2024+ Tacoma - Tire Pressure & Wheel Nut Torque
Proper tire pressure affects your Tacoma's safety, fuel efficiency, tire life, and ride comfort. Whether you're checking pressure before a long drive, rotating tires, or installing new wheels, here's what you need to know about tire specs and torque values for your truck.
(Reference: Owner's Manual, pages 532, 620-621)
Tacoma Tire Pressure: PSI Specs, Torque & Cold Inflation​
Tire Age Limit: 6 Years
Even if a tire looks fine, it degrades over time. Any tire older than 6 years needs a professional inspection before you keep using it - rubber dries out and can fail without warning, regardless of tread depth.
When to Replace Your Tires (Safety First)
Replace your tires if you notice any of these signs:
  • The treadwear indicators are showing on a tire
  • You have tire damage such as cuts, splits, cracks deep enough to expose the fabric, and bulges indicating internal damage
  • A tire goes flat repeatedly or cannot be properly repaired due to the size or location of a cut or other damage
Important: Measure Tire Pressure When Cold
All pressures below are for cold tires - measure before you drive or after the truck has sat for 3+ hours. Tires heat up during driving, which increases pressure, so you'll get a false reading if you check right after driving.
Tire Pressure Specifications by Configuration​
17-Inch Tire Options
17-Inch Type A Configuration​
SpecificationValue
Main Tire Size245/70R17 110T
Spare Tire SizeT175/90D18 111M
Main Wheel Size17" × 7J
Spare Wheel Size18" × 4.5T
Main Tire Pressure35 psi (240 kPa, 2.4 bar, 2.4 kgf/cm²)
Spare Tire Pressure60 psi (420 kPa, 4.2 bar, 4.2 kgf/cm²)
Wheel Nut Torque97 ft·lbf (131 N·m, 13.4 kgf·m)
17-Inch Type B Configuration​
SpecificationValue
Tire Size (Main & Spare)245/70R17 110T
Wheel Size (Main & Spare)17" × 7J
Wheel Nut Torque - Steel Wheels154 ft·lbf (209 N·m, 21.3 kgf·m)
Wheel Nut Torque - Aluminum Wheels97 ft·lbf (131 N·m, 13.4 kgf·m)
17-Inch Type C Configuration​
SpecificationValue
Main Tire Size265/70R17 115T
Spare Tire Size245/75R17 112S
Main Wheel Size17" × 7½J
Spare Wheel Size17" × 7J
Main Tire Pressure30 psi (210 kPa, 2.1 bar, 2.1 kgf/cm²)
Spare Tire Pressure32 psi (220 kPa, 2.2 bar, 2.2 kgf/cm²)
17-Inch Type D Configuration​
SpecificationValue
Tire Size (Main & Spare)265/70R17 115T
18-Inch Tire Options
18-Inch Type A Configuration​
SpecificationValue
Main Tire Size265/65R18 114T
Main Wheel Size18" × 7½J
18-Inch Type B Configuration​
SpecificationValue
Main Wheel Size18" × 8J
Wheel Nut Torque Reference​
Critical for wheel safety: Proper wheel nut torque is essential for wheel retention and safe operation.
  • Aluminum Wheels (Standard): 97 ft·lbf (131 N·m, 13.4 kgf·m)
  • Steel Wheels (Some Configurations): 154 ft·lbf (209 N·m, 21.3 kgf·m)
Always use a calibrated torque wrench when tightening wheel nuts. Cross-check your specific configuration to determine the correct torque specification for your truck.
Tire Maintenance​
Checking Your Tires​
Treadwear Indicators:
  • Check if the treadwear indicators are showing on the tires
  • The location of treadwear indicators is marked by "TWI" or similar symbol molded into the sidewall of each tire
  • Check the tires for uneven wear (excessive wear on one side may indicate alignment issues)
  • Check the spare tire condition and pressure if not regularly rotated
Maximum Load of Your Tires​
When replacing tires, verify that the replacement tire meets your Tacoma's load requirements:
Check that the number given by dividing the maximum load by 1.10 of the replacement tire is greater than 1/2 of the Gross Axle Weight Ratings (GAWR) of either the front axle or the rear axle, whichever is greater.
  • For GAWR information: See the Certification Label on your vehicle
  • For the maximum load of the tire: See the load limit at maximum cold tire inflation pressure mentioned on the sidewall of the tire
Important Notes​
  • Cold Pressure Only: All specifications listed are cold tire pressure. Do not bleed air from tires after driving when pressures are elevated due to heat.
  • 6-Year Tire Age Limit: Any tire older than 6 years must be checked by a qualified technician, regardless of tread depth or visible condition.
  • Torque Wrench Required: Use a calibrated torque wrench when tightening wheel nuts. Under-torquing can lead to wheel loss; over-torquing can strip lugs or warp rotors.
  • Check Your Manual: Always verify specifications against your own vehicle's owner's manual before service work.
Official Source:
2024+ Toyota Tacoma Owner's Manual (USA Model OM04041U)
Pages Cited:
  • Page 532 - Section 6-3: Do-It-Yourself Maintenance (Tire Information)
  • Page 620 - Section 8-1: Vehicle Specifications (17-Inch Tire Types A, B, C)
  • Page 621 - Section 8-1: Vehicle Specifications (17-Inch Type D, 18-Inch Types A, B)
This guide is derived from the official Toyota Owner's Manual for 2024+ Toyota Tacoma. Always follow your official owner's manual for warranty compliance and vehicle-specific requirements. This is a reference guide only. For tire replacement or service, consult with a qualified tire technician or your Toyota dealership.
