Best Aftermarket Headlights for 4th Gen Tacoma
Putting this post together as a resource to track aftermarket headlight options as they start showing up for the new Tacoma.
For me, the biggest draw to swapping headlights is the way they transform the truck’s look. The factory lights aren’t terrible, but aftermarket setups usually bring sharper DRLs, blacked-out housings, and lens designs that give the front end a more aggressive presence. A solid headlight upgrade can completely change the personality of the truck. The TRD Pro headlights are a good step-up, but some of the designs coming from aftermarket companies push it even further.
The performance side matters too: better projectors and LED tech mean safer night driving and more visibility when you’re out on the trail.
I’m really interested to see which brands drop their versions first and how they stack up against the factory options.
Alpharex NOVA​
The AlphaRex NOVA headlights bring a sharp, modern look with tri-projector LED output. They deliver stronger visibility while adding sequential turn signals and a bold DRL design.
  • Tri-projector LED low and high beams
  • White or amber DRL with sequential turn signal
  • Plug-and-play install for halogen models
Check them out online:
AlphaRex LUXX​
The Alpharex Luxx headlights step up the look with a sleek projector layout and animated lighting features. They provide a clean upgrade with improved output and style.
  • Dual-beam LED projectors with sharp cutoffs
  • Activation sequence with white DRL and sequential amber turn signals
  • Sealed housing with UV-coated lens for long-term clarity
Is there any other brands we should keep an eye on? Anyone currently running aftermarket headlights?
I remember when alpharex announced the headlights, it looked okay. The day I went to overland expo and saw it in person, very impressed by the quality.
So far hasn’t seen many Tacoma's with the alpharex.
Definitely need to keep this one updated as new options hit the market. Hopefully it doesn't take forever. I imagine Morimoto has a set in development, excited to see what they come up with. For now, I have the NOVA Alpha Black on order (wanted that full DRL). I ran AlphaRex headlights on my 3G and they were great. Beam pattern could have been a little bit better, but I couldn't really complain. I'm sure these next gen lights are better.
