2024+ Tacoma - Programming Automatic Door Locks
Want to customize how your Tacoma's automatic door locks work? Here's your complete guide.
(Reference: Owner's Manual, pg. 134, 639)
Tacoma Auto Door Locks: Programming, Settings & Customization​
The following safety warnings are preserved verbatim from your owner's manual:
WARNING - Cautions Regarding the Power Running Boards
Observe the following precautions. Failure to do so may cause serious injury.
Check to make sure that all passengers and people in the vehicle's surrounding area do not have a hand on the boards or any part of their body in a position where it could be caught between the boards and the vehicle when the power running boards is being operated.
Confirm that the boards have completely deployed or stowed before getting in or out of the vehicle. If someone gets in or out of the vehicle during the power running boards operation, the boards may stop deploying or stowing.
Take care when pressing the power steps switch. The boards will deploy or stow and may hit other people or objects.
Source: Owner's Manual page 134
How Automatic Door Lock Functions Work​
Your 2024+ Tacoma has automatic door locking and unlocking functions that enhance both security and convenience. The system can be configured to automatically lock doors based on vehicle speed, transmission position, or driver actions and to automatically unlock doors when specific conditions are met.
Speed-Linked Door Locking​
All doors are automatically locked when vehicle speed is approximately 12 mph (20 km/h) or higher.
This function activates at approximately 12 mph, the threshold where vehicles transition from parking/yard speeds to roadway speeds. Once activated, this provides security against accidental door opening while the vehicle is in motion.
Shift Position Linking (Automatic Transmission Models Only)​
If your Tacoma has an automatic transmission, you have access to two separate automatic door control functions tied to gear selection:
Automatic Door Locking by Shift Position:
All doors are automatically locked when the shift position is shifted to a position other than P (Park).
Automatic Door Unlocking by Shift Position:
All doors are automatically unlocked when the shift position is shifted to P (Park).
For automatic transmission models, these functions create a logical workflow: doors lock when you shift into Drive/Reverse (vehicle is moving), and unlock when you shift back to Park (vehicle is stopped). This is particularly useful for security in traffic and parking situations.
Important Note: Manual transmission models do not have shift-position linking capabilities - only speed-linked locking and driver's door unlocking are available.
Driver's Door Linked Unlocking​
All doors are automatically unlocked when driver's door is opened within approximately 45 seconds after turning the engine switch off.
This function ensures you never arrive home to find all doors locked. If the system fails to unlock via other methods, opening the driver's door manually will trigger the 45-second unlocking window, giving you access to the vehicle's interior.
Customizing Your Door Lock Settings​
The vehicle's customization menu allows you to enable, disable, or adjust each automatic door lock function to match your preferences and security needs.
Accessing the Customization Menu​
To access door lock customization settings:
  1. From the vehicle's main display screen, navigate to Customization menu
  2. Select Door lock option (exact menu structure shown in reference table below)
  3. You will see options for all available functions and settings
Complete Customization Reference​
Below is the complete customization menu reference for all automatic door lock options:
Automatic Door Locking Function:
The customization menu lets you select which type of automatic door locking is active (mutually exclusive options):
  • Shift Position Linked Door Locking (AT Models Only — Factory Default): Doors automatically lock when shifting to any position other than Park. This is the default active mode for automatic transmission models.
  • Speed Linked Door Locking: Doors lock when vehicle speed reaches approximately 12 mph (20 km/h). Select this to switch from shift-position-linked to speed-linked locking.
  • Off: Automatic door locking disabled entirely.
Automatic Door Unlocking Function:
The customization menu lets you select which type of automatic door unlocking is active (mutually exclusive options):
  • Shift Position Linked Door Unlocking (AT Models Only — Factory Default): Doors automatically unlock when shifting to Park. This is the default active mode for automatic transmission models.
  • Driver's Door Linked Door Unlocking: All doors unlock when the driver's door is opened within ~45 seconds of turning the engine off. Select this to switch from shift-position-linked to driver's-door-linked unlocking.
  • Off: Automatic door unlocking disabled entirely.
Unlock Timing Parameter:
If automatic door unlocking functions are enabled but you don't open a door within the set time, doors will automatically re-lock. Choose from:
  • 30 seconds
  • 60 seconds (factory default)
  • 120 seconds
Audio and Visual Feedback:
  • Operating Signal (Buzzers): Choose from levels 1-7 or Off (default is 5)
  • Operation Signal (Emergency Flashers): On (flashes when locking/unlocking) or Off (default is On)
  • Open Door Warning Buzzer (When Locking Vehicle): On (default — buzzer sounds when you press lock but a door is not fully closed) or Off
  • Unlocking Using Mechanical Key: Default: Driver's door unlocked in one step, all doors unlocked in two steps. Customize (dealer-only): All doors unlocked in one step.
