Adding Fog Lights To SR?
d3r3k
Has anyone added fog lights to a 4th Gen SR, and do you know if it's pre-wired?
I’m wondering the same thing I have a sr as well.
I ended up going with set of fog lights off eBay which came with harness & OE style switch. I installed them on steel front bumper I got off Lexland. Overall not bad but they aren’t all that bright so plan on going with cali raised fog lights and will be swapping them out whenever I get time to install winch I have. Not sure how one would go about installing them on OE plastic bumper, if my memory serves me right there was not any mounting tabs or mounts on the plastic oe bumper. I’m sure you could thru bolt them if you wanted.
The factory fogs mount to the inside of the front bumper cover. Not sure about a truck that doesn't come with fog lights, but it MAY still have the spot for them and you'd have to cut a hole to make them fit. Either way, you cut or remove the cover for the factory spot, and I'm sure you can figure out how to mount an aftermarket set. Then you'd just wire to a switch. Cali Raised has OEM style switches to keep it looking factory. Not sure about existing wiring.
I have my old factory ones laying around. Basically brand new. Not sure if you want to grab them for a killer deal and try and make them work. Let me know!
How much for those? Interested.
Real cheap man. But I would try and confirm that you have some kind of harness first. Otherwise, it could be quite a wiring project. Unless you're up for it.
Ideally, grey cloth (SR trim)... if somebody...
