- Apr 29, 2025
Cali Raised has an 8 switch control system out for the 2024+ Tacoma. It’s a solid way to run all your accessories off one hub instead of stacking random switches and wiring everywhere. Makes installs way cleaner and gives you one spot to manage everything from lights to compressors.
The best part is they also have an OEM style switch panel that snaps right into the dash. No cutting, no drilling, and it actually looks factory once it’s in. Way nicer than bolting on a universal panel.
Anyone tried this setup yet? Looks like one of the cleaner solutions if you’re planning to load your truck with gear.
Check it out!
Switch Control: https://www.tacomaforce.com/products/vehicle-accessory-8-switch-control-system-blue-backlighting
4G Trim: https://www.tacomaforce.com/products/oem-style-switch-panel-for-2024-toyota-tacoma
Check it out!
