- Apr 29, 2025
When I first went to wire my lights into the factory AUX buttons I was really confused to say the least. I was not well experienced with vehicle wiring and I thought it would be simple plug and play, but there are capped connectors, different amp ratings, and a lot of mixed info out there. I ended up watching a bunch of videos before it finally made sense, so I wanted to put all the info in one place.
The basics:
- The Tacoma comes with three AUX switches from the factory on certain trims
- AUX1 is 15 amps, AUX2 is 10 amps, AUX3 is 5 amps
- Each AUX switch already has its own relay and fuse in the factory fuse box
- The connectors are capped and tucked on the driver side of the engine bay near the fuse box
- There are three plugin locations around the truck 1 in the engine bay 1 underneath near the front and 1 in the rear
The harnesses:
- Toyota includes 2 harnesses i've heard some people getting 3 but I only got 2
- The main harness has 4 colored wires on one end and a plug in adapter on the other
- The second harness is identical to the first but only has 3 wires if you want to send power to the rear
- Main harness wire colors on the AUX harness usually line up like this:
- Black = AUX1 (15A, good for bigger stuff like a front light bar)
- Green = AUX2 (10A, good for medium loads like ditch lights or compressor trigger)
- White = AUX3 (5A, best for accent lighting or low-powered accessories)
- White/Black Striped = Ground
- Second harness wire colors on the AUX harness usually line up like this:
- Black = AUX1
- Green = AUX2
Wiring steps:
- Splice your accessory to the desired wire
- Locate the capped connectors
- Remove the weatherproof cap
- Insert factory wiring harness
- Enjoy your easy installation
Things I wish I knew:
- The AUX switches are ignition-switched from the factory; they don’t work with the truck off unless you rewire the relay box
- Each AUX circuit already has its own fuse and relay; you don’t need to add more unless you’re running higher draw gear
- There are aftermarket adapter harnesses that plug right into the Toyota pigtails if you don’t want to splice anything
- Make sure you look up your accessories draw beforehand
Accessory ideas:
- AUX1 (15A) is perfect for a front light bar or multiple pods, especially through a relay
- AUX2 (10A) works great for ditch lights or a compressor trigger
- AUX3 (5A) is a good fit for accent lighting, grille lights, or to act as a relay trigger for rear scene lights
- The bed 12V outlet is fine for bed LEDs, a small work light, or charging smaller electronics, but not for anything high draw
