h4ngman tacoma
- Jul 3, 2025
- Lunar 2021 TRD Pro
Wanted to share a connection solution for the Raptor lights on your pro grille. A couple of people who got the pro grill with Raptor lights installed on their truck have talked about having troubles connecting the Raptor lights. There's no need to add a switch for the Raptor lights, as there's a simple solution for it.
First, just get a fuse tap, find the fuse for your DRL or fog lights, and simply connect them together. The connection is done by simply attaching the red wire from your Raptor lights to the fuse tap and grounding the black wire to a nearby ground body.
It's as easy as that. When you're done, you can now turn on your Raptor lights with your fog lights. This solution works perfectly without any complex wiring. Hope this helps.
