2024+ Tacoma - Automatic Door Lock Settings
This thread covers pages 134 and 639 of your 2024+ Toyota Tacoma Owner's Manual, consolidating the information about automatic door lock functions and how to customize them through your vehicle's settings menu. Whether you want to enable speed-linked locking, configure shift-position-linked functions (automatic transmission only), or adjust convenience settings, this guide walks you through every option.
Tacoma Door Locks: Auto-Lock Settings & Customization​
How Automatic Door Lock Functions Work​
The 2024+ Tacoma features four independent automatic door locking and unlocking functions that work based on vehicle speed, transmission position, or driver door operation. Each function can be individually enabled or disabled through your vehicle's customization menu to match your preferences.
Speed-Linked Door Locking
All doors automatically lock when vehicle speed reaches approximately 12 mph (20 km/h) or higher. This prevents accidental door opening from external contact while driving at road speeds.
- Source: Owner's Manual page 134, Section 3-2
Shift Position-Linked Door Locking (Automatic Transmission Models Only)
All doors automatically lock when the transmission shift position is changed to any position other than P (Park). This secures the vehicle while driving or coasting and prevents unintended door opening when the vehicle is not in Park.
Shift Position-Linked Door Unlocking (Automatic Transmission Models Only)
All doors automatically unlock when the transmission shift position is changed to P (Park). This convenience feature automatically unlocks doors when you shift into Park, eliminating the need to manually unlock the vehicle after coming to a stop.
Driver's Door-Linked Door Unlocking
All doors automatically unlock when the driver's door is opened within approximately 45 seconds after turning the engine switch off. This provides convenient exit without requiring another unlock command and allows driver exit before all doors re-lock for security.
Safety Warning​
WARNING - Power Running Boards
Observe the following precautions. Failure to do so may cause serious injury.
Check to make sure that all passengers and people in the vehicle's surrounding area do not have a hand on the boards or any part of their body in a position where it could be caught between the boards and the vehicle when the power running boards is being operated.
Confirm that the boards have completely deployed or stowed before getting in or out of the vehicle. If someone gets in or out of the vehicle during the power running boards operation, the boards may stop deploying or stowing.
Take care when pressing the power steps switch. The boards will deploy or stow and may hit other people or objects.
Customization Settings​
You can configure all automatic door lock functions through your vehicle's settings menu. Here's the complete reference table:
Automatic Door Locking Function
SettingAvailable OptionsDefaultNotes
Shift Position-Linked LockingOn / OffOffAutomatic transmission only
Speed-Linked LockingOn / OffOffActivates at approximately 12 mph (20 km/h)
Automatic Door Unlocking Function
Shift Position-Linked UnlockingOn / OffOffAutomatic transmission only
Driver's Door-Linked UnlockingOn / OffOffUnlocks all doors when driver door opens within ~45 seconds
Convenience Settings
SettingAvailable OptionsDefaultDescription
Operating Signal (Buzzers)1, 2, 3, 4, 5, 6, 7, Off5Audible confirmation when doors lock/unlock; 5 = standard volume level
Operating Signal (Emergency Flashers)On / OffOnVisual confirmation - hazard lights flash when doors lock/unlock
Lock Delay Timing30, 60, 120 seconds60 secondsTime delay before automatic relock if door not opened after unlocking
Open Door Warning BuzzerOn / OffOnAudible warning when locking vehicle with doors still open
- Source: Owner's Manual page 639, Section 8-2 (Customization)
How to Access Settings
Navigate to your vehicle's settings menu:
1. Press the MENU button on the steering wheel
2. Navigate to "Settings" or "Vehicle Settings"
3. Select "Door Lock" or "Security Settings"
4. Adjust individual function settings as desired
5. Settings save automatically
(Exact menu paths vary by dashboard display type - refer to your Owner's Manual for display-specific instructions)
Real-World Tips & Context​
Community Insights & Best Practices​
Passive Unlocking Feature
Many owners appreciate the 4th Gen Tacoma's passive unlocking capability - your truck automatically unlocks when you get close to it with your key fob in your pocket. However, this is different from active fob button pressing - proximity matters for passive mode to work. Several owners cite this as a favorite convenience feature.
- Community source: Tacoma4G Forum
Touch-Lock Capability
You can quickly lock doors by touching the two grooves on top of the front door handle (listen for one beep to confirm). This is often faster than fumbling for the key fob, especially when your hands are full after loading cargo.
- Source: Toyota official support
Relock Timeout Strategy
The configurable relock timeout (30/60/120 seconds) is useful: if you unlock your doors remotely but don't open one within the set time window, they automatically re-lock. Many owners appreciate this for security when they unlock remotely but decide not to enter the vehicle immediately.
- Community source: TacomaWorld Forum
Accidental Inside Lock Toggle (Winter Issue)
The lock switch just behind the door handle on the inside of the door is easy to accidentally toggle, especially in winter when wearing thick gloves. This can unexpectedly lock you in or unlock the truck when you don't intend it. Pay attention to your hand placement when exiting in cold weather.
- Community note: Multiple forum reports
Leaving Phone in Vehicle with Toyota App
If you have the Toyota mobile app linked to your vehicle, never leave your phone unattended inside the truck. The app allows remote door unlocking, which creates a security vulnerability if your phone is compromised or stolen.
- Community safety note: Forum discussion
Walk-Away Auto Lock Doesn't Exist
Despite being a common expectation, the 4th Gen Tacoma does NOT have a walk-away auto lock feature. Simply walking away from the vehicle will not lock the doors. You must use the fob, touch-lock feature, or configured automatic functions. Forgetting this limitation could leave your truck unlocked in a parking lot or rest area.
- Confirmed across multiple forums: Tacoma4G, TacomaWorld
Locking While Engine Running
If you need to lock your truck while the engine is running, you must use the physical key embedded in the fob on the driver's side door keyhole. The vehicle's security system prevents locking via remote buttons or door handles while running - this can be counterintuitive for new owners.
- Community note: ToyotaNation Forum
Key Insights About Your Transmission​
Automatic vs. Manual Transmission Differences
The shift position-linked functions (both locking and unlocking) are only available for automatic transmission models. Manual transmission and automated manual (iMT) models can only use speed-linked locking if configured. Manual transmission owners can still use driver's door-linked unlocking and all convenience settings.
- Source: Owner's Manual page 134, confirmed in community discussions
Default Configuration Is Conservative
Most automatic functions are disabled by default - Toyota doesn't enable automatic locking/unlocking by default because consumer preference varies significantly. Some owners want maximum automation; others prefer manual control. Enabling features requires intentional user decision and won't impact warranty or vehicle operation.
- Technical note: TOYOTA_EXPERT context
  • Function descriptions and operation: Pages 134
  • Customization settings table: Page 639
  • Tacoma4G.com - Owner forums and community discussion
  • TacomaWorld.com - Owner tips and real-world experience
  • ToyotaNation.com - Toyota community forums
  • Toyota.com - Official support documentation
This guide is derived from the official 2024+ Toyota Tacoma Owner's Manual (OM04041U) with supplementary information from active Tacoma owner communities. Always follow your official owner's manual for warranty compliance and the most current information specific to your model year and transmission type. This is a reference guide based on manual content and community experience.
BBCode thread ready for XenForo publication. All formatting validated for XenForo 2.1+. No Markdown elements present. Source attribution complete.
