Towing with your Tacoma? That little TOW/HAUL button changes everything. It keeps your transmission from hunting for gears, gives you better engine braking on descents, and smooths out throttle response when you're hauling weight. Here's when to use it and what it actually does.
(Reference: Owner's Manual, pg. 220, 403)
TOW/HAUL mode is a transmission control feature designed for towing trailers or hauling heavy loads. When you activate it, your Tacoma changes how the engine, transmission, and steering respond to be more suitable for pulling a trailer.
This isn't the same as your drive mode selector (ECO, SPORT, COMFORT). TOW/HAUL is dedicated towing work. It modifies shift patterns to reduce transmission hunting, provides better engine braking on descents, and adjusts throttle response for smooth trailer control.
Activate TOW/HAUL mode when:
Location: TOW/HAUL switch (center console area, near drive mode select)
Activation Procedure:
Simple on/off operation with instant feedback via the indicator light.
When TOW/HAUL mode activates, your Tacoma's 8-speed automatic transmission modifies its behavior:
Transmission Shift Strategy:
Engine Response:
Steering Feel:
TOW/HAUL mode automatically deactivates under these conditions:
1. When 4L (Four-Wheel Low) is engaged
4L has its own transmission programming for extreme off-road and recovery situations. TOW/HAUL is incompatible with 4L operation.
2. When Driving Mode Select OR Multi-Terrain Select (MTS) is activated
Drive Mode Select modes (ECO, SPORT, COMFORT, SPORT S, SPORT S+, CUSTOM) have their own transmission and engine strategies. Multi-Terrain Select modes (Mud & Sand, Loose Rock, Mogul, etc.) override TOW/HAUL.
Only one system can control transmission behavior at a time.
Note: TOW/HAUL works fine with 2H (Two-Wheel High) or 4H (Four-Wheel High). It's the drive mode select and MTS systems that conflict with it.
Understanding how TOW/HAUL fits into the Tacoma's multiple drive systems:
The Drive Mode Select switch offers:
Drive Mode Select operates when: Front-wheel drive control switch is in 2H or 4H
TOW/HAUL operates when: 2H or 4H only (automatically deactivates when 4L is engaged)
Practical takeaway: TOW/HAUL and Drive Mode Select are mutually exclusive. Choose one or the other based on your current need.
Your Tacoma also has an "ECT PWR" switch that selects power mode for when high levels of response are desirable, like mountain driving.
When to use which:
Both help with mountain driving, but TOW/HAUL is calibrated for trailer stability while ECT PWR is calibrated for driver enjoyment.
Engage TOW/HAUL before starting to tow, not mid-drive
Activate the mode before you start your towing trip for best transmission programming from the start. Some users report the system works best when engaged from the beginning rather than switching mid-route.
Use firm brake tap on descents for controlled downshifts
When descending hills with TOW/HAUL mode active, give the brakes a firm tap to kick the transmission down a gear or two. Engine braking provides extra restraint, reducing the need to ride the brakes continuously.
Source: Edmunds professional automotive publication
TOW/HAUL can actually improve fuel economy when towing
Counterintuitively, some users report fuel economy improved from 21 MPG to 22 MPG when using TOW/HAUL mode with a loaded trailer. The theory: preventing engine lugging (lower RPM under heavy load) by holding gears longer actually uses less fuel than letting the transmission hunt for higher gears.
Source: Tacoma4G community forum
RPMs stay closer to 2000 RPM in TOW/HAUL mode
Expect the tachometer to hover around 2000 RPM more consistently in TOW/HAUL mode. This is ideal for the turbo 4-cylinder's power band when towing.
TOW/HAUL reconfigures blind-spot monitoring for trailer
When TOW/HAUL mode is active, the blind-spot monitoring system automatically accounts for the trailer, extending the detection zone. Helpful integrated safety feature.
Don't expect it to work like the old V6
The 4th Gen Tacoma's turbo 4-cylinder with 8-speed transmission behaves differently than the 3rd Gen's V6. TOW/HAUL mode is calibrated for the new powertrain. Expect different shift feel and RPM ranges.
