2024+ 4th Gen Tacoma - SRS Airbag & ABS Warning Lights
Your SRS airbag and ABS warning lights monitor safety-critical systems. While both are yellow/amber warnings (not the most urgent red), they still require immediate dealer inspection. Here's what these warnings mean and why they matter.
(Reference: Owner's Manual, pg. 569-570, 576)
Airbag Light, SRS Warning, ABS Light On, Airbag Malfunction, ABS Malfunction​
What It Looks Like:
Standard SRS airbag icon on your instrument cluster (amber/yellow color) with warning buzzer
What It Means:
Indicates a malfunction in the SRS airbag system or the seat belt pretensioner system. Have the vehicle inspected by your Toyota dealer immediately.
Why This Matters:
One or more airbags may not inflate in the event of a collision. While it's possible that all airbags could work as intended even with an SRS warning light, a failure in the airbags is a significant safety concern.
Proceed carefully to the service center right away when this light comes on.
SRS System Components Monitored:
The SRS warning light monitors an extensive component network:
  • Airbag sensor assembly
  • Front impact sensors
  • Side impact sensors (front door and rear)
  • Front passenger occupant classification sensors
  • Driver's seat position sensor
  • Seat belt buckle switches
  • "AIR BAG ON" and "AIR BAG OFF" indicator lights
  • Seat belt pretensioners and force limiters
  • SRS airbags
  • SRS system wiring harnesses and power sources
Any malfunction in this network will trigger the SRS warning light.
ABS Warning Light​
What It Looks Like:
"ABS" text indicator on your instrument cluster (amber/yellow color) with warning buzzer
What It Means:
Indicates a malfunction in the ABS or the brake assist system. Have the vehicle inspected by your Toyota dealer immediately.
What Happens When ABS Fails:
  • Your basic braking function remains operational
  • However, the anti-lock braking feature is disabled
  • In emergency stops, wheels may lock (pre-ABS behavior)
  • Brake assist system (which provides additional braking force in panic stops) is also affected
Important Distinction:
The ABS Warning Light (amber) indicates an ABS system malfunction, but basic brakes still work. This is different from the Brake System Warning Light (red), which is a critical brake system issue and a separate warning entirely.
If both the red brake system warning and the ABS warning lights illuminate together, this is a more serious condition requiring immediate attention.
4th Gen Tacoma Context: TNGA-F Platform Integration​
The 2024+ Tacoma (4th generation, TNGA-F platform) integrates SRS and ABS systems more deeply with other vehicle systems than previous generations:
SRS System Integration:
  • Works with Toyota Safety Sense 3.0 (TSS 3.0) for pre-collision deployment decisions
  • Seat belt pretensioners fire before airbags in detected crashes
  • Front passenger occupant classification system determines airbag deployment force
  • Driver's seat position sensor calibrates airbag deployment timing
ABS System Integration:
  • Foundation for Vehicle Stability Control (VSC)
  • Feeds data to Multi-Terrain Select (MTS) system
  • Supports Crawl Control and Downhill Assist Control (DAC) operation
  • Integrates with Pre-Collision System (PCS) braking
What this means: An ABS malfunction doesn't just disable anti-lock braking. It may also affect off-road systems (Crawl Control, DAC) and advanced safety features (PCS). Similarly, SRS issues can indicate problems with TSS 3.0 integration.
TSB and Recall Status​
TSB Status: No widespread Technical Service Bulletins addressing SRS airbag warning lights or ABS warning lights have been identified in publicly available databases for 2024-2025 Tacoma models. Dealers may have access to internal bulletins not in public databases.
Brake System Recall Status: While no recalls exist for ABS control modules or SRS airbag warning light malfunctions, there is an active brake-related recall (Recall 25V-058 for brake hose damage affecting about 222,000 4th gen Tacomas).
What This Means:
The limited TSB activity suggests:
  • These warning light issues are not occurring frequently enough to warrant systematic bulletins
  • Any issues that do occur are being handled case-by-case under warranty
  • The platform may be too new (launched 2024) for patterns to emerge
Owners experiencing persistent SRS or ABS warnings should still have their vehicles inspected, as individual component failures can occur even without widespread TSB patterns.
Important Brake Recall (Not ABS System)​
While no SRS/ABS recalls exist, there is a major brake-related recall:
Recall 25V-058 (Toyota 25TB04/25TA04) - Brake Hose Damage
  • Affected: 2024-2025 Tacoma 2WD/4WD models with specific wheel/brake configurations
  • Issue: Rear brake hoses can be damaged by mud/dirt buildup, causing brake fluid leaks
  • Remedy: Dealer replacement of both rear brake hoses (no charge)
Key distinction: This recall addresses physical brake hose damage that can cause fluid leaks, not ABS control module failures or ABS warning light malfunctions.
Check your VIN: Visit toyota.com/recall or nhtsa.gov/recalls to verify if this recall affects your specific vehicle.
Common Causes​
The 4th gen Tacoma is too new to have accumulated significant diagnostic pattern data. Most available troubleshooting information applies to previous generations. However, general Toyota/Tacoma diagnostic patterns include:
Common ABS Warning Light Causes:
  • Wheel speed sensor failures (most common)
  • Low brake fluid level
  • Tire pressure differential (underinflated tire spins faster, triggers speed sensor fault)
  • Common diagnostic trouble codes: C0035, C0040, C0041, C0045 (wheel speed circuit malfunctions)
Common SRS Airbag Warning Light Causes:
  • Defective airbag sensor
  • Damaged clock spring in steering wheel
  • Seatbelt pretensioner issues
  • Sensor/wiring problems in the 13-component network
Note: These causes are synthesized from owner forum discussions spanning different Tacoma generations and have not been confirmed specific to 4th gen through official sources.
