Time to rotate your tires? Regular rotation keeps your tires wearing evenly and extends their life - here's everything you need to know to do it yourself on your 4th Gen Tacoma.
(Reference: Owner's Manual, pg. 518, 534)
Important: Stick with tires that match the load rating and speed symbol on your door jamb sticker. Mixing different ratings can affect handling and safety.
Source: Owner's Manual Page 534
A note on rough roads: If you do a lot of off-road driving, check your tire pressure more often. Rough terrain can cause slow leaks, and impacts from rocks or potholes can damage tires, wheels, and even body panels.
Before rotating your tires, verify the following from your maintenance checklist:
Source: Owner's Manual Page 518
Before rotating, this is an ideal time to check tread depth across all four tires. Uneven wear patterns (center wear = over-inflation, edge wear = under-inflation, one-sided wear = alignment issues) may indicate underlying problems that should be addressed before or after rotation.
From the owner's manual:
The 4th Gen Tacoma uses a front-to-back rotation pattern where tires stay on the same side of the vehicle. This is a straight front-to-back pattern, NOT a crossover.
Standard Rotation Pattern for 4th Gen Tacoma:
For non-directional tires (most common configuration):
The front tires move straight back to the rear positions on the same side. The rear tires move straight forward to the front positions on the same side.
The owner's manual references following the maintenance schedule for tire rotation intervals:
Toyota recommends rotating every 5,000 to 7,500 miles or at every oil change interval, whichever comes first. Many owners rotate tires at each oil change as a convenient reminder.
Tools Required:
Materials Needed:
None required (unless cleaning wheels while off)
Time Estimate:
Skill Level:
Beginner-friendly (basic mechanical task). Requires safe jacking practices.
Step 1: Prepare the Vehicle
Step 2: Loosen Lug Nuts
Step 3: Lift and Support Vehicle
For efficiency, some owners lift the entire front or rear axle at once using a floor jack at the differential or designated multi-point jack location, supporting with stands at both frame rails.
Step 4: Remove and Rotate Tires
Step 5: Reinstall Wheels
Step 6: Lower Vehicle and Final Torque
Lug Nut Torque Specification:
Step 7: Post-Rotation Checks
Here's what to know about your TPMS after rotation:
TPMS Warning Types
The system uses a 2-type warning system:
Normal Warning:
When "Adjust Pressure" is displayed, the tire pressure warning light comes on and a buzzer sounds when the tire inflation pressure becomes low due to natural air leakage or outside temperature.
Emergency Warning:
When "Immediately Check tire when Safe" is displayed, the tire pressure warning light comes on and a buzzer sounds when the tire inflation pressure becomes low suddenly due to a blowout.
TPMS Display Feature
The 4th Gen Tacoma uses direct TPMS sensors mounted on each wheel. Per the owner's manual (page 537), the tire pressure warning system MUST be initialized after rotating the tires. Do not skip this step.
After rotation:
Rotation Pattern Clarification
The 2024 4th Gen Tacoma owner's manual depicts a front-to-back rotation pattern where tires remain on the left and right sides respectively. This is a straight front-to-back pattern, NOT a crossover.
Community source: Tacoma4G.com
Rotation Interval Recommendation
Rotate every 5,000 to 7,500 miles, or at every oil change to keep things simple. For 4WD vehicles like the Tacoma, some experts recommend more frequent rotation every 3,000-5,000 miles due to increased drivetrain stress.
Community source: BeachCitiesToyotaWestminster.com
Label Your Tire Positions
Use chalk or a marker to label the current position of each tire before removal. This makes reinstallation easier and prevents confusion, especially when managing multiple tires at once.
Community source: TacomaWorld.com
Why Toyota Shows Front-to-Back (Not Crossover)
There are several reasons for keeping the tires on the same side during rotation, including performance benefits and simplifying the procedure. The front-to-back pattern is particularly beneficial for vehicles with TPMS sensors, as it can reduce the likelihood of sensor position confusion (though the 4th Gen Tacoma's direct TPMS generally auto-relearns positions).
4WD-Specific Rotation Frequency
For 4WD vehicles like the Tacoma, some automotive experts recommend rotating tires every 3,000-5,000 miles rather than the standard 5,000-7,500 mile interval, particularly for owners who do significant off-road driving where uneven wear is more common.
Community source: O'BrienToyota.com
Crossing Directional Tires
Directional tires (with arrows on the sidewall indicating rotation direction) must NOT be crossed from side to side. They can only rotate front-to-back on the same side. Always check tire sidewalls before rotating.
Why it matters: Crossing directional tires causes them to spin in the wrong direction, drastically reducing traction and accelerating wear.
Incorrect Lug Nut Torque
Failing to torque lug nuts properly or not using a crisscross/star tightening pattern can lead to uneven wheel seating, warped brake rotors, and potential wheel loosening.
Why it matters: Improper torque can cause wheel vibration, premature rotor wear, and in extreme cases, wheel separation.
Skipping Post-Rotation Tire Pressure Check
Not verifying tire pressure after rotation is a common oversight. Each position on the vehicle may have slightly different pressure requirements.
Why it matters: Incorrect tire pressure after rotation negates some benefits of the rotation and can cause uneven wear on the newly positioned tires.
Skipping the Test Drive and Final Inspection
Not taking a short test drive after rotation to listen for noises, vibrations, or anything that feels off can allow improperly seated wheels or other issues to go unnoticed.
Why it matters: Early detection of installation issues prevents damage and safety hazards.
