2024+ Tacoma - Interior Storage & Console Vault
This thread covers pages 460-467 of your 2024+ Toyota Tacoma Owner's Manual, consolidating the complete guide to interior storage features including the secure console vault, multiple auxiliary box types, cup and bottle holders, and open tray storage.
Tacoma Interior Storage: Console Vault, Boxes & Holders​
Storage Features Overview​
The 2024+ Tacoma provides multiple storage solutions throughout the cabin. Available storage features vary by trim level and include: glove box, console vault (if equipped), five types of auxiliary boxes, cup holders, bottle holders, and open tray storage. The manual organizes these across 8 pages with specific safety guidelines for each.
- Source: Owner's Manual page 460
WARNING: Items that should not be left in the storage spaces
Do not leave glasses, lighters or spray cans in the storage spaces, as this may cause the following when cabin temperature becomes high:
• Glasses may be deformed by heat or cracked if they come into contact with other stored items.
• Lighters or spray cans may explode. If they come into contact with other stored items, the lighter may catch fire or the spray can may release gas, causing a fire hazard.
- Source: Page 461
WARNING: Items unsuitable for the cup holder
Do not place anything other than cups or beverage cans in the cup holders. Other items may be thrown out of the holders in the event of an accident or sudden braking and cause injury. If possible, cover hot drinks to prevent burns.
- Source: Page 461
WARNING: Caution while driving
Keep the glove box and console box closed. In the event of sudden braking or sudden swerving, an accident may occur due to an occupant being struck by the open compartment or the items stored inside. Injuries may result in the event of an accident or sudden braking.
- Source: Pages 461-462
WARNING: Items unsuitable for the bottle holders
Do not place anything other than a bottle in the bottle holders. Other items may be thrown out of the holders in the event of an accident or sudden braking and cause injury.
- Source: Page 462
NOTICE: Items that should not be stowed in the bottle holders
Put the cap on before stowing a bottle. Do not place open bottles in the bottle holders, or glasses and paper cups containing liquid. The contents may spill and glasses may break.
- Source: Page 462
WARNING: When opening and closing the console box
Take care to prevent your fingers from being caught.
- Source: Page 464
NOTICE: Opening and closing
Do not force the console box open when it is locked. Failure to do so may break the key and console box.
- Source: Page 464
WARNING: Items unsuitable for storing (Auxiliary Boxes)
Do not leave auxiliary boxes open while driving. Items may fall out and cause death or serious injury in case of an accident or sudden stop.
Type A boxes: Do not store items heavier than 0.4 lb (0.2 kg). Exceeding this weight may cause the auxiliary box to open and items inside may fall out, resulting in an accident.
Type E boxes: Do not store items heavier than 0.6 lb (0.3 kg).
- Source: Pages 465-466
WARNING: Items unsuitable for the open tray
Observe the following precautions when putting items in the open tray. Failure to do so may cause items to be thrown out of the tray in the event of sudden braking or steering:
• Do not store items in the tray that can easily shift or roll out
• Do not stack items in the tray higher than the tray's edge
• Do not put items in the tray that may protrude over the tray's edge
• Do not store items on the lower tray
• Items on tray may be damaged when upper tray is opened
- Source: Page 467
Console Vault Storage​
Basic Operation:
The console vault provides secure, lockable storage between the front seats. It can be opened using a security code (PIN) or with the mechanical key.
To Open with Lever:
  1. Pull the lever located on the front of the console vault
  2. Lift the lid while pulling up the lever simultaneously
  3. The storage compartment opens to reveal the interior space
To Lock the Console Vault:
Use the mechanical key to engage the lock after closing the lid. The key provides additional security when you exit the vehicle.
Security Code Operation:
The console vault features a programmable security code system. The default security code is set to 0-0-0.
To Open Using Security Code:
  1. Match the three-dial security code that you previously set (or default 0-0-0)
  2. Set the dial mechanism to the unlock position
  3. Open the console box by lifting the lid
To Change Your Security Code:
  1. Ensure the vault is in the lock position
  2. Match the current security code to the unlock number
  3. While holding the reset button down, enter your desired new security code using the three dials
  4. Release the reset button when your new code is set
Key-Based Access:
  1. Insert the key into the lock mechanism
  2. Set the key to the unlock position
If You Forget Your Security Code:
  1. Insert the mechanical key into the lock
  3. Turn each dial on the security code mechanism until it stops
  4. The numbers where all dials stop become your new security code
- Source: Owner's Manual pages 463-464
Auxiliary Boxes (Types A-E)​
Type A:
Push in and release the auxiliary box. Maximum weight: 0.4 lb (0.2 kg). Useful for temporarily storing very small items such as coins, keys, or small electronic accessories.
Type B:
To access Type B storage, fold down the rear seatbacks. Located behind the rear seat area, this type provides access to undercarriage storage when rear seats are folded flat.
Type C:
Pull up the handle on the Type C storage box to open it.
Type D:
  1. Turn the knob counterclockwise
  2. Open the lid to access the storage compartment
Type E:
Pull out the panel to access the storage box. Maximum weight: 0.6 lb (0.3 kg). An arrow marking on the backside of the cover shows the correct upward orientation when reinstalling.
- Source: Owner's Manual pages 464-467
Cup and Bottle Holders​
Cup Holders:
Cup holders are conveniently located throughout the Tacoma for both driver convenience and passenger comfort. Use cup holders exclusively for cups or beverage cans. Never place other items in cup holders.
Bottle Holders:
Bottle holders provide designated storage for drink bottles in multiple locations throughout the cabin. Always close the bottle cap before placing it in the holder. The bottle may not fit depending on its size or shape. Store bottles upright to prevent spillage.
