Alcan Spring: Coil Spring To Leaf Pack Conversion Kit For 4th Gen Tacoma
Now this is something I wasn't expecting... the 4G just got coil springs and a 5-link in the rear (with sway bar) and the people at Alcan Spring have come up with a conversion kit to change everything over to a leaf pack setup.
It looks like you retain the factory front lower link mount (which is now the mount for the front of the leaf pack), and the rear gets a bolt-on hanger. Then the pack goes under the rear axle (spring under kit). They're running it with what (I believe) is a 2.5 remote reservoir rear shock from Radflo and the OEM bump stop. Since they build custom leaf springs, I'm sure they used their own. Looks pretty heavy duty. From what I can tell, no more upper/lower links, no panhard/track bar, and no sway bar. Same setup as the 2nd/3rd Gen Tacoma had.
I wanted to learn more about this, so I fed all the required info and links to chatgpt - this is what it came back with for the "why"... I read through it and it all seems to be correct. Would love to hear what everyone thinks!
No link yet, I just found this teaser video from Alcan.
Their main site: https://www.alcanspring.com/ - they are based out of Colorado.
Good question — at first it sounds backwards since Toyota just upgraded the Tacoma to coils. But there are some real reasons why an aftermarket company might offer a coil-to-leaf swap kit for the 2024+ Tacoma.
Why Swap Back to Leaf Springs?
1. Payload & Towing Capacity
  • Leaf packs naturally distribute weight over a larger surface area and resist sag under heavy loads.
  • For people hauling constant heavy payloads (contractors, overland rigs with campers, flatbeds, or service bodies), a leaf pack can handle that better long-term than coils.
2. Simplicity & Durability
  • Leaf springs = fewer moving parts.
  • A 5-link has multiple bushings, joints, and arms that wear out. Leafs are old-school but very reliable in harsh, high-mileage, work-truck use.
3. Cost & Serviceability
  • Replacing leaf packs is cheaper and easier than replacing multiple arms, bushings, and coils.
  • For fleet or work use, leafs can be more cost-effective to maintain.
4. Custom Load Tuning
  • Leaf packs can be built to exact needs — light-duty for comfort, heavy-duty for campers, progressive packs for mixed use.
  • Coil spring tuning exists too, but leaf packs are often preferred when the truck always has weight on it.
5. Proven in Certain Applications
  • Many expedition-style or utility trucks worldwide still run leafs in the rear for load-bearing reasons.
  • Someone who views their Tacoma as a workhorse first, adventure truck second, may actually prefer a leaf pack.
So basically:
  • Coils (5-link): comfort, flex, modern ride.
  • Leafs: strength, simplicity, heavy hauling.
The aftermarket might target people who are maxing out payloads with slide-in campers, flatbeds, or constant overlanding builds — situations where coils could sag or wear faster.
This got my attention. I've been running Alcan springs on my 4Runner for over 20 years. One issue with my Gen4 Tacoma is I have a camper/canopy and the coils don't handle the weight as well. I have Dobinson 821 springs with a 1/2" spacer.
I just watched the video. Unfortunately, the shackle mount uses the same mounting location as my rear bumper.
Pappy, it seems that you know a little bit about, well, everything! Haha. That's not a bad thing. I always appreciate your commentary.
Oh, that's a bummer. Considering they do a lot of custom work, maybe it could be modified?
You are a mind reader. I had the same thought. If I decide to go that direction I will give them a call, or drive up to Grande Junction and show them the issue. I think there is an easy solution.
Let us know if you do!
