2025 Tacoma TRD Pro on Spidertrax 1 Inch Wheel Spacers Improved Stance & Clearance
8runneroffroad
Portland, OR
8runneroffroad.com
This 2025 Tacoma TRD Pro came through the shop for a simple but solid upgrade — a set of Spidertrax 1.00” wheel spacers. Sometimes it’s not about going bigger with lifts or tires, but about dialing in the stance and clearance so everything works together.
2025 Tacoma TRD Pro build:
  • Spidertrax 1.00” Wheel Spacer Kit (x4)
  • Installed and torqued to spec with OEM hardware
Why spacers? They push the wheels out just enough to make the truck look wider and more planted without going overboard. They also help with clearance if you’re planning on running bigger tires or certain aftermarket wheel setups. On the road and trail, that wider track gives a bit more stability too.
It’s a small mod that makes a big difference in both looks and function. If you’ve been thinking about spacers on your Tacoma, 1.00” is a sweet spot — noticeable stance improvement without being excessive.
8Runner Off-Road & Overland Outfitters
10160 Southwest Nimbus Avenue, Suite F2
Tigard, OR 97223
Phone: (503) 352-4629
Email: nathan@8runneroffroad.com
Website: www.8runneroffroad.com