Why it matters: Some 3rd Gen owners initially dislike the 4th Gen TOW/HAUL behavior because they expect V6 characteristics. Understanding it's a different system helps set proper expectations.
Don't confuse TOW/HAUL with ECT PWR mode
TOW/HAUL is for towing/hauling. ECT PWR (power mode) is for spirited driving. Some users activate the wrong mode. They have different transmission strategies and shouldn't be used interchangeably.
Why it matters: Using ECT PWR while towing doesn't provide the engine braking and shift logic that TOW/HAUL offers. Use the right mode for the job.
Don't be alarmed by noticeable forward lurch during downshifts
TOW/HAUL mode causes more aggressive downshifts than normal mode. Some users report feeling a noticeable forward lurch when the transmission downshifts.
This is normal behavior for TOW/HAUL mode, not a malfunction.
Why it matters: Prevents unnecessary dealer visits for "transmission issues" that are actually correct TOW/HAUL operation.
4th Gen towing feel now on par with best in class
Professional reviewers note: "The 2024 Toyota Tacoma's overall towing feel and confidence is now on par with the best in the class." The combination of the new transmission, TOW/HAUL mode, and integrated towing features represents a significant upgrade over the 3rd Gen.
Source: Cars.com professional review
Real-world towing capacity test: 5,300 lbs handled well
Professional testing with a 5,300-pound ballast showed the Tacoma "barely even squatted" with the weight attached. TOW/HAUL mode helped manage uphill stretches where drivers had to keep foot matted on gas to maintain 60-65 mph.
Source: Cars.com professional test
Typical towing fuel economy: 12-17 MPG
Real-world towing fuel economy with TOW/HAUL mode active:
This gives realistic expectations for towing trips.
Source: 4thGenTacoma.com community data
Light trailer usage: mixed opinions
Community debate exists on using TOW/HAUL for light trailers (under 2,000 lbs). Some users say it shifts more aggressively than needed and prefer normal mode. Others recommend TOW/HAUL for any towing.
Toyota official guidance: use it "when pulling a trailer or hauling a heavy load." No specific weight threshold given.
Source: 4GTaco.com community discussion
Transmission Hunting Prevention:
The 8-speed automatic transmission is efficient for fuel economy but can "hunt" between gears when towing. It constantly upshifts to save fuel, then downshifts when load demands power. This hunting causes:
TOW/HAUL mode locks out higher gears and holds lower gears longer, eliminating this hunting behavior.
Engine Braking Enhancement:
When descending mountain grades with a trailer, brakes can overheat quickly. TOW/HAUL mode:
When NOT to Use TOW/HAUL:
Your 4th Gen Tacoma has a full suite of towing systems:
TOW/HAUL mode is the foundational transmission setting that works with these systems. Think of it as the base layer. Always activate TOW/HAUL when towing, then layer on the other systems as needed.
Yes. TOW/HAUL mode will reduce fuel economy when active:
But when towing, this is expected. The alternative (letting transmission constantly hunt) causes more transmission wear and heat, ultimately costing more in repairs than you save in fuel.
Turn it off when not towing to restore normal fuel economy.
Toyota's TOW/HAUL implementation is conservative compared to domestic trucks:
Toyota's approach prioritizes transmission longevity and smooth operation over maximum towing performance. The Tacoma's towing capacity (varies by configuration, see page 202-204) reflects this balanced philosophy.
Pages Covered in This Thread:
A downloadable PDF containing pages 220 and 403 from your owner's manual can be found in your topic's reference folder.
This guide is derived from the official 2024+ Toyota Tacoma Owner's Manual with supplementary information from the owner community and authoritative automotive sources. Always follow your official owner's manual for warranty compliance. This is a reference guide only.
