- Apr 29, 2025
Tailgate Panel Buyers Guide for the 2024+ Tacoma
I was looking into tailgate panels for the new Tacoma and figured I’d put this together as a resource. The factory tailgate isn’t exactly built for comfort or function when you’re sitting, cooking, or loading gear. Aftermarket panels and covers add a flat work surface, and in some cases, make the tailgate more comfortable to use.Why Would You Want a Tailgate Panel
- To turn your tailgate into a usable surface for cooking, sitting, or working
- To protect the factory finish from dents, scratches, and weather damage
- To add grip, comfort, or modular gear mounting for camping and overlanding
SnailArmor
Built from aluminum with a textured finish, this one’s designed to add durability and grip.
- Powder-coated aluminum
- Adds traction for loading gear
- Sleek, modern look
BillieBars
Durable cover built to work with their rack systems or as a stand-alone upgrade.
- Aluminum panel with tie-down points
- Matches BillieBars gear setups
- Rugged build quality
Xtrusion Overland
A modular, bolt-on tailgate cover with slots for mounting gear.
- Modular design with accessory slots
- Black powder-coated aluminum
- Strong, trail-ready option
Mountain Hatch
A heavy-duty, food-grade cutting board replacement that turns your tailgate into a flat, easy-to-clean work surface.
- Food-safe, UV-stable material
- Cleans easily after camping or cooking
- Direct swap for factory panel
BedRug
A softer option that protects the tailgate and adds comfort if you’re kneeling or sitting on it.
- Carpet-like surface over foam backing
- Resists stains, chemicals, and mold
- Easy to clean with water
LASFIT
A simple cover that helps seal and protect the tailgate gap from dirt and water.
- Protects against weather intrusion
- Flexible, lightweight material
- Affordable add-on
OVS
Made from carbon rubber, this one adds grip and durability while staying easy to clean.
- Anti-slip surface
- Weatherproof material
- Easy hose-off cleanup
Final Thoughts
Tailgate panels are one of those upgrades that can make a huge difference in how you use your Tacoma day to day. Some go for flat, food-safe surfaces, others for modular mounting and durability, and a few keep it simple with added comfort and protection. The right choice comes down to whether you want your tailgate to be a cooking station, a gear hauler, or just a cleaner, tougher surface.
