2024+ Tacoma - Automatic Transmission Shifting (S Mode)
This thread consolidates complete information about automatic transmission shifting and S mode operation from pages 217-219 of your 2024+ Toyota Tacoma owner's manual, enhanced with community insights and practical real-world tips.
Tacoma Automatic Transmission: S Mode, Shifting & Tips​
WARNING - Slippery Road Surfaces:
When driving on slippery road surfaces Do not accelerate or shift gears suddenly. Sudden changes in engine braking may cause the vehicle to spin or skid, resulting in an accident.
Source: Owner's Manual, Page 218
WARNING - Shift Lock Override Safety:
To prevent an accident when releasing the shift lock Before pressing the shift lock override button, make sure to set the parking brake and depress the brake pedal. If the accelerator pedal is accidentally depressed instead of the brake pedal when the shift lock override button is pressed and the shift lever is shifted out of P, the vehicle may suddenly start, possibly leading to an accident resulting in death or serious injury.
Source: Owner's Manual, Page 219
CAUTION - Transmission Overheating Protection:
If the automatic transmission fluid temperature is high, 'Transmission Oil Temp. High Stop in a Safe Place and See Owner's Manual' will be displayed on the multi-information display. Immediately stop the vehicle in a safe place, shift the shift lever to P and wait until the warning message go off. If the warning message go off, you may start the vehicle again. If the warning message do not go off, contact your Toyota dealer.
Source: Owner's Manual, Page 217
Understanding Your Transmission​
What the Shift Positions Do
Your 2024+ Tacoma features an 8-speed automatic transmission with intelligent shift control. Each shift position serves a specific purpose:
PositionPurposeWhen to Use
PPark - Power transmission disengagedWhen parked or starting engine
RReverse - Drive backwardsBacking up only
NNeutral - Engine running, no power transmissionBrief stops (hold brake pedal)
DDrive - Automatic gear selectionMost normal driving conditions
SSport Mode - Manual-style gear selection (S1-S8)Performance, engine braking, precise control
How AI-SHIFT Works
Your transmission features AI-SHIFT automatic operation, which intelligently selects appropriate gear ratios based on current driving conditions, throttle input, road slope, and real-time traffic patterns. AI-SHIFT automatically operates whenever the shift lever is in D (Drive) or S (Sport) position.
How to Shift Gears​
Basic Shifting Procedure
For Normal Driving (Shifting into D):
1. Depress the brake pedal
2. Turn the engine switch to ON
3. Push the shift release button on the shift knob
4. Move the shift lever to your desired position (R, N, D, or S)
For Manual Gear Selection (Shifting into S mode):
1. While the shift lever is in any position
2. Push the shift release button on the shift knob
3. Shift the lever normally
Important: When shifting between P (Park) and D (Drive), the vehicle MUST be completely stopped. For the vehicle to be shifted FROM P, the brake pedal must be depressed BEFORE pushing the shift release button.
Sport Mode (S Mode) Operation​
What is S Mode?
Sport mode allows you to take manual control of your transmission's gear selection, similar to a traditional manual transmission. This gives you precise control over engine braking force and acceleration characteristics.
S1-S8 Shift Ranges
Shift RangeAccelerating ForceEngine Braking ForceBest For
S1-S3MaximumMaximumDownhill driving, traction, performance
S4-S5ModerateModerateBalanced performance and efficiency
S6-S8LowLowHighway cruising, fuel efficiency
Community Best Practices​
Pro Tips:
- Use S3 before steep acceleration to maximize power
- Regular ATF fluid changes maintain smooth shifting
- S mode provides excellent engine braking on downhill driving
- Transmission break-in routine (D→Eco→Sport for 500 miles each) improves performance
Common Mistakes to Avoid:
- Don't ignore rough cold-start shifts (may indicate solenoid issues)
- Delayed Park-to-Reverse engagement is normal (2-4 seconds)
- Monitor RPM levels in S mode to avoid over-revving
- Don't skip transmission diagnostics if experiencing problems
Content sourced from:
- 2024+ Toyota Tacoma Owner's Manual, Pages 217-219
- TacomaWorld.com, 4GTaco.com, TacomaForum.com community forums
