Bolt on Trackbar Correction Kit for the 4th Gen Tacoma
TacomaForce
www.tacomaforce.com
2024 DCSB TRD Off-Road
Dr KDSS Pan Hard Relocation Bracket in Stock!
We’re stoked to announce that TacomaForce is now carrying the Dr KDSS pan hard relocation bracket for the 4G Tacoma.
If you’ve recently lifted your rear suspension, you’ve probably noticed how badly the panhard angle gets thrown off. Instead of the axle moving up and down cleanly, it starts shifting side to side, which gives you an unstable, wandering feeling on the road or trail. The B.O.T.C.K. (Bolt on Trackbar Correction Kit) fixes that by raising the axle-side pivot and getting the bar back close to level. The result is better stability, predictability, and the truck cycling the way it should.
There are two fitment options: the Shorty for 1.5”–3”+ of rear lift, and the Standard with dual mounting holes for 3”+ lifts. On top of that, you can choose your look with multiple finishes: Standard Black, Red, or King “like” Blue.
In stock now at TacomaForce:
Take 5% off all DRKDSS parts with code: 4gtacopanhard
https://www.tacomaforce.com/products/botck-trackbar-relocation-kit-4th-gen-tacoma
Check out the install here: https://6thgen4runner.com/threads/d...ocation-bracket-for-6th-gen-4runner-2025.764/
  • Like
Reactions: BG
Must have mod for Tacomas with a lift to prevent rear bump steer. The DR KDSS panhard relocation is held in place with three (3) bolts while most of the brackets provided in some of the lift kit options out there (the Rough Country kit I'm currently running, Pro Comp, etc) are held in place with only one (1) bolt. There is no internal support and/or outside support... just one single bolt holding it on. The problem is that when there is any left to right leverage/momentum on the factory panhard bushing (passenger side), it pushes and pulls the bracket back and forth, which can potentially be very dangerous if it were to fail.
Here is a look at the bracket that came with my lift kit. Pictured below. Given enough leverage from the panhard, that bracket is likely to move, being on one single pivot point.
I will be upgrading to the DR KDSS pan hard relocation bracket in the next couple of days. The BOTCK has internal support to spread the load, and outside support all the way around the factory bracket, providing an incredibly strong mounting point for the panhard.
I highly recommend upgrading to the BOTCK kit from DR KDSS. It's extremely stout and held in place with three grade 8 bolts. It's not going anywhere.
  • Like
Reactions: BG
I have one waiting. Just need to install my new springs and coming lift kit.
