2024+ 4th Gen Tacoma - Towing Your Vehicle (Emergency Towing)
Breakdown on the highway? Dead battery in a parking lot? When your Tacoma can't drive itself, you need to know the right way to get it home without causing damage.
Here's what you need to know about towing your truck safely.
(Reference: Owner's Manual, pg. 563-565)
Key Topics Covered:
  • Professional towing methods (flatbed, wheel-lift, dolly)
  • Critical safety warnings for 2WD and 4WD models
  • Emergency towing procedure (last resort only)
  • Speed and distance limitations
  • Damage prevention guidelines
Towing, Flatbed Tow, Tow Dolly, Tow Hook Location, Emergency Towing​
If your Tacoma won't move under its own power, call your Toyota dealer or a commercial towing service.
Call before attempting any towing if:
  • The engine runs but the vehicle doesn't move
  • You hear abnormal sounds from the transmission
These symptoms could indicate serious transmission or drivetrain issues. Moving the vehicle in this condition can turn a fixable problem into thousands in damage. Even for emergency towing.
The Critical Rule: All Four Wheels Must Be Raised​
Here's the most important thing to understand: your Tacoma must be towed with all four wheels off the ground. 2WD or 4WD, doesn't matter.
Why this matters:
2WD Models:
Your truck's driveshaft connects the transmission to the rear differential. If the rear wheels are on the ground while being towed, the driveshaft rotates without the transmission providing lubrication. This causes catastrophic transmission damage. We're talking complete failure.
4WD Models:
The 4WD system includes a transfer case that distributes power to both axles. Even with the transfer case in neutral, towing with wheels on the ground can damage the transfer case internals, front differential, and axle bearings. The drivetrain wasn't designed for unpowered rotation.
Toyota's engineering team didn't make this requirement on a whim. Ignoring it voids your warranty and leads to expensive repairs.
Professional Towing Methods​
Method 1: Flatbed Truck (Best Option)​
A flatbed truck is the safest way to transport your Tacoma. All four wheels are off the ground, eliminating any risk of drivetrain damage. Works for both 2WD and 4WD models.
Flatbed Procedure:
  1. Tow operator uses tire strapping belts to secure the vehicle
  2. Set the parking brake before transport
  3. Turn the engine switch OFF
  4. Follow the flatbed operator's manual for proper tire strapping
Method 2: Wheel-Lift Type Truck​
A wheel-lift truck raises either the front or rear wheels while the opposite wheels stay on the ground.
For your Tacoma: You need all four wheels raised off the ground. If the tow service only has a wheel-lift truck, they'll need to use dollies under the wheels that would otherwise touch the ground.
Important wheel-lift precautions:
  • Don't tow from the rear when the engine switch is off. The steering lock mechanism isn't strong enough to hold the front wheels straight.
  • Check ground clearance at the end opposite the lift, or you'll scrape the truck while being towed
Method 3: Dolly Towing​
If your Tacoma must be towed using a dolly, here are the configurations:
Towing from the front:
  • Use a towing dolly under the REAR wheels
  • Front wheels will be on the ground, steered by tow truck
Towing from the rear:
  • Use a towing dolly under the FRONT wheels
  • Rear wheels will be on the ground
Required for all towing: Always use a safety chain system and follow all state, provincial, and local laws.
Don't Use: Sling-Type Trucks​
Sling-type tow trucks use chains or straps under the front or rear bumper. This can damage your Tacoma's body panels and undercarriage components.
Tell the tow operator not to use this method.
Emergency Towing (Last Resort Only)​
If a professional tow truck isn't available and you're stuck in an emergency, you can temporarily tow your truck using cables or chains attached to the emergency towing eyelets. Last resort only. Hard surfaced roads.
Critical Limitations​
Distance: 50 miles (80 km) maximum
Speed: Under 18 mph (30 km/h)
Surface: Hard surfaced roads only
Why these limits exist:
  • Transmission lubrication: The automatic transmission pump only works when the engine runs. Emergency towing creates minimal fluid circulation, risking overheating and damage.
