derrenp
Brand new Taco, bed rail plastic caps appear to be secured by little pieces of Styrofoam glued to the caps and to the metal box all letting go causing the plastic caps to be loose and lifting up. Dealer tried re gluing back down but glue ate the styrofoam so waiting for at least one new bed cap from dealer as other one still holding. New ones on lot all doing the same. Even if you put a little pressure on the inside edge of the plastic bed cap it lifts leaving a space as seen in the pics I attached.