How often should I rotate my tires?
Toyota recommends every 5,000-7,500 miles. Many owners follow the "every oil change" rule for convenience. Off-road use may warrant more frequent rotation (every 3,000-5,000 miles) due to accelerated uneven wear.
Do I need to rotate if I have a full-size spare?
The 4th Gen Tacoma includes a full-size matching spare. Some owners incorporate the spare into a 5-tire rotation pattern to equalize wear across all five tires. This is optional but extends the life of all tires, including the spare.
What if my tires are directional?
Directional tires (with arrows indicating rotation direction) can only be rotated front-to-back on the same side. They cannot cross to the opposite side. Check your tire sidewalls for directional arrows.
What about different-sized front/rear tires?
The standard Tacoma uses the same size tires front and rear, allowing full rotation. If you have installed a staggered setup (different sizes), side-to-side rotation only is possible within each axle.
Should I reset anything after rotation?
Yes. Per the owner's manual (page 537), the tire pressure warning system must be initialized after rotating the tires. Follow the initialization procedure in Vehicle Settings → TPWS → Setting Pressure for your display type (pages 537-539). Skipping initialization can result in incorrect pressure readings or the TPMS not detecting low pressure in the correct tire position.
This guide synthesizes information from the following owner's manual pages:
Recommended Products:
Tire Rotation Pattern, Rotation Schedule, TPMS After Rotation, DIY Tire Rotation
Safety Precautions
Pre-Rotation Inspection Checklist
| Inspection Point | Criteria |
| Tire Inflation Pressure | Is the tire inflation pressure correct? |
| Tire Condition | The tires should not be damaged or excessively worn. |
| Rotation Status | Have the tires been rotated according to the maintenance schedule? |
| Wheel Nuts | The wheel nuts should not be loose. |
Source: Owner's Manual Page 534Rotate the tires in the order shown.
- Front Left moves to Rear Left
- Front Right moves to Rear Right
- Rear Left moves to Front Left
- Rear Right moves to Front Right
Rotation Schedule Reference
Source: Owner's Manual Page 518Have the tires been rotated according to the maintenance schedule?
Prerequisites
Tools Required:
- Floor jack (or factory jack)
- Jack stands (safety requirement - do not work under a vehicle supported only by a jack)
- Lug wrench or impact wrench (21mm socket for Tacoma lug nuts)
- Torque wrench (for proper re-torquing)
- Tire pressure gauge
- Chalk or tire marker (optional - to mark tire positions)
Materials Needed:
Time Estimate:
- DIY: 30-45 minutes
- Shop: 15-30 minutes
Skill Level:
Step-by-Step Rotation Procedure
- Park on a flat, level surface
- Engage the parking brake
- If equipped, shift transfer case to 2H (not 4WD)
- While tires are still on the ground, loosen (do not remove) all lug nuts approximately 1/4 turn
- This prevents the wheel from spinning when elevated
- Position jack under designated jack point
- Raise vehicle until tire clears ground by 1-2 inches
- Place jack stand under frame rail
- Lower vehicle onto jack stand
- Repeat for all corners as needed for rotation pattern
- Remove lug nuts completely
- Remove wheels
- Move each tire to its new position according to the rotation pattern:
- Front Left to Rear Left
- Front Right to Rear Right
- Rear Left to Front Left
- Rear Right to Front Right
- Mount wheel on hub
- Hand-thread lug nuts to prevent cross-threading
- Tighten lug nuts in a star pattern (not circular) to finger-tight
- Lower vehicle off jack stands
- Torque lug nuts to specification in star pattern
- 2024+ Tacoma: Refer to your owner's manual or door jamb sticker for the correct specification
- Note: The 4th Gen Tacoma uses a higher torque spec than previous generations
- Verify tire inflation pressure on all four tires (check door jamb sticker for specs)
- Re-check lug nut torque after driving 25-50 miles (re-torque interval)
Tire Pressure Warning System (TPMS) Information
Source: Owner's Manual Page 534Your vehicle is equipped with a tire pressure warning system that uses tire pressure warning valves and transmitters to detect low tire inflation pressure before serious problems arise.
TPMS Warning Types
Normal Warning:
Emergency Warning:
Source: Owner's Manual Page 534The tire pressure detected by the tire pressure warning system can be displayed on the multi-information display. The unit can be changed.
After rotation:
- Ensure tire pressures are adjusted to the specified cold inflation pressure before initializing
- Follow the TPMS initialization procedure for your display type (Vehicle Settings → TPWS → Setting Pressure — see TPMS guide, pages 537-539)
- Drive at approximately 25 mph (40 km/h) or more for approximately 10 to 30 minutes to complete initialization
- If the TPMS warning light remains on after initialization, verify all tire pressures are correct and repeat the procedure
Real-World Tips and Context
Pro Tips from the Community
Common Questions
Manual Pages Reference
- Page 518 - Maintenance checklist (tire inspection points, rotation schedule reference)
- Page 534 - Do-it-yourself maintenance (tire rotation pattern diagram, TPMS information)
- Floor jack (3 ton capacity)
- Jack stands (3 ton capacity, pair)
- Torque wrench (1/2 inch drive, capable of reaching your vehicle's specification)
- Tire pressure gauge (digital recommended)
- Tire marking chalk
- Rotation pattern and TPMS information: Page 534
- Maintenance checklist and schedule reference: Page 518
- Tacoma4G.com
- TacomaWorld.com
- BeachCitiesToyotaWestminster.com
- O'BrienToyota.com
