2024+ 4th Gen Tacoma - Hitch Receiver & Trailer Ball Specifications
Getting your hitch and ball setup right isn't just about matching sizes. It's about ensuring the connection can handle your trailer's weight and sits at the proper height for level towing. Wrong ball size, insufficient thread engagement, or improper height means safety risks and potential equipment failure. Here's what you need to know about your 4th Gen Tacoma's hitch receiver position and how to select the right trailer ball.
(Reference: Owner's Manual, pg. 205-206)
Hitch Receiver Specifications, Trailer Ball Position, Towing Hitch Setup​
Pin Hole Position​
The pin hole position depends on your tire size:
Tire SizePin Hole Position
Except 265/70R1843.8 in. (1113 mm)
265/70R1844.9 in. (1141 mm)
Ball Position Height​
The ball mount height also depends on your tire size:
Tire SizeBall Position Height
Except 265/70R1850.2 in. (1276 mm)
265/70R1851.3 in. (1303 mm)
The 265/70R18 tire option (available on off-road trims) raises the hitch receiver position by approximately 1.1 inches compared to standard tire sizes. This affects both pin hole position and the ball mount height you'll need for level towing.
Trailer Ball Selection Requirements​
When selecting a trailer ball, all four specifications must match:
1. Ball Load Rating
Must match or exceed your trailer's gross trailer weight rating. If your trailer weighs 6000 lbs, your ball needs to be rated for at least 6000 lbs.
2. Shank Length
Must protrude beyond the bottom of the lock washer and nut at least 2 threads. This ensures the lock nut fully engages the threads under load. Insufficient thread engagement can cause ball separation under towing stress. Catastrophic failure.
3. Shank Diameter
Must match the ball mount hole diameter size. Common sizes are 3/4", 1", and 1-1/4". Verify your ball mount before purchasing a ball.
4. Ball Diameter
Must match the size of your trailer coupler. Most couplers are stamped with the required ball size (typically 1-7/8", 2", or 2-5/16").
Trailer Ball Size by Class​
Trailer ClassTypical Trailer Ball Size
Class IV2 5/16 in.
Class II and III2 in.
Class I1 7/8 in.
Why Ball Size Matters:
Using incorrect ball size creates a dangerous mismatch. A 2" ball on a Class IV setup rated for a 2-5/16" coupler means the coupler won't fully seat on the ball. The connection is loose and can separate. Always verify your trailer's coupler size before purchasing a ball.
Matching Ball Height to Coupler Height​
Your trailer ball setup must be at the proper height for the coupler on your trailer. The coupler and ball must align at the same height for level towing. Use an adjustable ball mount (with drop or rise) to achieve proper height.
Level towing means:
- Trailer sits parallel to the ground when connected
- Weight distributes properly to trailer axles
- Trailer tracks straight without nose-up or nose-down attitude
Hitch Installation and Maintenance​
About Aftermarket Hitches:
Toyota recommends using Toyota hitch/bracket assemblies for your truck. If installing an aftermarket hitch:
- Use only a hitch that conforms to your truck's gross trailer weight requirement
- Follow the hitch manufacturer's installation directions
- Don't install on the bumper (can cause body damage)
- Use only Toyota dealer-recommended mounting positions
Critical Hitch Safety:
Trailer hitch assemblies have different weight capacities set by the hitch manufacturer. Even though your Tacoma might physically handle more weight, never exceed the hitch's maximum weight rating. The hitch is the weak link if it's rated lower than your truck's towing capacity. Exceeding its rating can cause failure.
Lubrication:
Lubricate the hitch ball and kingpin with a light coating of grease. This reduces friction and wear, plus it helps the trailer coupler seat properly on the ball.
When Not Towing:
Remove the hitch ball when not towing a trailer. Consider removing the entire trailer hitch if you won't need it for extended periods, and seal any mounting holes in the vehicle body to prevent entry of substances into the vehicle.
4th Generation Tacoma Context​
The 2024+ Tacoma features Toyota's integrated hitch receiver on most trims, eliminating the need for dealer hitch installation in many cases. However, these specifications remain critical for:
Selecting Aftermarket Trailer Balls:
The trailer ball is NOT included with the factory hitch. You must purchase it separately based on your trailer's coupler size and weight rating.
Tire Size Impact on Height:
The 265/70R18 tire option raises the hitch receiver position by approximately 1.1 inches. If you're running these tires, you need to account for this when selecting your ball mount and calculating the drop/rise needed for level towing.
Ball Selection Safety:
The Class-based ball sizing table is your starting point, but always verify your specific trailer's coupler size before purchasing. A 2-5/16" ball is standard for Class IV (heavy trailers), but don't assume. Check the coupler stamp.
Why Toyota Recommends Toyota Hitch/Bracket:
While aftermarket hitches meeting TWR (Trailer Weight Rating) specifications are acceptable, Toyota-branded components are engineered specifically for the 4th gen Tacoma's frame mounting points and have undergone Toyota's testing protocols. They're designed to integrate with the truck's crash structure properly.
Recommended Products​
Towing Equipment:
  • 2 5/16" Trailer Ball (Class IV)
  • 2" Trailer Ball (Class II/III)
  • Adjustable Ball Mount with Drop/Rise
  • Trailer Ball Lock Nut Kit
  • Lithium Grease for Ball Lubrication
PDF Download: A combined PDF of manual pages 205-206 is available for download with this thread (pages-reference.pdf). This includes the original manual diagrams and complete specifications.
  • Hitch specifications and safety warnings: Page 205
  • Trailer ball requirements and position specifications: Page 206
This guide is derived from the official 2024+ Toyota Tacoma (4th Gen) Owner's Manual (OM04041U) with supplementary context from Toyota engineering specifications. Always follow your official owner's manual for warranty compliance. Towing capacity and hitch ratings vary by trim and equipment. Verify your specific vehicle's TWR (Trailer Weight Rating) before selecting towing equipment. This is a reference guide only.
Has anyone figured out to silence the seat...
Has anyone added fog lights to a 4th Gen SR...
Hey fellas, wanted to blast a photo out to...
I wanted to start a dedicated thread for...
A couple weeks ago I installed my new...
Here are a few shots of the SXTH exhaust tip...
Tired of slinging mud and rocks down the sides...
