2024+ 4th Gen Tacoma - Tire Pressure Warning Light (TPMS)
Proper tire pressure affects safety, ride comfort, tire life, and fuel economy. Your Tacoma's TPMS monitors pressure automatically, but understanding how to troubleshoot TPMS warnings (and knowing the difference between a blinking light and a solid one) can save you unnecessary dealer visits.
(Reference: Owner's Manual, pg. 574, 576)
TPMS Light, Tire Pressure Warning, Low Tire Pressure, TPMS Reset, Tire Sensor​
Your 4th gen Tacoma uses two distinct warning patterns that tell you exactly what's wrong:
PATTERN 1: Light BLINKS for about 1 minute, then stays on
  • Meaning: Malfunction in the tire pressure warning system
  • Action: Have the vehicle inspected by your Toyota dealer immediately
PATTERN 2: Light comes ON solid (no blinking)
  • Meaning: Low tire inflation pressure (natural causes or flat tire)
  • Action: Stop the vehicle in a safe place and check your tires
The key difference: Blinking = system malfunction requiring dealer service. Solid = low pressure you can troubleshoot yourself.
DIY Troubleshooting (Solid Warning Light Only)​
If your TPMS light came on solid (did not blink first), follow this procedure:
Step 1: Visual Tire Inspection
Look for:
  • Visibly flat tire (sidewall bulging, obvious deflation)
  • Foreign objects in tread (nails, screws, road debris)
  • Sidewall damage (cuts, bulges, punctures)
  • Valve stem damage
If you find a puncture, reference the flat tire change procedure (Page 585).
Step 2: Engine Switch Diagnostic Test
Turn the engine switch off, then turn it to ON. Check if the tire pressure warning light comes on or blinks.
  • Light blinks for about 1 minute then stays on: System malfunction. Stop DIY troubleshooting and have the vehicle inspected by your Toyota dealer immediately.
  • Light comes on solid (no blinking): Confirmed low tire pressure. Continue to Step 3.
Step 3: Allow Tires to Cool (CRITICAL)
Tire pressure is highly temperature-sensitive. For every 10°F change in temperature, tire pressure changes by 1-2 PSI. If you've been driving (especially highway speeds or with heavy load), tire friction has heated the tires and increased pressure above cold specification.
Best practice:
  • Check tire pressure in the morning before first drive (cold tire condition)
  • Light came on while driving? Park for 30-60 minutes and allow tires to return to ambient temperature
  • Must check immediately? Add 2-3 PSI to account for heat, then re-check when cold
Step 4: Check and Adjust Tire Pressure to Specification
Tools required:
  • Tire pressure gauge (digital recommended for accuracy)
  • Air compressor or access to gas station air
Procedure:
  1. Locate door jamb placard (driver's side B-pillar) with cold tire pressure specifications
  2. Remove valve stem cap from first tire
  3. Press gauge firmly onto valve stem and read PSI value
  4. Compare to door jamb specification (not tire sidewall max pressure)
  5. Repeat for all four tires. Check every tire even if only one triggered TPMS
  6. Add air to reach specified PSI if low, or release air if overinflated
  7. Replace valve stem caps on all tires
The 4th gen Tacoma often has different front vs rear tire pressure specifications due to weight distribution.
Always follow your door jamb placard exactly.
Step 5: Verify TPMS Light Turns Off
After adjusting pressure to specified levels, drive the vehicle for several minutes. The TPMS light should turn off within 5-10 minutes of driving as the system re-reads sensor data and verifies all tires are at proper pressure.
Light turns off? Issue resolved. Monitor tire pressure weekly to catch slow leaks early.
Light doesn't turn off? Check that the inflation pressure of each tire is at the specified level and perform initialization (Page 537).
Understanding "Natural Causes" TPMS Activation​
Temperature-Induced Pressure Changes (Most Common)
Fall/winter cold snaps are the most common natural cause. Tire pressure drops about 1 PSI for every 10°F temperature decrease.
Real-world scenario:
  • Overnight temperature drops from 70°F to 40°F (30°F change)
  • Tire pressure drops 3 PSI due to temperature alone
  • If tires were at 32 PSI, they're now at 29 PSI
  • TPMS threshold (around 20-25% below spec) may be exceeded
  • Light illuminates at cold start
  • As you drive and tires warm from friction, pressure increases and the light may turn off mid-drive
This is confusing but normal. However, you should still add air to reach cold specification. Don't ignore the light assuming it's "just cold weather."