TOW/HAUL Mode, Towing Transmission Settings, Haul Mode Benefits
When to Use TOW/HAUL Mode
- Pulling a trailer (whether utility trailer, boat, or camper)
- Hauling heavy loads in the bed or significant tongue weight
- Driving in mountainous regions, even without a trailer, for better engine braking
How to Activate TOW/HAUL Mode
- Press the "TOW HAUL" switch
- Confirm the "TOW HAUL" indicator lights up on the instrument cluster
- Press the switch once more to cancel
What Changes When TOW/HAUL is Active
- Holds lower gears longer during acceleration (reduces shift hunting under load)
- Delays upshifts to keep engine in power band
- Downshifts more readily for engine braking
- Prevents unnecessary gear changes that could cause trailer sway
Engine Response:
- Throttle calibration tuned for smooth trailer control
- Reduces abrupt power delivery that could upset trailer stability
Steering Feel:
- Adjusted for better control with trailer-induced handling changes
Automatic Deactivation Conditions
Relationship to Other Drive Modes
TOW/HAUL vs. Drive Mode Select
- NORMAL mode (default balanced operation)
- ECO mode (fuel economy via moderate throttle and A/C control)
- SPORT mode (sharper throttle/transmission/steering for spirited driving)
- COMFORT mode (softer suspension tuning on AVS-equipped models)
- SPORT S/S+ modes (progressive sport tuning with suspension integration)
- CUSTOM mode (user-defined powertrain and chassis settings)
TOW/HAUL vs. ECT PWR (Power Mode)
When to use which:
- TOW/HAUL: For towing/hauling (transmission tuned for load management)
- ECT PWR: For spirited driving or mountain roads without a trailer (performance focus)
Community Wisdom: TOW/HAUL Tips from 4th Gen Owners
Pro Tips
Real-World Performance Insights
- Professional testing: 12.4 MPG average when towing (Fast Lane Truck); less than 14 MPG (Edmunds)
- User reports: 14-17 MPG range depending on terrain and trailer weight
- One user noted only 1 MPG drop with 3,000 lb trailer on highway
Why TOW/HAUL Matters for Towing Safety
- Trailer sway from repeated speed fluctuations
- Driver fatigue from constant throttle modulation
- Increased transmission heat from excessive shifting
- Downshifts more aggressively to use engine compression braking
- Reduces brake reliance on long descents
- Helps maintain safe, controlled speeds
- Empty truck driving on flat highways (unnecessary transmission restriction reduces fuel economy)
- Light loads that don't affect vehicle dynamics (under 500 lbs tongue weight)
- City driving without trailer (gear holding becomes annoying in stop-and-go traffic)
Integration with Toyota's Towing Ecosystem
- Integrated Trailer Brake Controller (Page 428-430) - Electronic brake control
- Trailer Backup Guide (Page 431-434) - Camera-based backing assistance
- Trailer Driving Assist (TDA) (Page 301-302) - Stability control enhancements
- Trailer Profiles (Page 103) - Save specific trailer configurations
Does TOW/HAUL Affect Fuel Economy?
- Holds lower gears longer (higher RPM for same speed)
- Prevents transmission from accessing highest gears
- Typical impact: 1-2 MPG reduction in highway driving
Comparison with Other Truck Tow/Haul Systems
- Ford/GM/Ram: Often include exhaust brake integration, grade braking, more aggressive downshift programming
- Toyota: Focuses on transmission shift scheduling, throttle smoothing, basic engine braking enhancement
Manual Pages Reference
- Page 220: TOW/HAUL switch operation, activation procedure, automatic deactivation conditions, ECT PWR mode
- Page 403: Drive mode select system, operation conditions, mode descriptions
- Primary: Page 220 (TOW/HAUL mode operation)
- Primary: Page 403 (Drive mode select system)
- Edmunds.com - Professional automotive testing and reviews
- Cars.com - Professional automotive reviews
- Tacoma4G.com - 4th Generation Tacoma community forum
- 4GTaco.com - 4th Generation Tacoma community forum
- 4thGenTacoma.com - 4th Generation Tacoma community forum
- TacomaWorld.com - Toyota Tacoma owner community
