2024+ Tacoma - Coolant Type & Capacity
This guide provides the definitive coolant specifications from your 2024+ Tacoma's official owner's manual. Use these OEM specifications to maintain warranty compliance and peak cooling system performance.
Tacoma Coolant: Type, Capacity & Super Long Life Specs​
Required Coolant Type​
Your 2024+ Tacoma's cooling system was engineered specifically for Toyota Super Long Life Coolant. Using the correct coolant type is essential to:
  • Prevent corrosion and rust formation
  • Maintain freeze/boil-over protection appropriate for your climate
  • Preserve gasket and water pump seal integrity
  • Maintain full warranty coverage
- Source: Owner's Manual pages 527, 616
Toyota Specification:
Use only "Toyota Super Long Life Coolant" for your Tacoma cooling system.
Alternative Coolant Standard (if OEM brand unavailable):
Use only high-quality coolants meeting Toyota's hybrid organic acid technology (OHAT) standard:
  • Ethylene glycol-based
  • Non-silicate formula
  • Non-amine composition
  • Non-nitrite additive
  • Non-borate content
  • Long-life hybrid organic acid technology
- Source: Owner's Manual page 616
Critical Safety Requirement:
Do not use plain water alone in your cooling system under any circumstances.
Cooling System Capacity​
Your 2024+ Tacoma's coolant capacity depends on engine configuration. Check your vehicle's documentation to determine which applies to your specific model.
Short Bed Models (TZNA41L-PRZSTA, TZNA41L-CRZSTA, TZNA46L-PRZSTA, TZNA46L-CRZSTA):
  • 12.6 quarts (11.9 liters / 10.5 imperial quarts)
All Other Models (Long Bed and remaining configurations):
  • 12.8 quarts (12.1 liters / 10.6 imperial quarts)
Note: All 4th Gen Tacoma models use the same turbocharged gasoline engine with intercooler. The capacity difference is determined by model code/bed configuration, not engine type.
Checking Your Coolant Level​
Procedure:
The coolant level is correct when it reads between the "F" (Full) and "L" (Low) lines on the reservoir with your engine cold (not running and cooled for at least 5 minutes after shutdown).
- Source: Owner's Manual page 527
Important Precautions:
  • Always check coolant level when the engine is completely cold
  • Never attempt to open the radiator cap when the engine is hot
  • If level is at or below the "L" line, add coolant carefully up to the "F" line
Why Coolant Type Matters for Your Tacoma​
Toyota Super Long Life Coolant uses long-life hybrid organic acid technology (OHAT) - it was engineered for the aluminum and bi-metal components in modern engines like yours. Standard coolants lack the corrosion inhibitors needed for your specific cooling system design.
Using the wrong coolant can result in:
  • Accelerated corrosion and rust formation
  • Water pump damage and premature failure
  • Gasket and seal degradation
  • Warranty coverage loss
  • Cooling system failure under extreme conditions
Official Documentation:
All specifications in this guide are sourced directly from the official 2024+ Toyota Tacoma Owner's Manual (Document OM04041U):
  • Coolant type specification: Pages 527, 616
  • System capacity: Page 616
  • Level checking procedure: Page 527
This guide is derived from the official 2024+ Toyota Tacoma Owner's Manual (OM04041U). Always follow your official owner's manual for warranty compliance and maintenance procedures. This is a reference guide only. Consult your Toyota dealership for service questions or if you are unsure of your vehicle's specific specifications.