Gradual Air Loss (Normal Permeation)
Tire rubber is semi-permeable. Air molecules slowly diffuse through sidewalls at a rate of 1-2 PSI per month. If you don't check tire pressure for 3-4 months, natural permeation alone can trigger TPMS.
Check tire pressure monthly with a quality gauge. Don't rely on TPMS as your only pressure monitoring. It's a warning system for significant pressure loss, not a maintenance reminder.
Altitude Changes
Driving from sea level to mountain passes can trigger TPMS as atmospheric pressure decreases and the TPMS sensor reading changes relative to atmosphere.
When to Visit Toyota Dealer vs DIY Resolution​
Dealer-Required Scenarios:
  • TPMS light blinks about 1 minute then stays on (system malfunction)
  • TPMS light won't turn off after proper inflation and driving and initialization
  • Recent tire service at non-Toyota facility (sensors may need re-registration)
  • Tire pressure correct but light behavior is erratic
DIY-Appropriate Scenarios:
  • Light comes on solid during cold weather snap (temperature-induced pressure drop)
  • Light comes on after not checking pressure for months (natural permeation)
  • You knowingly aired down for off-roading (re-inflate to spec and perform initialization)
  • Light comes on after visual inspection shows no puncture
4th Gen-Specific TPMS Issues​
Issue #1: Incorrect TPMS Threshold Settings (Dealer Delivery Problem)
A very common cause of false TPMS warnings on 4th gen Tacoma is incorrect threshold configuration in the instrument cluster, not defective sensors or actual low pressure.
The pattern:
  • Dealers deliver 4th gen Tacomas with tires inflated to 40-50 PSI (shipping/transport pressure)
  • TPMS threshold is set to 35 PSI in instrument cluster
  • Door placard specifies 30-32 PSI (proper operating pressure)
  • When owners correctly adjust tires to 30 PSI per door placard, TPMS triggers warning because cluster threshold remains at 35 PSI
Owner experience from Tacoma4G.com:
"Door sticker says somewhere around 30psi...instrument cluster was set at 35psi. It caused a low pressure warning in cold weather."
"Dealership had it at 40psi...Then I brought it down to 30psi per the door sticker and it triggered a warning."
The 4th gen Tacoma features adjustable TPMS warning thresholds accessible through the Multi-Information Display (MID) settings. Before suspecting sensor failure, check TPMS settings in your instrument cluster and verify the threshold matches your door placard recommendation.
If your truck is recently dealer-delivered (within first 1,000 miles) and pressures are correct but TPMS shows "low pressure" warning, return to dealer for TPMS threshold reprogramming (free under warranty).
Issue #2: Dual Wheel Set Registration (NEW 4th Gen Feature)
Unlike the 3rd gen Tacoma, the 2024+ 4th gen can register two complete sets of TPMS sensors, allowing seamless switching between summer and winter wheel sets without reprogramming each time.
This feature allows:
  • Registration of primary wheel set (stock wheels with all-season tires)
  • Registration of secondary wheel set (aftermarket wheels with winter or off-road tires)
  • Switching between sets via Multi-Information Display menu
The process can be quirky and may require dealer assistance for initial setup, but once both sets are registered, switching is straightforward.
Issue #3: TPMS Display Persistence Firmware Bug
Known 4th gen issue (as of November 2025): The TPMS display setting (showing live pressure values for all four tires on instrument cluster) does not persist after vehicle restart. Even if you select TPMS to display on the instrument cluster, turning off the truck causes it to be replaced by another gauge or blank screen at next startup.
Important clarification: This firmware glitch affects the display of live pressure values only, not the warning light functionality.
Your TPMS warning light will still illuminate properly when pressure is low or system malfunction occurs.
Workaround: None effective. You must manually re-select TPMS display each time you start the vehicle.
TPMS Sensor Battery Life​
TPMS sensors contain non-replaceable lithium batteries with a lifespan of 7-10 years. Your 2024-2025 Tacoma's sensors should last until around 2031-2034.
Premature "sensor failure" diagnoses within the first 3 years are almost always configuration errors (incorrect threshold settings), not hardware failures.
