2024+ 4th Gen Tacoma - Opening the Hood
Whether you're checking oil, topping off fluids, or just getting familiar with your new Tacoma, here's how to open the hood properly and what you'll find under there. The 4th Gen uses a two-stage release system (interior pull + exterior latch) that keeps the hood from popping open on the highway.
(Reference: Owner's Manual, pg. 522-524)
Hood Release, Hood Latch, Opening Hood​
Your Tacoma has a two-stage hood release to prevent accidental opening while driving. The hood can be positioned at two different heights depending on what you're working on.
Step 1: Interior Release​
  1. Find the hood release lever inside (driver's side, low on the left side of the dashboard)
  2. Pull the lever. You'll hear the latch pop and the hood will lift slightly
Step 2: Exterior Auxiliary Catch​
  1. Move to the front of your truck
  2. Reach under the slightly raised hood at the center front
  3. Push the auxiliary catch lever to the left and lift the hood
Step 3: Secure the Hood Open​
You have two support rod positions:
Standard Opening:
Insert the rod into the standard slot for routine checks (oil, coolant, washer fluid). This is enough for most maintenance and puts less stress on the hood hinges.
Wider Opening:
Insert the rod into the wider opening slot when you need maximum clearance. Helpful for accessing brake fluid, battery terminals, or working near the firewall.
Before you start working:
  • Verify the support rod is firmly seated in the slot
  • The cooling fan may keep running for a few minutes after you shut off the engine. Wait for it to stop before reaching into the engine bay. Those blades spin fast and can catch you off guard.
Closing the Hood​
  1. Remove the support rod from the hood slot
  2. Important: Return the support rod to its clip. Closing the hood with the rod still up will bend the hood
  3. Lower the hood until it's about 12 inches above the latch
  4. Release and let it drop to engage the lock (it needs that momentum to latch properly)
  5. Verify closure: Pull up gently on the front edge to confirm the hood is locked
Before you drive, check that the hood is fully closed and locked.
If it's not latched properly, it can open while you're moving. That's a safety issue you don't want to deal with at highway speeds.
Engine Compartment Overview​
Once the hood is open, here's what you'll find:
Fluids and Reservoirs:
  • Engine oil filler cap (center, marked with oil can symbol)
  • Engine oil level dipstick (right side)
  • Engine coolant reservoir (left side)
  • Brake fluid reservoir (left rear, near firewall)
  • Washer fluid tank (left front)
Electrical:
  • Battery (right side, covered)
  • Fuse boxes (multiple locations)
Cooling System Components:
  • Engine radiator (front)
  • Cooling fan (behind radiator)
  • Intercooler (turbocharged 4-cylinder engine, cools compressed air)
  • Condenser (air conditioning system)
Your owner's manual has a detailed diagram showing exact locations with reference page numbers for each system.
Real-World Tips & 4th Gen Context​
Hood Drop Height for Proper Latching
To properly close your hood, release it from about 12-20 inches above the latch (not gently lowering it all the way). Some owners need to drop from about 20 inches to get tight latches to engage. The hood is designed to drop from this height to build enough momentum for the latch to catch.
Source: Tacoma4G.com
Hood Sensor Awareness
The instrument cluster stays on when the hood is open on 2024+ models. Be mindful that the battery is drawing power. Avoid leaving the hood open for extended periods without starting the engine.
Source: Tacoma4G.com community observations
Latch Adjustment for Early 2024 Models
Early 2024 Tacoma owners reported hood latches that wouldn't close or were excessively tight after first opening. Toyota dealers can adjust the latch mechanism quickly (usually under warranty). If your hood requires more than about 20 inches of drop height to latch, or won't latch at all, schedule a service appointment.
Source: Tacoma4G.com community discussion
Gently Lowering Hood to Close
Some owners try to slowly lower the hood all the way to the latch. This fails with 4th Gen Tacomas due to tight factory latch settings. The hood needs to drop from about 12 inches to build enough momentum for the latch to engage.
