- Apr 29, 2025
Top 10 Tonneau Covers for 2024+ Tacoma
I’ve been looking into tonneau covers for the Tacoma and realized there are a ton of options out there, so I put this list together to compare the ones that stood out the most. A cover is one of those upgrades that changes how you use the truck bed, keeping gear dry, locking things up when needed, and even helping with MPG a bit. The tricky part is figuring out which style actually fits the way you use your truck.Who Tonneau Covers Are For
If you’re tired of throwing gear in the bed and having it sit out in the open, a tonneau cover makes a big difference. They’re for anyone who wants to:- Keep gear protected from weather and theft
- Decide how much of the bed to keep open vs covered
- Add a cleaner look to the truck without going full camper shell
What To Think About
Before picking one, I’d think about how often you need full bed access, whether you’ll ever mount things on top, and how much security matters to you. Soft roll-ups are cheap and easy, but hard folding and retractables give more strength and peace of mind.UnderCover Select Hard Folding
I like this one because it’s a straightforward hard folding option. Strong panels, folds toward the cab, and doesn’t look bulky.
- Folds forward for full bed access
- Cable release on both sides
- Weather-sealed edges
BAK Revolver X4S
This one’s clever: it rolls up but still uses aluminum slats for strength. You get the security of a hard cover without losing bed access.
- Rolls up on rails behind the cab
- Aluminum slats with locking system
- Low profile look
Extang Trifecta Signature 2.0
Good choice if you want something lighter and simple. It’s a soft tri-fold, easy to flip open, and doesn’t cost as much as the hard covers.
- Marine-grade vinyl
- Upgraded clamps for security
- Tri-fold design for partial access
TruXedo TruXport
This is one of the entry-level roll-up covers. Not fancy, but it does the job if you just want to keep gear dry without spending a ton.
- Soft roll-up vinyl
- Lightweight and easy to use
- Basic clamp system
RetraxPRO MX
If budget isn’t an issue, this is one of the premium retractables. Heavy-duty aluminum, retracts on rails, and you can even put weight on top.
- Ball-bearing roller system
- Strong aluminum slats
- Flush design with tight seals
Peragon Retractable
Peragon’s system is unique because the whole cover can actually come off when you don’t need it. It’s all aluminum, retractable, and lockable.
- Retracts toward the cab
- Full lock system
- Fully removable design
Rough Country Low Profile
For the price, this one gives you a flush hard tri-fold look without going too far up the ladder in cost.
- Low profile hard folding
- Simple latch system
- Rapid install
Rough Country Roll-Up
Same brand, but a different take, this one’s the soft roll-up version. Budget-friendly and easy to throw on.
- Lightweight build
- Quick install
Rough Country Soft Roll-Up
An even simpler version for people who just want basic coverage.
- Budget soft cover
- Affordable
- Easy clamps
DiamondBack HD
This one is in a different league. If you’re hauling heavy gear or want to load stuff on top of the cover itself, the DiamondBack is built for it.
- Can hold up to 1,600 lbs
- Weather-sealed and lockable
- Rugged aluminum build
