New Member in TX
Fused11
2026 Trailhunter
2026 TrailHunter. Made the switch after retiring my F150. Only real mods so far are a set of Nitto Ridge Grapplers (285/65/18). Hoping to pickup some insight on some topics including info on the hybrid system.
Heck yeah! Welcome and congrats. Post some pics!
I have a hybrid myself, happy to help. I've drafted a bunch of threads on various topics here.
One thing I’m trying to figure out is which relay to pull for the 41.22 kill switch.
Ahhhh. Wish I could be of more help. I assume it would be something related to ignition. I'd have to dig deeper. Did you try reaching out to 41.22?
Sadly it doesn’t work. It appears it does not work on the 2026. Gonna go with a Ravelco plug instead. Absolutely foolproof.
Oh bummer. What's the other plug you mentioned? First time hearing about that.
It’s called a Ravelco plug. Been around for a long time. Pricey. But basically foolproof. Dealers put them on some higher end cars.
I'll take a look! You could also take a look at pedal commander. It's a throttle response controller. The latest units have anti-theft built into the app. So not only can you modify your throttle sensistivity, but you can lock out the gas pedal as well. Something to think about. It's around $300 if I remember correctly.
Ok so I am a complete dumbass. The 41.22 WILL work. I mistakenly watched a video (not theirs) that showed the passenger side fuse/relay box. The starter relay is on the drivers side. 100% my fault. I’m used to more simple (non-hybrid) layouts and didn’t consider there was another box. Duh…it even said FUSE/RELAY on it. One of the dumbest things I have ever done. Their product is slick.
