2024+ 4th Gen Tacoma - Trailer Driving Assist (TDA) Features
The 4th gen Tacoma's Trailer Driving Assist (TDA) system automatically adjusts driver assistance features when you're towing. Instead of manually disabling each safety system, TDA recognizes when you have a trailer and adjusts how various features behave to account for the trailer's presence. This is a new feature for 2024+ Tacomas that wasn't available on 3rd gen models.
(Reference: Owner's Manual, pg. 301-302, 311)
Trailer Driving Assist, TDA Feature, Trailer Sway Control​
TDA adjusts certain driver assist settings to support towing functionality. It's recommended to use a genuine Toyota Trailer Brake Controller (TBC) when towing.
What TDA Does:
Rather than forcing you to manually disable each driver assistance feature when towing, TDA recognizes when you're towing a trailer and automatically adjusts how various safety systems behave. This is Toyota's intelligent approach to making towing safer by preventing system-induced trailer sway or jackknifing.
Important limitations: This system helps but has its limits. Don't rely on it too heavily. You're still responsible for being aware of your surroundings and driving safely. Towing without a genuine Toyota Trailer Brake Controller (if equipped) increases the risk of vehicle and trailer instability.
How TDA Activates​
TDA operates when any of the following conditions are met:
  1. Via 7-pin Trailer Brake Connector: When towing a trailer connected to a genuine Toyota Trailer Brake Controller (TBC)
  2. Via BSM (Blind Spot Monitor) Auto-Detection: When BSM detects a connected trailer
When a trailer is detected, a message appears on the multi-information display. Enable the function according to the instructions on the display.
Auto Trailer Detection (ATD) Details​
Detection via BSM Sensors:
When you confirm a trailer is detected by pressing "YES" to the meter pop-up, the detection area extends to a maximum length of about 50 ft. (15m) from the rear bumper.
ATD Requirements:
  • For BSM detection without 7-pin connector: Vehicle should be moving forward at speed above 0.6 mph (1 km/h) for at least 10 seconds
  • ATD function triggers at every engine start, when the vehicle is stopped and the shift lever is in P or N, or the parking brake is set for more than 90 seconds
Detection Delays:
Trailer detection via BSM sensors can be delayed if you're in a crowded environment. Busy parking lots, areas surrounded with trees (camping ground), or environments with objects that prevent sensors from detecting the trailer will cause delays.
Driver Assist Features Modified by TDA​
When TDA is operating, driver assistance features are limited as shown below:
Features That REMAIN AVAILABLE When Towing:
  • AHB (Automatic High Beam) (P.235)
  • RSA (Road Sign Assist) (P.281) [if equipped]
  • Dynamic Radar Cruise Control (P.284)
Features PARTIALLY UNAVAILABLE When Towing:
  • PCS (Pre-Collision System) (P.253) - See specific modifications below
  • Intuitive Parking Assist (P.316) [if equipped]
Features NOT AVAILABLE When Towing:
  • LTA (Lane Tracing Assist) (P.264)
  • LDA (Lane Departure Alert) (P.269) [Alert only available except for Puerto Rico, A.Samoa and New Caledonia]
  • PDA (Proactive Driving Assist) (P.275) [if equipped]
  • Emergency Driving Stop System (P.298) [if equipped]
  • PKSB (Parking Support Brake) (P.332) [if equipped]
  • Parking Support Brake Function (static objects) (P.337) [if equipped]
  • RCD (Rear Camera Detection) (P.328) [if equipped]
  • RCTA (Rear Cross Traffic Alert) (P.322) [if equipped]
PCS (Pre-Collision System) Specific Modifications​
The following PCS functions are disabled when a trailer is detected:
  • Moderate braking for pre-collision warning
  • Acceleration suppression at low speed (vehicles with automatic transmission)
  • Emergency steering assist
  • Intersection collision avoidance support (left/right turn)
Why These Are Disabled:
The added weight and length of a trailer fundamentally changes your vehicle's braking dynamics and turning radius.
Emergency braking or steering interventions that work for the truck alone could cause trailer sway or jackknifing when towing. TDA disables these aggressive interventions to prevent system-induced instability.
Advanced TDA Features​
Trailer Length Detection (TLD)​
Once a trailer is detected and if the trailer length in the meter is selected as "Auto", the TLD function estimates the trailer length using the Blind Spot Monitor sensors.
How to Activate TLD:
To estimate the trailer length with TLD function and detection area, make at least two 90 degree turns.
