2024+ Tacoma - Wiring Auxiliary Switches (AUX 1-3)
Your 2024+ Toyota Tacoma features a factory pre-wired auxiliary switch system that provides convenient 12V DC powered circuits for connecting aftermarket accessories. This thread consolidates information from pages 488-491 of your owner's manual and adds real-world community insights to help you select and use the right auxiliary circuit for your needs.
Tacoma Auxiliary Switches: Wiring, Specs & AUX 1-3 Setup​
WARNING - For safe use:
Do not cut or modify the wiring harness of the vehicle body when connecting accessory electronics. Failure to do so may lead to an accident resulting in property damage, serious injury, or death.
Source: Owner's Manual page 491
NOTICE - To prevent damage to the Auxiliary switches:
  • For information on repairs, contact your Toyota dealer.
  • Accessory wiring harness pigtails can be purchased from your Toyota dealer.
How Auxiliary Switches Work​
Your Tacoma provides three powered auxiliary circuits (AUX1, AUX2, AUX3) plus one non-powered rear circuit (AUX_RR) for complete accessory integration.
Operating Principles:
  • Activation: Switches only operate when the ignition is in the ON (IG ON) position. This prevents battery discharge when the engine is off.
  • Indicator Illumination: When an auxiliary switch is pressed, the indicator light on the switch illuminates to confirm activation.
  • Power Management: If your vehicle's power usage increases and battery voltage drops, the auxiliary switch system automatically disables to protect the battery. The system resets automatically when power usage decreases and battery voltage recovers.
Connection Requirements:
  • Remove the waterproof cap (if present) from the vehicle wire harness connector
  • Connect your accessory wiring harness pigtail to the vehicle connector
  • All accessory wire harness pigtails must be purchased through your Toyota dealer
Powered Circuits​
CircuitAmperageWire ColorConnector Locations
AUX115ABlackEngine compartment, cabin
AUX210AGreenEngine compartment, cabin
AUX35AWhiteEngine compartment, cabin
Source: Owner's Manual page 490
Non-Powered Rear Circuit​
AUX_RR (Rear Auxiliary - Non-Powered):
  • Amperage: 20A
  • Wire Color: Black
  • Fuse Location: Under right-rear seat
  • Connector Locations: Engine compartment, rear frame
  • Use: Ground-only applications or relay-controlled systems
Real-World Tips & Community Insights​
Pro Tips​
  • Use Clean Wire Routing: Clean routing of accessory wiring ensures long-term reliability. (Source: Tacoma4G.com)
  • Leverage Multiple Connector Locations: Plan your accessory layout to use the most convenient connector location rather than running long wire runs. (Source: Tacoma4G.com)
  • Plan Amperage Distribution: Distribute loads across AUX1 (15A), AUX2 (10A), and AUX3 (5A) based on actual power draw. (Source: 4th Gen Tacoma Forum)
  • OEM Harness Pigtails Are Plug-and-Play: Toyota Genuine pigtails connect directly without requiring splice work. (Source: Tacoma4G.com)
  • Exceeding Fuse Ratings: A 40" light bar drawing 16+ amps exceeds AUX1's 15A limit, causing fuse failure. (Source: Tacoma4G.com)
  • Confusing IG-ON Operation: Switches only operate with ignition ON. This protects battery but can surprise owners expecting constant power. (Source: TacomaWorld)
  • Overlooking Wire Gauge: Use correct wire gauge for each circuit. Improper gauge causes voltage drop and overheating. (Source: 4th Gen Tacoma Forum)
  • Not Planning Rear Power: Rear connectors don't have constant factory power. Plan accordingly for rear accessories. (Source: 4th Gen Tacoma Forum)
Selecting the Right Circuit​
Accessory TypePower DrawCircuit
LED lights, sensors1-3AAUX3
Single light bar, fans5-10AAUX2
Dual light bars, compressors10-15AAUX1
Maintenance and Service​
What You Can Do: Verify switch illumination, confirm power cuts when ignition OFF, monitor for intermittent connections.
What Requires Dealer: System repairs, replacement pigtails (genuine only), fuse replacement.
Manual Pages: 488-491 (Wiring Auxiliary Switches)
Web Sources: Tacoma4G.com, 4th Gen Tacoma Forum, TacomaWorld
Always verify specifications in your vehicle's owner's manual.
