2024+ 4th Gen Tacoma - Starting Engine with Dead Key Fob
When your electronic key fob battery is depleted, Toyota's Smart Key System provides an emergency start procedure that allows you to start your Tacoma without replacing the battery immediately.
Here's how to get back on the road. Plus how to replace the battery when you can.
(Reference: Owner's Manual, pg. 127, 550, 598-599)
Dead Key Fob, Key Battery Replacement, Emergency Start, CR2450 Battery, Smart Key​
Symptoms of depleted electronic key battery:
  • Smart key system and wireless remote control will not function properly
  • Operational range is reduced
  • Doors don't unlock when approaching vehicle
  • Engine start button doesn't respond
Before assuming battery failure:
Verify these settings first:
  • Smart key system has not been deactivated in customization settings
  • Battery-saving mode is not activated
  • Communication between key and vehicle is not interrupted
Emergency Door Access with Mechanical Key​
Extracting the Mechanical Key:
  1. Electronic key: Slide the release lever and take the key out
  2. Card key (if equipped): Push the release button and take the key out
Key Orientation: The mechanical key can only be inserted in one direction, as the key only has grooves on one side. If the key cannot be inserted in a lock cylinder, turn it over and re-attempt to insert it.
Unlocking Doors with Mechanical Key:
  1. Insert mechanical key into driver's door lock cylinder
  2. Turn key once to unlock driver's door only
  3. Turn key again to unlock remaining doors and tailgate
Important Note: Using the mechanical key to lock the doors will not set the alarm system. If a door is unlocked using the mechanical key when the alarm system is set, the alarm may be triggered.
Emergency Engine Starting Procedure​
Once inside the vehicle, follow these steps to start the engine with a dead key fob battery.
For Vehicles with Automatic Transmission:
  1. Prepare Vehicle:
    • Ensure shift lever is in P (Park)
    • Depress the brake pedal fully
  2. Activate Emergency Key Recognition:
    • Touch the Toyota emblem side of the electronic key to the engine switch
    • When the electronic key is detected, a buzzer sounds and the engine switch will turn to ON
    • Note: When the smart key system is deactivated in customization setting, the engine switch will turn to ACC mode instead
  3. Verify System Ready:
    • Firmly depress the brake pedal
    • Check that the engine start symbol is shown on the multi-information display
  4. Start Engine:
    • Press the engine switch shortly and firmly
    • Engine should start normally
For Vehicles with Manual Transmission:
  1. Prepare Vehicle:
    • Ensure shift lever is in N (Neutral)
    • Depress the clutch pedal fully
    • Firmly depress the clutch pedal
  4. Start Engine:
If Engine Still Cannot Be Started:
In the event that the engine still cannot be started after following the procedure above, contact your Toyota dealer.
Stopping the Engine:
  1. Shift lever to P (automatic transmission) or N (manual transmission)
  2. Set the parking brake
  3. Press the engine switch as you normally do when stopping the engine
Battery Replacement Solution​
The emergency start procedure described above is a temporary measure. Replace the electronic key battery immediately when the battery is depleted.
Battery Type: CR2450 lithium battery
Tools Required:
  • Flathead screwdriver
  • Small flathead screwdriver
Where to Purchase:
  • Toyota dealer
  • Local electrical appliance shops
  • Camera stores
  • Online retailers
Toyota Dealer Recommendation:
As the key may be damaged if the battery replacement procedure is not performed properly, it is recommended that key battery replacement be performed by your Toyota dealer.
For Card Key (if equipped):
The battery for the card key is available only at your Toyota dealer. Your Toyota dealer can replace the battery for you.
Battery Disposal:
Dispose of used batteries according to local regulations regarding battery disposal.
Tips from the Community​
Emergency Start Technique:
When battery is weak, hold the back side of the fob (with Toyota emblem) directly against the push button start. Depress brake and push start button while holding fob as close as possible. The weak battery signal can still reach when in direct contact.
Source: Tacoma4G.com
Keep Key Fob Away from Cell Phones:
Some owners report reduced battery life when storing fob with cell phones in the same pocket, though experts debate whether RF interference is the actual cause. To be safe, avoid storing fob and phone in same pocket, center console tray, or purse compartment.
Store Key Fob Out of Range When Not Using Vehicle:
Leaving fob inside truck or very close to it causes constant polling/communication. This dramatically shortens battery life (reports of less than 1 year when left in vehicle). Store spare keys away from vehicle, not in glove box or center console.
Source: TacomaWorld.com
Buy CR2450 Batteries in Multi-Packs:
CR2450 is less common than CR2032. Not all grocery/convenience stores carry it. Having spare batteries at home prevents emergency trips to dealer or specialty store.
2024 Card-Style Key Fob Easy Battery Access:
Press small circular button to remove mechanical key, then pinch the end to slide off battery cover. Much easier than older fob designs requiring screwdriver prying.