  • Brake system: Your Tacoma uses vacuum-assisted brakes. With the engine off, you only get 2-3 brake applications with full power before the vacuum depletes.
  • Power steering: Electric power steering doesn't function with the engine off. Steering gets extremely difficult.
These are engineering maximums, not recommendations. Shorter distance and slower speed means less risk.
Requirements for Emergency Towing​
  • A driver MUST be in the vehicle to steer and operate the brakes
  • The vehicle's wheels, drivetrain, axles, steering, and brakes must be in good condition
  • For automatic transmission models: Only the front towing eyelets may be used
Emergency Towing Steps​
  1. Attach Towing Cables/Chains
    Connect the towing cables or chains firmly to the designated towing hooks on your Tacoma. Be careful to avoid contact with body panels during attachment.
    Tow Hook Configurations:
    Type A (see manual page 565 diagram)
    Type B (see manual page 565 diagram)
  2. Enter Vehicle and Start Engine
    Get into the vehicle that will be towed and attempt to start the engine. If it won't start, turn the engine switch to the ON position at minimum.
  3. Configure 4WD System (4WD Models Only)
    Move the front-wheel drive control switch to the "2H" setting.
    This ensures the transfer case is in rear-wheel-drive mode, preventing drivetrain damage during emergency towing.
Roadside Assistance Services​
AAA Membership:
AAA membership includes emergency towing service with the following coverage:
  • Up to 4 roadside assistance events per year
  • Towing distance varies by membership tier (Basic/Plus/Premier)
  • Additional mileage cost: Varies by region ($3-7 per mile beyond free tier limit)
  • Average response time: AAA has the fastest response time at 35 minutes (JD Power study)
AAA vs. ToyotaCare Roadside Assistance:
Some 4th Gen Tacoma owners report preferring AAA membership over Toyota's included roadside assistance. Better response times, wider network of service providers, and more flexible coverage options.
Note: Toyota vehicles include complimentary ToyotaCare with 24-hour roadside assistance coverage (2-3 years with unlimited mileage, varies by model). ToyotaCare also includes complimentary maintenance for 2 years/25,000 miles. Check your owner's manual warranty section for specific coverage details.
Q: Can I tow my 4WD Tacoma with just the front or rear wheels raised?
A: No. All four wheels must be raised off the ground for both 2WD and 4WD models. Towing with any wheels on the ground will cause drivetrain damage.
Q: Why does the manual specify front towing eyelets only for automatic transmissions?
A: The rear towing eyelets are positioned near the rear differential. Using them with an automatic transmission during emergency towing creates risk of driveshaft and transmission damage. Front eyelets ensure the drivetrain rotates in the correct direction.
Q: What if I need to be towed more than 50 miles?
A: Use professional flatbed towing. The 50-mile limitation is for emergency cable/chain towing only. Professional flatbed trucks can transport your Tacoma any distance safely.
Q: Can I flat-tow my 4WD Tacoma behind an RV?
A: No. The manual does not permit flat towing (all four wheels on ground while being towed). This would cause severe drivetrain damage. Use a flatbed trailer or tow dolly with proper configuration.
Manual Reference​
Owner's Manual: Pages 563-565
  • AAA Roadside Assistance (aaa.com)
  • ToyotaNation.com (AAA vs ToyotaCare discussion)
This guide is derived from the official 2024+ Toyota Tacoma Owner's Manual (OM04041U) with supplementary information from roadside assistance providers and the Toyota owner community. Always follow your official owner's manual for warranty compliance. For emergency situations, contact your Toyota dealer or a commercial towing service. This is a reference guide only and does not replace professional towing services.
When in doubt about proper towing procedures, contact a professional towing service to avoid drivetrain damage and ensure safe transport of your vehicle.
