​
The 2024+ Tacoma's fuel pump shut off system is a collision safety feature designed to prevent fuel fires in emergencies. According to the owner's manual (page 567):
"To minimize the risk of fuel leakage when the engine stalls or when an airbag inflates upon collision, the fuel pump shut off system stops supply of fuel to the engine."
This system automatically intervenes in two specific scenarios:
  1. Engine Stall: When the engine RPM drops to zero unexpectedly while ignition is still ON
  2. Collision: When any airbag deploys (front, side, or curtain airbags)
When activated, the system cuts power to the fuel pump, eliminating the risk of fuel spraying onto hot engine components or accumulating under the vehicle. This is a critical fire prevention measure.
Why This System Exists​
Toyota includes this safety system across their vehicle lineup as a fire prevention measure. In a collision severe enough to deploy airbags, fuel system components may be damaged. Continuing to pump fuel through compromised lines creates extreme fire risk.
Similarly, when an engine stalls unexpectedly due to mechanical failure or severe impact, continuing fuel delivery without combustion can flood the engine bay with volatile gasoline vapors.
The fuel pump shutoff acts as an automatic circuit breaker for your fuel system.
When Does This Activate?​
Scenario 1: Collision-Based Activation
The system monitors airbag deployment signals. ANY airbag deployment (front, side, curtain) triggers the shutoff. The collision severity threshold matches the airbag deployment threshold, and activation is instantaneous with airbag inflation.
The fuel pump shutoff works in conjunction with Toyota's airbag system (SRS). Both systems share collision severity sensors to ensure consistent activation thresholds.
Scenario 2: Engine Stall Detection
When the engine RPM drops to zero unexpectedly while the ignition is still in the ON position, the ECU (Engine Control Unit) cuts power to the fuel pump. Common causes include:
  • Severe mechanical failure
  • Fuel starvation
  • Electrical fault
  • Severe off-road impact that stops the engine
Restarting Your Engine After Activation​
CRITICAL SAFETY CHECK (Page 567)​
Before attempting to restart your engine, the manual provides this important notice:
NOTICE
Before starting the engine
Inspect the ground under the vehicle.
If you find that fuel has leaked onto the ground, the fuel system has been damaged and is in need of repair. Do not restart the engine.
— Source: Owner's Manual page 567
Why This Inspection Matters​
If the system activated due to collision, fuel lines may be damaged. Restarting the pump without inspection risks:
  • Fuel spray onto hot exhaust components (fire hazard)
  • Fuel accumulation under vehicle (environmental hazard, fire risk)
  • Worsening fuel system damage
If You Find Fuel Leaking:
  1. Do NOT restart the engine
  2. Move away from the vehicle
  3. Call for emergency towing
  4. Contact Toyota dealer for fuel system inspection
Restart Procedure (Page 567)​
If NO fuel leak is detected, follow the official restart procedure from the owner's manual:
  1. Turn the engine switch to ACC or OFF.
    • This action resets the fuel pump shutoff circuit
    • ACC (Accessory) position is sufficient
    • OFF position also works and is recommended for safety
    • Wait 2-3 seconds in this position
  2. Restart the engine.
    • Turn ignition to START (push-button models: press with brake depressed)
    • Engine should start normally
    • Fuel pump resumes operation automatically
    • No warning lights should remain illuminated
The fuel pump shutoff system will reset automatically when you restart the engine. There is no manual reset button or procedure.
What to Expect:
  • Engine may crank slightly longer than usual on first restart (fuel system repriming)
  • This is normal - allow up to 5 seconds of cranking
  • Once started, engine should run normally
Troubleshooting: System Won't Reset​
If the engine won't start after following the restart procedure:
Check These First:
  1. Battery Condition: Collision may have damaged battery or cables
  2. Fuel Level: System activated due to fuel starvation (empty tank)
  3. Visible Damage: Collision damaged engine components beyond fuel system
If Multiple Restart Attempts Fail:
  • Do NOT continue cranking (risks starter motor damage)
  • Check for fuel leaks again (leak may not be immediately visible)
  • Check for any warning lights on the instrument cluster
  • Contact Toyota roadside assistance: 1-800-444-4195
When to Seek Toyota Dealer Service:
  • System activates repeatedly without collision or stall
  • Warning lights remain after restart
  • Engine starts but runs roughly
  • Any fuel odor detected
Integration with Toyota Safety Systems​
The 4th Gen Tacoma's Toyota Safety Sense (TSS) 3.0 system includes collision detection sensors that work in coordination with the fuel pump shutoff. When airbags deploy (triggered by collision severity sensors), the same signal activates the fuel shutoff.
This integration ensures consistent thresholds - if the collision is severe enough for airbags, it's severe enough to cut fuel supply.
The system is also part of Toyota's Star Safety System, which coordinates multiple post-collision actions including door unlock and hazard flasher activation.
Important Distinctions​
Collision Shutoff vs. Refueling Issues​
Many online discussions about "fuel pump shutting off" refer to EVAP system issues during refueling (gas pump nozzle clicking off prematurely). This is COMPLETELY DIFFERENT from the collision safety shutoff system.
Key Distinction:
  • Collision Shutoff (this topic): Emergency system, activates on collision/stall, requires manual restart
  • EVAP/Refueling Issues: Vapor recovery system, causes gas pump nozzle to click off early during refueling, unrelated to collision safety
Don't confuse these two different systems. If your gas pump nozzle keeps clicking off during refueling, that's an EVAP system issue, not the collision fuel shutoff.
Electronic Reset (4th Gen) vs. Physical Button (Older Generations)​
Older Toyota vehicles (including 3rd Gen Tacoma) had an "inertia fuel shutoff switch" - a physical button that needed to be pressed to reset after collision. This was typically located under the driver's side kick panel or near the glove box.
4th Gen Change: The 2024+ Tacoma uses an electronic reset system (turn ignition to ACC/OFF, then restart). The manual makes no mention of a physical reset button, suggesting Toyota moved to a fully electronic system.
Important: If experiencing activation issues on 4th Gen, follow the manual procedure (ignition cycle). Do not search for a physical button (may not exist on this generation).
Real-World Context​
Based on community forum research, most 4th Gen Tacoma owners never encounter this system. The limited discussion about the collision fuel shutoff suggests it works reliably in the background and users rarely experience activation. This is actually a good sign - the system only activates during significant collisions or severe mechanical failures.
Scenarios Where System May Activate:
  • Off-Road Impact: Hard landing from jump may trigger system if airbag threshold is met
  • Severe Pothole: System may activate from extreme impact
  • Minor Collision: Even minor collisions that deploy airbags will trigger shutoff
Post-Collision Note: Always perform fuel leak inspection, even if vehicle appears undamaged. Insurance claims often require professional fuel system inspection after airbag deployment.
This guide is based on the following page from your 2024+ Toyota Tacoma Owner's Manual:
Primary Content:
  • Page 567 - Fuel Pump Shut Off System (complete system description, activation triggers, restart procedure, safety notice)
  • Primary: Page 567 (System description, restart procedure, safety notice)
  • Tacoma4G.com - 4th Gen Tacoma community forum
  • TacomaWorld.com - Toyota Tacoma enthusiast community
  • Toyota Nation Forums - Multi-model Toyota community
  • 4GTaco.com - 4th Gen Tacoma forum
This guide is derived from the official 2024+ Toyota Tacoma Owner's Manual with supplementary information from the owner community and authoritative sources. Always follow your official owner's manual for warranty compliance. This is a reference guide only.
The fuel pump shutoff system is a safety feature. When in doubt, contact Toyota roadside assistance at 1-800-444-4195 or consult your Toyota dealer.
