2024+ Tacoma - Customizing the Instrument Cluster (Meter Style)
This thread consolidates the comprehensive customization information from pages 104-115 and 636-638 of your 2024+ Toyota Tacoma Owner's Manual. The extensive display customization options available on the 4th Generation Tacoma represent a significant enhancement over previous generations, giving you powerful control over what information appears on your instrument cluster.
Tacoma Instrument Cluster: Customize Meter, Display & Style​
WARNING: If the engine is operating while changing certain settings on the settings display, ensure that the vehicle is parked in a place with adequate ventilation. In a closed area such as a garage, exhaust gases including harmful carbon monoxide (CO) may collect and enter the vehicle. This may lead to death or a serious health hazard.
WARNING: As the engine needs to be operating during customization, ensure that the vehicle is parked in a place with adequate ventilation. In a closed area such as a garage, exhaust gases including harmful carbon monoxide (CO) may collect and enter the vehicle. This may lead to death or a serious health hazard.
NOTICE: To prevent battery discharge, ensure that the engine is running while customizing features.
Some settings cannot be changed while driving. When changing settings, park the vehicle in a safe place.
- Source: Owner's Manual pages 115 and 636
Accessing the Instrument Cluster Customization Menu​
The instrument cluster settings are accessible from two different control methods on your 4th Gen Tacoma:
Via Multi-Information Display
Direct buttons on the instrument cluster allow menu navigation and setting changes.
Via Multimedia System
Select customization options through your vehicle's main multimedia interface.
Your 2024+ Tacoma provides flexible customization across these systems, with some settings available through one method and others through the alternative system.
Customizable Meter Display Settings​
The following settings can be customized on your instrument cluster. Each setting has a default value and multiple customization options:
1. Language
Default: English
Available Options: English, French, Spanish
(Default varies by country)
2. Units of Measurement
Default: Miles (MPG US)
Available Options: Miles (MPG US), Kilometers (km/L), Kilometers (L/100km), Miles (MPG Imperial)
Note: These unit options affect all display measurements including fuel economy, distance, and speed references.
3. Meter Style
Default: "Tough"
Available Options: "Tough," "Casual," "Sporty," "Smart"
Note: The "Smart" style is available for both standard meter and head-up display (if equipped).
4. Dial Type
Default: Tachometer
Available Options: Tachometer (engine RPM), Speedometer (vehicle speed)
5. Meter Type
Allows selection between different meter display configurations to suit your preference for information presentation and visual layout.
6. Fuel Economy Display
Default: Average fuel consumption after starting
Available Options: Average since starting, Average since last reset, Average since last refuel
7. Drive Information and Trip Items (Configurable Slots)
Your cluster offers two customizable information display slots. You can select what information appears in each slot independently.
First Item Options: Distance traveled, Average vehicle speed, Elapsed time
Second Item Options: Distance traveled, Average vehicle speed, Elapsed time
8. Pop-Up Display
Default: On (enabled)
Available Options: On, Off
Note: Controls supplementary system information and alerts on your meter screen.
9. Default Setting Reset
Option: Return all customization selections back to factory default settings.
10. Head-Up Display Customization (If Equipped)
Display: On/Off toggle (default: On)
Display Type: Standard, Full, or Minimum
Meter Style: "Tough," "Casual," "Sporty," or "Smart"
11. System Capabilities
Settings changeable using the multimedia system: Certain customizations accessible through the main touchscreen interface
Settings changeable using the multi-information display: Some options adjustable through steering wheel controls
Settings changeable by your Toyota dealer: Advanced system configurations requiring professional programming
- Source: Owner's Manual pages 104-115 and 636-638
Important Implementation Note​
Some function settings are changed simultaneously with other functions being customized. Contact your Toyota dealer for further details.
- Source: Owner's Manual page 636
Real-World Tips from the Community​
Pro Tips (Owner Best Practices)​
Multi-Page Customization Strategy
Each driver can configure three separate display pages with different information on each page. This allows you to have different "profiles" for different driving scenarios (daily commute page, off-road page, towing page).
Source: Tacoma4G.com Forum
Driver Profile Switching for Personalized Configurations
When your vehicle starts with a specific key or phone, it automatically loads that driver's customized dashboard settings AND multimedia settings. If multiple people drive the truck, each person can have their preferred meter style and information display configuration.