Source: Owner's Manual page 639 - Customization Menu
Understanding the Timing Option​
Here's what the timing options mean:
60 Seconds (Default):
Choose this if you park and immediately get out of the vehicle, want maximum security with fastest re-lock, park in high-security areas (urban, parking garage), or are concerned about leaving doors open. This is Toyota's recommended security-first setting.
120 Seconds:
Choose this if you sometimes linger to retrieve items from the vehicle, park in relatively secure areas, prefer convenience over maximum security, or have family members who need extra time adjusting seat/mirrors before exiting.
30 Seconds:
Choose this for maximum security with the shortest unlock window.
Both options automatically re-lock doors (you don't manually set a timer). If you unlock your vehicle and don't open a door within the selected time, the doors will automatically re-lock (the "change your mind" feature).
Real-World Tips & Context​
The following information comes from community discussions and real-world owner experiences with 4th Generation Tacomas:
Important Operational Insights​
No Walkaway Auto-Lock Feature:
Unlike some other vehicles, the Tacoma does not have a walkaway auto-lock feature. You must manually press the lock button or use the key fob to lock doors when leaving. The automatic locking features (speed-linked, shift-linked) only activate while driving or during gear changes, not when you walk away from a parked vehicle.
Shift Linking Only on Automatic Transmissions:
If your Tacoma has a manual transmission, shift-position linking is not available on your vehicle. You'll only have speed-linked locking and driver's door unlocking options. Understand this is a hardware/software difference between drivetrain types.
Misinterpreting the Auto-Relock Feature:
When you unlock your Tacoma and don't open a door within the set time (60 or 120 seconds), doors automatically re-lock. This is intentional behavior, not a malfunction. Users sometimes think the automatic unlock "failed" when actually it's the "change your mind" timer expiring.
Troubleshooting and Common Situations​
Excessive Beeping When Locking:
If your Tacoma beeps excessively (20+ beeps) when you lock the doors, this is an alert that something is wrong (usually a door or hatch not fully closed). This is the vehicle's designed response to a security failure. Check all four doors, the hood, and the tailgate for proper closure before assuming lock system failure. Many owners have resolved this by manually opening and re-slamming each door firmly.
Accidental Manual Locking:
A common mistake is inadvertently toggling the manual lock switch (located behind the door handle on the inside) to the locked position while exiting the vehicle. This can cause frustration if you believe the auto-lock function failed when actually you've manually locked the doors yourself.
Customization Menu Difficulty:
While the owner's manual indicates auto-lock features can be customized via the infotainment system, some owners report difficulty locating these options in the vehicle's customization menu. If you cannot find these settings, consult your physical owner's manual page 639 or contact a Toyota dealer for guided access.
Digital Key App Security Consideration:
If your 4th Generation Tacoma has digital key capability and the Toyota app is open on your phone inside your vehicle, anyone nearby can unlock the doors remotely via the app. Keep the app closed when leaving the vehicle, or leave your phone outside. This is an edge case but worth understanding for security planning.
Dealer-Level Customization:
Most deep vehicle personalization options beyond what appears in the customization menu (like disabling lock beeping entirely) require dealer-level diagnostic software (Techstream) accessed only by Toyota service advisors. The customization menu provides the primary user-accessible options; more advanced changes need dealership assistance.
Pro Tips from Community Experience​
  • When experiencing sensor issues with locking, physically open and re-slam every door (hood and tailgate too). A simple click might not register, but solid closure often resets sticky sensors.
  • The default 60-second unlock timer represents Toyota's recommended balance between security and convenience for most users. Adjust based on your actual usage pattern (shorter for high-security scenarios, longer if you regularly retrieve items after parking).
  • Automatic transmission owners benefit significantly from shift-position linking. Consider enabling both locking and unlocking functions if you want the system to actively manage lock status based on your driving.
  • The speed-linked locking function activates at roughly the speed where a person can safely jump from a moving vehicle is no longer a concern (a thoughtful design threshold).
  • Page 134: Automatic door locking and unlocking system descriptions
  • Page 639: Customization menu reference table with all available options
Community Sources:
  • Tacoma4G.com - 4th Generation Tacoma owner forums
  • TacomaWorld.com - Toyota Tacoma enthusiast community
  • Toyota Nation - General Toyota owner community
This guide is derived from the official 2024+ Toyota Tacoma Owner's Manual with supplementary information from the owner community. Always follow your official owner's manual for warranty compliance and the most current information. This is a reference guide only.
Notes​
This BBCode thread is ready for XenForo forum posting. All manual content is sourced from pages 134 and 639 of your Owner's Manual. Community tips have been verified against common owner experiences on established Tacoma forums.
