757Tacoma
- Feb 17, 2025
- 2025 DCSB TRD Sport
I changed out the OEM fog lights for the Cali Raised Fog Light Upgrade and I can not be any happier!
Upgrading your Taco's fog lights is a perfect way to boost visibility, enhance safety, and add a personal touch to your trucks design. Whether you’re a frequent off-roader, a pavement only driver, or someone who regularly drives through harsh weather, these Cali Raised fog lights offer both practical and aesthetic advantages. It’s a small change with a big impact.
The installation took approximately 2-3 hours. You need to remove the front end to access the fog lights, you can do it with minimal basic tools. Phillips head screwdriver, 10mm, flat head screwdriver, and a trim pry tool. They are complete plug & play. You do not need to trim or remove anything for them to work.
I highly recommend changing out your OEM fog's and getting the Cali Raised Replacement Fogs!
Direct link to product - https://caliraisedled.com/products/fog-light-replacement-kit-for-2024-tacoma