Manual Override:
If you enter the trailer length manually via the multi-information display, the detection area is also adjusted to exceed the length of the trailer.
Trailer Merge Warning (TMW)​
When towing a trailer, the blind spot system uses input from ATD and TLD to modify the detection zone to match the trailer. TMW will alert via the indicators on the outside mirrors when a vehicle in an adjacent lane enters the modified detection zone.
TMW Limitations:
Depending on some combinations of trailer types, trailer dimensions, and bumper types, TMW performance can be degraded.
Real-World Tips from the Community​
Best Practice: Test TDA Cancellation After First Unhook
After disconnecting a trailer for the first time, drive forward about 20 feet then back up the same distance. This triggers the "Trailer Detected YES OR NO" prompt. Select "NO" to properly cancel TDA mode and restore all safety features.
Source: Tacoma4G.com community
Tip: Use Ball-Only Method to Trigger Prompt
If stuck in TDA mode without a trailer, connect trailer to hitch ball (without plugging in electronics). Drive for about 10 seconds to trigger the trailer detection prompt, then select "NO" when asked.
Source: 4GTaco.com forum
Prevention: Always Confirm "NO" When Unhooking
The only way to properly cancel trailer assist is by selecting "NO" when the "Trailer Detected?" prompt appears.
If you unhook and park without backing up to trigger this prompt, the system can remain in trailer mode.
Source: 4thgentacoma.com community
Maintenance: Keep BSM Sensors Clean
BSM sensors are located on the inside left and right of the rear bumper. Dirty sensors cause false detections or prevent trailer detection. Clean regularly, especially after off-road trips.
Known Issues​
"Ghost Trailer" Detection Issue
The 4th gen Tacoma's Auto Trailer Detection via BSM has a known issue where the system continues detecting a trailer after disconnection. This is widespread enough that Toyota issued Technical Service Bulletin T-SB-0084-24 on September 30, 2024.
The TSB Fix:
The bulletin addresses the issue where the "Trailer Driving Assist Active Message" is displayed without a trailer connected. The fix involves reprogramming both BSM sensors with updated software.
Source: Toyota TSB T-SB-0084-24
Impact on Safety Features:
When the system incorrectly detects a trailer, it turns off lane-keeping assist, emergency steering assist, and other safety features. Understanding this helps explain why "stuck in trailer mode" is problematic. You're driving without these safety systems until properly cancelled.
Mistake: Unhooking Trailer Without Triggering the Cancellation Prompt
If you disconnect a trailer and park immediately without backing up to trigger the "Trailer Detected?" prompt, TDA can remain active. This disables lane-keeping assist, emergency steering, and other safety features until properly cancelled.
Mistake: Assuming Trailer Mode Will Auto-Cancel
Some owners drove 15+ minutes expecting TDA to realize no trailer was connected.
The system requires explicit "NO" confirmation via the multi-information display prompt. It won't auto-cancel.
Mistake: Not Knowing About TSB T-SB-0084-24 When Experiencing Persistent Issues
If simple workarounds don't resolve stuck trailer mode, your truck likely needs the TSB software update at the dealer. This isn't a DIY fix. It requires BSM sensor reprogramming.
Integration with Trailer Profiles​
TDA works in conjunction with the Tacoma's trailer profile system (Pages 103, 112, 311). When you save a trailer profile via the multi-information display, TDA can automatically activate when that trailer is detected, either through the 7-pin connector or BSM sensors.
Official Manual Pages for This Topic:
  • Pages 301-302: TDA overview, function availability table, operating conditions
  • Page 311: Auto Trailer Detection (ATD), Trailer Length Detection (TLD), Trailer Merge Warning (TMW)
For complete towing procedures and safety information, see Page 198 of your owner's manual.
  • TDA overview and function table: Pages 301-302
  • Auto Trailer Detection details: Page 311
  • Toyota Technical Service Bulletin T-SB-0084-24
  • Tacoma4G.com
  • 4GTaco.com
  • 4thgentacoma.com
This guide is derived from the official 2024+ Toyota Tacoma Owner's Manual (OM04041U) with supplementary information from the owner community and Toyota technical service bulletins. Always follow your official owner's manual for warranty compliance. This is a reference guide only.
SELLING OEM TRD OFF ROAD HEADLIGHT SET...
5% all around! 50% on the windshield. Came out...
Proud owner of a pedestrian 25 SR5 2wd Taco...
Howdy folks, I picked up my first new vehicle...
