- Mar 12, 2025
- Website
- c4fabrication.com
- YouTube
- Visit YouTube
- Parts Offered
- Premium Fabricated Parts for the 4th Gen Tacoma (and gobs of other Toyotas...)
- 2024 TRD Sport
The rear diff is basically the lowest hanging point of your undercarriage. It often gets caught on rocks and that can cause damage to the housing as well as the drain plug.
Our rear diff skid bolts directly to the third member assembly and housing for total protection. It extends to protect the U-joint and driveshaft yoke. It's made from 3/16" steel for solid impact resistance.
The skid only fits the smaller rear differential available on the Tacoma. It will not fit hybrid models or TRD models with manual transmission.
If you're looking to dial in your underbody protection, check out our skid plate!
c4fabrication.com
- protects housing, third member, U-joint, and yoke
- bolt on install
- 3/16" steel construction
- hardware included
- weighs 22 lbs.
- comes in raw or powder coat finish
- does not fit hybrid or TRD models with manual transmission
- free shipping
- made in the USA
C4 Rear Differential Skid plate for 2024+ Toyota Tacoma
Protect your 4th Gen Tacoma with a 3/16" steel rear diff skid. Bolt-on design shields the differential, U-joint & driveshaft from trail damage.