Leaving spare key fob inside vehicle or very close to it:
Constant communication/polling drains battery rapidly. One owner reported battery death in less than 1 year from this. Spare keys should be stored in house, away from garage if truck is parked there.
Risk: Premature battery failure
Using incorrect battery or low-quality batteries:
CR2450 required (NOT CR2032 which is more common). CR2450 is thicker and higher capacity. CR2032 won't make proper contact. Low-quality batteries may not provide necessary voltage consistently.
Risk: Fob won't work even with "new" battery
Not checking battery contacts after replacement:
Bent or dirty contacts prevent proper battery connection. Can cause fob to appear "dead" even with new battery. Check contacts are clean and properly aligned before reassembly.
Risk: Fob won't work after battery replacement
Battery Life Expectations​
Some 2024 Tacomas came with weak/dead batteries from factory:
Multiple owners report brand new trucks arriving with dead or dying key fob batteries. One 2024 Hybrid Limited owner reported battery death after just 1.5 months. This is not abnormal. Batteries sit on shelf before installation.
Normal battery life: 1-2 years with proper use:
If fob is used normally (not stored with phone or in vehicle), expect 1-2 years. Shorter lifespan (6-9 months) indicates one of the common mistakes above. Heavy remote start users may see shorter life due to increased usage.
Mechanical key may trigger alarm. This is normal:
Some 2024 owners report alarm activates when unlocking with mechanical key. This is intentional security feature: alarm was armed, mechanical key bypasses it. To avoid: Unlock with fob before battery fully dies, or disable alarm first.
No reprogramming needed after simple battery replacement:
Fob retains programming during battery swap. Only time reprogramming is needed: if battery was out for extended period (weeks). If fob doesn't work after replacement, check battery orientation and contacts first.
How Long Can You Drive on Emergency Start?​
You can drive indefinitely using the emergency start method, but:
  • You must repeat the touch procedure for every engine start
  • Remote key functions (unlock from distance, panic button) won't work
  • Some convenience features may be unavailable
  • Eventually the battery will be completely dead (can't even backup start)
Best Practice: Replace the battery within 1-2 days of first needing emergency start procedure.
Why CR2450 Specifically?​
Toyota specifies CR2450 lithium batteries for the electronic key because:
  • Higher capacity than smaller coin cells (620 mAh)
  • 3V voltage matches Smart Key System requirements
  • Temperature stability (-30°C to +60°C operational range)
  • Long shelf life (up to 10 years unused)
DO NOT substitute with:
  • CR2032 (too thin, won't make proper contact)
  • CR2025 (too thin, insufficient capacity)
  • Generic "equivalent" batteries (may have voltage variance)
Q: Why does this emergency procedure work?
A: Toyota's Smart Key System uses two communication methods: long-range wireless (normal operation) requiring adequate battery voltage, and short-range backup (emergency) using near-field communication. When battery voltage drops too low for wireless operation, the backup system still functions because direct contact requires minimal power.
Q: What reduces battery life?
A: Frequent use of remote start (if equipped), storing key near metal objects (causes continuous authentication attempts), extreme temperatures (very hot or cold environments), and physical proximity to strong magnetic fields all reduce battery life.
Q: How can I extend battery life?
A: Use battery-saving mode when not driving for extended periods, don't store spare keys inside vehicle (causes continuous polling), keep fob away from cell phones, and replace proactively every 2 years rather than waiting for failure.
Q: When should I seek dealer service?
A: If emergency start procedure fails even with new battery, if key fob was physically damaged (dropped, water exposure), if multiple electronic keys all failing simultaneously (suggests vehicle-side issue), or if smart key system was recently deactivated and won't reactivate.
When using the mechanical key:
Operate the power window or the moon roof after checking to make sure that there is no possibility of any passenger having any of their body parts caught in the window or the moon roof. Also, do not allow children to operate the mechanical key. It is possible for children and other passengers to get caught in the power window or the moon roof.
In case of smart key system malfunction:
Take your vehicle with all the electronic keys provided with your vehicle (including the card key) to your Toyota dealer.
Manual Reference​
Owner's Manual: Pages 598-599, 127, 550
  • Tacoma4G.com (4th Gen Tacoma community forum)
  • 4GTaco.com (4th Gen Tacoma enthusiast forum)
  • TacomaWorld.com (General Tacoma community)
  • ToyotaNation.com (Toyota owner forums)
  • Haynes Manuals (Automotive repair reference)
This guide is derived from the official 2024+ Toyota Tacoma Owner's Manual (OM04041U) with supplementary information from the owner community and authoritative sources. Always follow your official owner's manual for warranty compliance. This is a reference guide only and does not replace professional service or official Toyota documentation. Verify all procedures and specifications against your specific vehicle's owner's manual before performing any work.
