Key fob losing range? Button presses not registering from more than a few feet away? Your battery is dying. Here's how to replace it in about 5 minutes with a flathead screwdriver.
(Reference: Owner's Manual, pg. 550-551)
If you notice these symptoms, your electronic key battery is depleted:
(Source: Page 550)
Keep Away from Kids
The CR2450 battery is small and button batteries are dangerous if swallowed. They can cause severe chemical burns in as little as 2 hours.
Keep new and used batteries away from children. If a battery is swallowed, get emergency medical attention immediately.
If the key fob cover won't close securely after replacing the battery, stop using the key and contact your Toyota dealer. A loose cover creates a safety risk if kids are around.
(Source: Page 551)
Use the Right Battery Type
The 4th Gen Tacoma uses CR2450 batteries specifically. Don't use CR2032 (from older generation key fobs) or any other type. Wrong batteries can explode or leak flammable gas.
(Source: Page 551)
Battery Type Required: Lithium battery CR2450
Tools Required:
Where to Purchase Battery:
Batteries can be purchased at your Toyota dealer, local electrical appliance shops or camera stores.
(Source: Page 550)
Important Note: Toyota recommends having your dealer perform this replacement, as the key may be damaged if the procedure is not performed properly. However, if you're comfortable with small electronics repair, this is a straightforward 5-minute DIY task.
Note for Card Key Owners: The battery for the card key is available only at your Toyota dealer. Your Toyota dealer can replace the battery for you.
(Source: Page 550)
Take out the mechanical key from the electronic key fob.
(Source: Page 551)
Remove the cover to access the battery compartment.
Pro Tip: Cover the tip of your flathead screwdriver with tape before prying. The plastic housing scratches easily, and tape provides a softer contact surface. Better yet, use the mechanical key slot if your fob has one. Gentler on the plastic.
(Source: Page 551)
Battery orientation is critical here. Installing it backwards will prevent the key from working and could damage the electronics. The "+" side faces up.
(Source: Page 551)
After reassembly, test the key fob functions:
Dispose of used batteries according to local laws.
(Source: Page 550)
Keep Your Key Fob Away from Your Phone
This is the most frequently reported issue in the 4th Gen community: keeping the key fob and phone in the same pocket or storage area causes parasitic draw and significantly reduces battery life. Even brief periods together will drain the battery faster. Electromagnetic interference from phones kills these batteries fast.
Source: 4GTaco.com, Tacoma4G.com forums
Don't Leave the Key Fob in Your Truck
Leaving the key fob inside the vehicle will drain the battery quickly due to constant communication with the truck's systems.
Source: 4GTaco.com
Consider Faraday Bags for Storage
Some owners use Faraday bags when storing the key fob at home to prevent constant pinging from the vehicle, extending battery life. This is particularly useful if you park in a garage near where you store keys.
Source: 4GTaco.com
Use the Hidden Key Slot Method
For easier disassembly without scratching: pull out the mechanical key and insert it into the slot specifically designed to open the case. This avoids prying with a screwdriver and is gentler on the plastic housing.
Source: YotaTech Forums
Using CR2032 Instead of CR2450
The 4th Gen Tacoma uses the less common CR2450 battery. The CR2032 (used in previous generation key fobs) won't work. It's thinner (3.2mm vs 5.0mm) and has different voltage characteristics. Make sure you buy CR2450.
Source: Community forums
Storing Phone and Key Fob Together
This is the number one cause of premature battery failure reported by 4th Gen owners. Don't do it.
Expecting 2-3 Year Battery Life
Many 4th Gen owners report batteries dying after only 3-9 months. This seems to be a widespread issue with 4th Gen key fobs, not user error. Set realistic expectations and keep spare batteries on hand.
Source: Multiple 4th Gen forums
CR2450 Availability Challenge
The CR2450 battery is less common than the CR2032 used in previous generation Toyota key fobs. Many owners report being unable to find CR2450 batteries in grocery stores. Plan ahead and purchase from Toyota dealerships, electronics stores (Best Buy, etc.), camera shops, or online retailers.
4th Gen Battery Life Issue
There's a widespread battery life issue specific to the 4th Gen (2024+) Tacoma key fobs. Multiple forum threads report unexpectedly short battery life (3-9 months) compared to previous generations. Having a spare battery in your glovebox is recommended.
Low Battery Warning May Not Appear
Some owners report not seeing the expected low battery warning on the dashboard display, despite the manual suggesting one should appear. Don't rely on the warning. If your key fob range decreases, replace the battery immediately.
Why Cover the Screwdriver with Tape?
The plastic housing of the Toyota electronic key is easily scratched and can crack if pried with excessive force. Tape protects the finish and provides a softer contact surface.
Why Toyota Recommends Dealer Service
While this is a straightforward DIY task, Toyota's disclaimer protects them from liability if the key fob housing is cracked during disassembly. If you're comfortable with small electronics repair, this is an easy 5-minute job. If you're hesitant, Toyota dealers charge $10-15 for this service.
Given the shorter-than-expected battery life in 4th Gen key fobs (3-9 months reported by owners), consider purchasing batteries in bulk:
This guide synthesizes information from your owner's manual:
Primary Pages:
A downloadable PDF of these exact pages will be attached to this thread for your reference.
This guide is derived from the official 2024+ Toyota Tacoma Owner's Manual (OM04041U) with supplementary information from the owner community and established Toyota enthusiast forums. Always follow your official owner's manual for warranty compliance. This is a reference guide only.
Key Fob Battery Replacement, Replace Fob Battery, Smart Key Battery
- The smart key system and wireless remote control will not function properly
- The operational range will be reduced
(Source: Page 550)
Important Safety Notes
Keep Away from Kids
(Source: Page 551)
(Source: Page 551)
What You'll Need
Tools Required:
- Flathead screwdriver
- Small flathead screwdriver
(Source: Page 550)
(Source: Page 550)
Step-by-Step Battery Replacement
Step 1: Remove the Mechanical Key
(Source: Page 551)
Step 2: Remove the Key Fob Cover
(Source: Page 551)
Step 3: Replace the Battery
- Remove the depleted battery from the compartment
- Insert a new battery with the "+" terminal facing UP
- Ensure the positive (+) side is visible when properly installed
(Source: Page 551)
Step 4: Reassemble the Key Fob
- Replace the cover, ensuring it snaps firmly into place
- Verify the cover is securely closed
- Reinsert the mechanical key
Step 5: Test the Key Fob
- Lock/unlock buttons should work at normal range (30+ feet)
- Smart key system should recognize the key
- Touch sensor on door handle should work
- If functions still don't work, the battery may not be seated flat (reopen and check)
Battery Disposal
(Source: Page 550)
Tips from Tacoma Owners
Source: 4GTaco.com
Source: 4GTaco.com
What You Need to Know
Recommended Products
- Lithium CR2450 batteries (4-pack or more for cost savings)
- Faraday bag for key fob storage (optional, for those experiencing rapid battery drain)
Manual Pages Reference
Primary Pages:
- Pages 550-551: Key fob battery replacement procedure, tools, battery type, safety warnings
- Primary procedure: Pages 550-551
- 4GTaco.com
- Tacoma4G.com
- TacomaWorld.com
- YotaTech Forums