Grille Shutter Electrical Connection:
While not directly SRS/ABS related, some 2024 Tacoma owners have reported broader electrical system issues. Multiple owners have reported complete system shutdowns possibly related to front grille shutters, throwing various warning messages. Dealers are replacing the grille shutter and changing the wiring harness.
Relevance: If your SRS or ABS warning lights appear alongside other electrical symptoms (multiple warning lights, system shutdowns, check engine light), ask your dealer about grille shutter system inspection. This may indicate broader electrical issues rather than isolated SRS/ABS component failures.
Warranty Coverage​
Both SRS and ABS systems are covered under factory warranty for new 4th gen Tacomas:
SRS Airbag System Warranty:
  • 5 years or 60,000 miles
  • Covered under Powertrain Coverage Warranty
  • Includes seatbelts and airbags
ABS System Warranty:
  • 3 years or 36,000 miles
  • Covered under bumper-to-bumper warranty
  • Electronic safety components coverage
Warranty escalation: If dealer denies warranty coverage, escalate to Toyota customer service: 800-331-4331
What To Do When Warning Lights Illuminate​
For SRS Airbag Warning Light:
Immediate actions:
  1. Proceed carefully and directly to authorized Toyota dealer
  2. Do not delay. Airbags may not function in collision
  3. Avoid high-risk driving situations until diagnosis complete
At dealer:
  1. Request complete diagnostic scan with Toyota TechStream
  2. Obtain written documentation of all diagnostic trouble codes (DTCs)
  3. Verify repair will be covered under 5yr/60K mile SRS warranty
  4. If warranty denied, escalate to Toyota customer service
Follow-up:
  1. Keep all service records
  2. If issue recurs, document pattern with dates and circumstances
  3. Monitor owner forums for similar reports
  4. Consider reporting to NHTSA if pattern suggests safety defect
For ABS Warning Light:
Simple checks before dealer visit:
  1. Check brake fluid level (visible through reservoir, should be between MIN and MAX lines)
  2. Verify all tires properly inflated to door placard specs (underinflated tire can trigger ABS light)
  3. Check if brake hose recall (25V-058) has been completed on your VIN
Immediate actions:
  1. Schedule dealer diagnostic appointment
  2. Drive cautiously with increased following distance
  3. Anticipate normal braking without anti-lock function
  4. Avoid emergency braking situations if possible
At dealer:
  1. Request TechStream diagnostic scan
  2. Verify simple causes checked (brake fluid, tire pressures)
  3. Verify repair covered under 3yr/36K mile bumper-to-bumper warranty
What You Cannot Do​
For SRS Warning Light:
  • Cannot diagnose with generic OBD-II scanner (requires Toyota diagnostic system)
  • Cannot reset by disconnecting battery (fault codes are protected, will return)
  • Cannot ignore (compromises crash protection)
  • DIY airbag component replacement not recommended (high-voltage system, deployment risk)
  • Cannot safely use advanced driving features (Crawl Control, DAC may be disabled)
  • Generic OBD-II scanners may miss ABS codes (Toyota Techstream or equivalent required)
  • Ignoring reduces emergency braking effectiveness (brake assist disabled)
Dealer Diagnostic Tools​
Toyota TechStream: Toyota's dealer-level diagnostic platform with capabilities including:
  • SRS function resets airbag data to clear collision fault indicator after repair
  • ABS scanner repairs ABS pump system and performs brake bleeding
  • Read and clear diagnostic trouble codes
  • Perform system tests and calibrations
Aftermarket scan tools exist but dealer-level diagnosis is recommended for safety-critical SRS/ABS systems.
Normal vs. Abnormal Behavior​
Normal Behavior (Not a Problem):
At engine start: Both lights illuminate briefly during system self-test. This is normal. The systems are performing diagnostics. Lights extinguish within 5-7 seconds after engine start.
Abnormal Behavior (Indicates Malfunction):
  • Light stays on after engine start (system detected fault, dealer scan required)
  • Light comes on while driving (system detected fault during operation, pull over safely and assess)
Why Immediate Dealer Inspection Matters​
For SRS System:
  • The SRS system is safety-critical (it deploys airbags in a crash)
  • A malfunction may mean airbags won't deploy when needed
  • Alternatively, a fault could cause unintended deployment
  • DIY diagnosis is not recommended (dealer-level scan tools required)
  • Warranty coverage may apply for SRS repairs (5yr/60K miles)
For ABS System:
  • Modern ABS integrates with other safety systems (VSC, traction control, TSS)
  • Malfunction codes must be read with Toyota diagnostic equipment
  • ABS sensor issues vs. control module failures require different repairs
  • Brake assist system loss reduces emergency braking effectiveness
  • Warranty coverage may apply for ABS repairs (3yr/36K miles)
Manual Reference​
Owner's Manual: Pages 569, 570, 576
  • Toyota Warranty Documentation
  • NHTSA
  • Car and Driver
  • Edmunds
  • Consumer Affairs
  • Tacoma4G.com
  • TacomaWorld.com
  • ToyotaNation.com
  • 4Runner Forum
This guide is derived from the official 2024-2025 Toyota Tacoma Owner's Manual with supplementary information from authoritative sources and the owner community. Always follow your official owner's manual for warranty compliance. Safety-critical repairs should be performed by authorized Toyota dealers. This is a reference guide only.
