Lasfit LED Backlights Might be the Best Backlights Option for your Truck Plus a Free Installation Tip
Rico's4G
Tacoma 2024 Underground TRD Off-Road
Does anyone else use Lasfit LED backlights? I've had mine for over 6 months now. They work perfectly. Honestly, sometimes I even forgot about them. That's the way it should be.
Just to share a tip for anyone who hasn't installed them yet on their truck. They only work when they are in the bulb sockets one way. So put the bulb in the socket and test them before placing the socket back into the light housing.
If they don't work, just pull the bulb out and switch them around. I hope this makes sense.
On a level, how much MPG do you guys losing on...
First 4th gen snorkel I've seen aftermarket.
Has anyone removed the inside tailgate panel...
If you didn't know, when you lift the rear end...
So... we hit some pretty solid rock crawling a...
The 4th Gen has proven itself to be a solid...
I know fuel efficiency is always a hot topic...
Hey everyone. If you've done some deeper dives...
