Affordable UCAs From JBA Offroad - STD HC Version
JBAoffroad
JBA Offroad, 704 Forman Rd, Souderton, PA 18964
jbaoffroad.com
Parts Offered
Upper Control Arms
2024 TRD Offroad Tacoma
Hi everyone!
JBA Offroad here. Wanted to quickly share our upper control arm for the new Tacoma.
The STD HC UCA is a high performance arm at a reasonable price point.
  • Designed specifically for 2024+ Toyota Tacoma models
  • Ideal for trucks running a 1”–3.5” front lift
  • Corrects caster and alignment issues caused by lifting
  • Built from heavy-duty DOM steel for strength and longevity
  • Features JBA’s Max 90 ball joints for increased articulation and travel
  • Uses patented EZ Lube bushings for easy maintenance and longer bushing life
  • Greaseable design helps reduce squeaks and premature wear
  • Bolt-on installation using factory mounting points
  • Powder-coated finish for corrosion resistance
  • Made in the USA and built for daily driving and off-road use
If you have any questions, fire away!