Source: 4th Gen Tacoma Forum
Full Gauge Monitoring Suite Available
Your 4th Gen Tacoma includes a comprehensive set of available gauges: fuel, coolant temperature, oil pressure, oil temperature, voltmeter, turbo boost gauge, transmission fluid temperature, and many other informational displays. Many owners aren't aware of the full range of monitoring options available through the customizable display.
"Smart" Meter Style is Popular Among Owners
Community discussions indicate the "Smart" meter style is a popular choice among 4th Gen owners for its balance of information density and visual clarity. If you're unsure which style to choose, trying the Smart style is worth considering based on owner feedback.
Critical Implementation Tip​
Settings Must Be Changed While in Park
Your customization changes will ONLY save if you make them while the vehicle is parked. Many owners discovered this through trial-and-error when their changes didn't persist after restarting the vehicle.
Attempting to Change Settings While Driving
The manual specifically states settings cannot be changed while driving. The system locks these settings for safety, and you must pull over and park the vehicle to make adjustments. Frustration from owners trying to customize while stopped at traffic lights led to repeated community discussions about this limitation.
Source: Tacoma World Forum
Not Realizing Settings Are Tied to Driver Profiles
Some owners were confused when they reset the truck and their customizations were gone, not realizing that settings are linked to specific key fobs or phone profiles. If the truck is started with a different key, it loads different settings. This caused confusion for households with multiple drivers.
Helpful Context​
Why 4th Gen Offers More Customization Than Previous Generations
Owners upgrading from 3rd generation Tacomas frequently comment on the extensive customization options being new to the 4th Gen. This reflects Toyota's philosophy with the new generation to allow different driving profiles and personalization. If you're new to the 4th Gen, exploring these options is worth your time.
TSS 3.0 Customization Extends Beyond the Instrument Cluster
The 4th Gen Tacoma's Toyota Safety Sense 3.0 system allows extensive customization through the instrument cluster. Nearly every system can be customized to match your driving preferences, not just the display aesthetics. The customization menu extends to driver assist settings and safety features through the My Settings menu.
Source: 4GTaco.com
Frequently Asked Questions​
Q: Why did my settings change after I restarted the truck?
A: Your truck may have been started with a different key or phone profile, which automatically loads that driver's custom settings. Alternatively, your changes may not have been saved because the vehicle wasn't in Park when you made them. Always ensure you're in Park and that your changes fully register before restarting.
Q: Can I change settings while driving?
A: No. The system requires the vehicle to be parked and in Park gear to accept customization changes - a safety feature to prevent distracted driving.
Q: Is it worth spending time customizing my display?
A: Yes. 4th Gen Tacoma owners consistently report that finding their preferred meter style and information display configuration improves their daily driving experience. New owners especially benefit from exploring these options.
Q: What does the "Smart" meter style offer?
A: The "Smart" style provides an enhanced display layout with optimized information density. It's particularly popular for head-up display use and is frequently recommended by the owner community.
This thread covers information from the following pages of your 2024+ Toyota Tacoma Owner's Manual:
  • Pages 104-115: Instrument Cluster Display Options and Settings
  • Pages 636-638: Complete Customization Reference Tables
For the official manual diagrams, specifications, and complete procedures, refer directly to these pages in your owner's manual.
Manual Sources:
All official specifications and procedures are sourced from the 2024+ Toyota Tacoma Owner's Manual (pages 104-115 and 636-638).
Community Sources:
Real-world tips and owner experiences are sourced from established Tacoma enthusiast communities:
  • Tacoma4G.com - 4th Generation Tacoma Forum
  • TacomaWorld.com - Tacoma Owner Community
  • 4GTaco.com - 4th Gen Tacoma Dedicated Forum
This thread presents information from the official owner's manual combined with community feedback. For safety-critical information or procedures you're uncertain about, always refer to your official owner's manual or contact your Toyota dealer. The customization options and procedures described here are accurate for 2024+ Toyota Tacoma models, but your specific vehicle configuration may vary.
Always ensure your engine is running while customizing features to prevent battery discharge, and park in a well-ventilated area due to exhaust hazards - as emphasized in the official manual warnings.
Thread compiled from: 2024+ Toyota Tacoma Owner's Manual (pages 104-115, 636-638) and community feedback from established Tacoma enthusiast forums.