Why it matters: An improperly latched hood can open while driving
Forcing Stuck Auxiliary Catch
If the auxiliary catch lever (second release under the hood) is stuck, don't force it. Stiff latches on brand new trucks may require dealer adjustment if excessive force is needed. Toyota may have set latches intentionally tight to prevent hood shake, but overly tight latches could indicate misalignment.
Why it matters: Forcing the catch can bend the release mechanism or damage the hood latch assembly
Why Two Hood Support Positions?​
Toyota included dual support rod positions for different maintenance scenarios:
Standard Opening:
  • Enough for most routine checks (oil, coolant, washer fluid)
  • Less hood travel means less stress on the hood hinges
  • Easier for shorter users to reach the support rod slot
Wider Opening:
  • Maximum access to firewall-area components (brake fluid, battery terminals, cabin air filter)
  • Better clearance when working with bulky tools
  • Useful for accessing engine components on the turbocharged T24A-FTS (intercooler service, intake components)
Pro Tips​
Best Practice for Closure Verification
After closing the hood, stand at the center front and push down firmly with both hands. If you hear a click or the hood moves downward, it wasn't fully latched. Repeat the closing procedure.
Cold Weather Note
The auxiliary catch lever may be stiffer in cold weather. Don't force it. Warm the metal slightly with your hand or push firmly while sliding left.
Cooling Fan Awareness
The T24A-FTS turbocharged engine runs hot. The electric cooling fan has a temperature-based controller that may continue running for several minutes after shutdown, especially after highway driving or hot weather operation.
Wait for the fan to stop before reaching into the engine bay.
Hood Alignment Check
If your hood doesn't close smoothly or sits unevenly when latched, the rubber hood stops (small rubber bumpers on the fender/radiator support) may need adjustment. See your Toyota dealer for proper adjustment.
High Lift Jack Positioning​
For off-road recovery or trail repairs, your Tacoma includes designated high lift jack points on the frame rail. This is a reinforced section designed to handle the lifting force of a high-lift style jack.
Safety Requirements:
  • Follow the instructions in the manual provided with the jack
  • Position the jack correctly (improper placement can damage your vehicle or cause injury)
Note: This is different from the standard jacking points used with a floor jack for tire changes. High-lift jacks are primarily for off-road/trail use, not routine maintenance.
Q: What if my hood won't latch on the first try?
A: Don't force it closed. Lift it back up about 12-20 inches and let it drop. The latch needs momentum to engage properly. If it still won't latch after 2-3 tries, check that the support rod was returned to its clip and that nothing is obstructing the latch mechanism.
Q: Why does my hood feel so tight compared to my old truck?
A: Toyota may have intentionally set 4th Gen latches tighter than previous generations to eliminate hood shake/flutter at highway speeds. The turbocharged T24A-FTS engine and updated front-end aerodynamics may have changed hood dynamics compared to the 3rd Gen.
Q: Can I use the wider opening position for all maintenance?
A: Yes, but it puts slightly more stress on the hood hinges. Use the standard position for quick checks (oil, coolant, washer fluid) and save the wider opening for tasks that require better access to the firewall area.
Q: What should I do if I hear the cooling fan running after I turn off the engine?
A: This is normal. The electric cooling fan may continue operating for several minutes after shutdown to cool the turbocharger and engine. Wait for it to stop before working near the fan blades.
This thread synthesizes information from:
Pages 522-523: Complete hood opening and closing procedure
Page 523: High lift jack positioning
Page 524: Engine compartment component diagram and references
For the complete procedures and diagrams, consult these pages in your 2024+ Toyota Tacoma Owner's Manual (Document: OM04041U).
  • Primary procedure: Pages 522-523
  • Engine compartment overview: Page 524
  • High lift jack points: Page 523
  • Tacoma4G.com (4th Gen Tacoma owner community)
This guide is derived from the official 2024 Toyota Tacoma Owner's Manual (OM04041U) with supplementary information from the owner community. Always follow your official owner's manual for warranty compliance. This is a reference guide only.