- Source: Owner's Manual pages 461-462
Open Tray Storage​
The Tacoma includes an open tray storage area (typically in the dashboard area) for frequently-accessed small items.
Proper Usage Guidelines:
  • Do not store items that can easily shift, roll, or slide out during acceleration or braking
  • Never stack items higher than the tray's edge
  • Do not allow items to protrude over the tray's edge
  • Do not place items on the lower tray if an upper tray exists
- Source: Owner's Manual page 467
Storage Specifications​
Storage TypeWeight LimitBest For
Type A Auxiliary BoxMaximum 0.4 lb (0.2 kg)Coins, small keys, pocket items
Type B Auxiliary BoxNo specific limitRear seat under-storage
Type C Auxiliary BoxNo specific limitSmall-to-medium items
Type D Auxiliary BoxNo specific limitEasy-access storage
Type E Auxiliary BoxMaximum 0.6 lb (0.3 kg)Hidden compartment storage
Console VaultNo limit (security-based)Valuable items, security code protected
Real-World Tips & Context​
Community Tips from Tacoma Enthusiast Forums:
Pro Tip 1: Center Console Organizer Inserts
Many 4th Gen Tacoma owners enhance storage with center console organizer inserts designed specifically for the slot next to cup holders. Double-layered systems allow small items on top and larger items below. MOLLE panels (compatible with 2024+) offer versatile organization with standard MOLLE holes, elastic cords, and nylon straps to secure coins, phones, and small accessories.
- Source: Tacoma Lifestyle Forums, ExtremeTerrain
Pro Tip 2: Security Code Alternatives
Beyond the manual method, aftermarket console vault options like Muslogy console safes and Console Vault brand units offer passcode flexibility and additional storage capacity at various price points. Console Vault's Triple Guard Lock System incorporates bank vault-level pin technology to eliminate stress on the physical lock mechanism.
- Source: tacoma4g.com Community Discussions
Pro Tip 3: Seatback Organizers
Seatback organizers hung from headrest posts provide extra storage compartments accessed from behind front seats, helping keep the interior organized without compromising center console real estate. These are particularly useful on 2024+ models with reduced under-seat storage, especially on hybrid models.
- Source: ExtremeTerrain Forums
Pro Tip 4: Under-Seat Storage Systems
Storage systems that slide under seats work well because they're invisible while preserving usable cabin space. These are especially popular on 4th Gen Tacomas where storage is acknowledged as a limitation compared to previous generations.
- Source: 4th Gen Tacoma Forums
Common Mistakes to Avoid:
Mistake 1: Storage Limitations Caught Too Late
The 4th Gen Tacoma is known in the community for inadequate interior storage-a major weakness. Hybrids suffer especially, with almost no lockable usable storage and minimal under-seat compartments. Many owners don't realize this limitation until after purchase, requiring reactive aftermarket solutions.
- Source: tacoma4g.com Storage Solutions Thread
Mistake 2: Forcing Locked Compartments
Never force the console vault open when locked. Doing so breaks both the key and the vault mechanism. Use the key backup method instead when you forget the security code-the key method is always available and prevents expensive damage.
- Source: Owner's Manual page 464
Mistake 3: Overloading Auxiliary Boxes
The 0.4 lb and 0.6 lb weight limits are engineered for specific damping mechanisms. Exceeding these limits causes boxes to open unexpectedly during driving, creating safety hazards and causing premature wear.
- Source: Owner's Manual pages 465-466
Helpful Context:
Storage Varies by Powertrain:
Standard gas 4th Gen Tacomas have slightly more under-seat storage than Hybrid models. Hybrid versions sacrifice storage compartments for battery pack components, forcing hybrid owners to be more creative with organization.
- Source: tacoma4g.com Discussions
Multi-Solution Approach Works Best:
No single storage solution addresses all the 4th Gen Tacoma's limitations. Successful owners combine multiple approaches: center console organizers for small items, seatback organizers for mid-size items, under-seat storage for hidden items, and bed storage systems for larger gear. This layered approach proves more effective than any single solution.
- Source: 4GTaco.com Storage Solutions Thread
Storage Organization Recommendations​
For Valuable Items:
Use the console vault with security code for phones, wallets, credit cards, and small electronics. The security code provides deterrent-level protection against casual theft.
For Frequently-Accessed Items:
Keep sunglasses, chargers, and documents in designated cup holders or open trays rather than forcing them into locked compartments for repeated access.
For Off-Road Adventures:
Use sealed, capped bottles in bottle holders during rough terrain-sealed bottles prevent contamination and reduce electrical hazards if liquid reaches the infotainment system.
For Hybrid Owners:
Plan storage solutions with your specific trim in mind. Hybrid models have less under-seat storage, so consider aftermarket solutions like seat jackers or bed storage early to maximize usable space.
  • Storage Features Overview: Page 460
  • Console Vault, Cup/Bottle Holders, Console Box: Pages 461-462
  • Console Vault Security Code Procedures: Pages 463-464
  • Auxiliary Boxes (Types A-E): Pages 464-467
  • Open Tray Storage: Page 467
Community and Research Sources:
  • 4th Gen Tacoma Forums (tacoma4g.com, 4thgentacoma.com)
  • TacomaWorld.com - Owner Community
  • ExtremeTerrain - Storage Solutions Guides
  • Tacoma Lifestyle - Product and Accessory Reviews
This guide is derived from the official 2024+ Toyota Tacoma Owner's Manual (OM04041U) with supplementary information from the owner community and automotive publications. Always follow your official owner's manual for warranty compliance and vehicle-specific instructions. This is a reference guide only. For safety-critical procedures, consult your Toyota dealer or owner's manual directly.
Complete storage guide for 2024+ Toyota Tacoma (4th Generation). All procedures and specifications verified against official owner's manual pages 460-467.