If a dealer recommends sensor replacement on your 2024-2025 Tacoma within warranty period, verify:
  1. Light blinks for about 1 minute before staying on (true sensor failure pattern)
  2. Dealer performed Techstream diagnostic confirming sensor battery low/dead
  3. Issue covered under 36-month/36,000-mile basic warranty (should be no-charge)
Warranty Coverage and Replacement Costs​
TPMS sensors are covered under the 36-month/36,000-mile basic New Vehicle Limited Warranty. TPMS sensor failures within this period should be covered at no cost.
Replacement Cost Expectations (After Warranty):
Aftermarket pricing:
  • Individual sensors: About $40 each
  • Complete 4-sensor set: $130-$160
  • Labor for replacement: $50-$150
  • Total aftermarket cost: $210-$310 for complete 4-sensor replacement
OEM dealer pricing (estimated):
  • OEM Toyota sensors: Around $65-$100 each
  • Dealer labor: $100-$150
  • Estimated total: $360-$550 for complete 4-sensor OEM replacement
TPMS Reset and Initialization​
When initialization is required:
  • After adjusting tire pressure and light doesn't turn off after driving
  • After installing new TPMS sensors
  • After switching between dual wheel sets (4th gen feature)
  • After airing down for off-road use and re-inflating
Important: Tire rotation does not always require TPMS reprogramming. The TPMS sensors automatically communicate new wheel positions to the ECU after rotation. Re-registration is only required when sensors are physically replaced or swapped between different wheel sets.
Complete initialization procedure is on Page 537 of your owner's manual.
4th Gen Tacoma Hybrid-Specific Warning​
CRITICAL for Hybrid owners: If you disconnect the 12V battery on a 4th gen Tacoma Hybrid model, you must take the vehicle back to the dealer for ECU reboot. The traditional DIY "battery disconnect to clear codes" method is not safe for hybrid models and will create additional system errors requiring dealer intervention.
Q: Can I ignore the TPMS light if I know my pressure is correct?
A: No. The light indicates either low tire pressure requiring immediate attention or TPMS system malfunction requiring dealer diagnosis. Ignoring the light means you lose the safety benefit of pressure monitoring. If pressure is truly correct and the light persists, follow the initialization procedure (Page 537). If the light still won't turn off, dealer service is required.
Q: The light turned on during a cold morning but turned off after 10 minutes of driving. Is this normal?
A: Yes, this is the "natural causes" temperature scenario. Cold overnight temperatures dropped tire pressure below TPMS threshold. As you drove, tire friction warmed the tires, pressure increased back above threshold, and the light turned off. However, this indicates your cold tire pressure is borderline low. Add air to reach proper cold specification (door jamb placard) to prevent repeated morning TPMS warnings.
Q: Does the spare tire under my truck bed have a TPMS sensor?
A: Most 4th gen Tacoma configurations do not include a TPMS sensor in the spare tire. When you install the spare after a flat, the TPMS light will blink then stay on because the system detects only 3 of 4 sensors. This is expected behavior. After repairing or replacing the punctured tire and re-installing it, the light should turn off (may require initialization).
Q: I'm airing down for off-roading. Will the TPMS light come on?
A: Yes. Airing down to 15-20 PSI for trail traction will trigger TPMS warning. This is expected and safe in off-road context at low speeds.
Critical: Re-inflate to proper specification before returning to paved roads and highway speeds. Underinflated tires at highway speed create excessive heat and risk tire failure. Perform TPMS initialization after re-inflation (Page 537).
Bonus tip: The 4th gen's adjustable TPMS threshold feature allows you to temporarily set the threshold to 20 PSI during off-road trips to prevent nuisance warnings, then reset to normal threshold (30-35 PSI) for street driving.
Manual Reference​
Owner's Manual: Pages 574, 576, 537, 585
  • Tacoma4G.com
  • TacomaWorld.com
  • ATEQ-TPMS.com
  • TPMSDirect.com
  • Modern Tire Dealer
  • 4Runner Forum
This guide is derived from the official 2024 Toyota Tacoma Owner's Manual with supplementary information from the 4th gen Tacoma owner community. Always follow your official owner's manual for warranty compliance and safety. This is a reference guide only.
SELLING OEM TRD OFF ROAD HEADLIGHT SET...
5% all around! 50% on the windshield. Came out...
Proud owner of a pedestrian 25 SR5 2wd Taco...
Howdy folks, I picked up my first new vehicle...
Hey Y'all, As we all know, the 4th Gen...
