KC HiLiTES Products For the 4th Gen Tacoma
KC HiLiTES
Arizona
www.kchilites.com
Hey everyone,
We’re excited to join the 4GTaco community officially. KC HiLiTES has been building performance lighting for off-roaders, racers, and explorers since 1970... and we’re here to support the next generation of Tacoma owners with purpose-built lighting systems for the 2024+ platform.
From the new Gravity® Titan™ LED Light Bar to our modular FLEX ERA® pod series, every KC system is designed, tested, and assembled in Flagstaff, AZ to handle the same trails and conditions you do. Our engineering team has been working closely on fitment for the new 4th Gen Tacoma, ensuring clean installs, factory integration, and high-output performance.
Highlighted Tacoma-Specific Products:
Gravity® Titan™ LED Light Bar Bundle – A full-width roof-mounted bundle built for maximum forward projection and low-glare pattern.
Gravity® Pro6 LED Light Bar Bundle – The iconic round light bar with modular linking, available in 7- or 8-ring setups for Tacoma.
Platform One™ Roof Rack – Designed specifically for the 2024–2025 Tacoma with integrated lighting channels and full load capacity.
A-Pillar / Ditch Mount Bundle – Includes our precision brackets and paired lights for balanced beam spread and trail-side visibility.
Cyclone LED Engine Tray Kit – Compact lighting for under-hood illumination, now available for Tacoma and Land Cruiser 250.
Backup Light Mount & FLEX ERA® 1 Pod Bundle – Rear-facing auxiliary lighting with dedicated mounting plates for the 24–25 Tacoma.
We’ll be using this thread to share product development updates, lighting tips, install examples, and member discounts as they roll out.
If you’ve got questions about beam patterns, wiring integration with OEM switches, or fitment on your specific trim, we’re happy to help.
You can also explore the full KC Tacoma lineup here:
Thanks for having us. See you on the trails.
— KC HiLiTES Team
Flagstaff, Arizona
“Adventure Further®”
I've got a bunch of KC lights going on the truck soon! Backlights are about to change my life...
