OEM Style Switch Panel for 2024+ Tacoma – Factory Fit for the Cali Raised 8 Switch System
Cali Raised LED
VENDOR
Fortworth, TX
caliraisedled.com
Parts Offered
Rock Sliders, Bed Racks, Bumpers, Skid Plates, Lighting & More
2024 DCSB TRD Off-Road
Wiring up lights, air systems, or other trail gear in your 2024+ Tacoma? This OEM Style Switch Panel from Cali Raised LED is a direct-fit solution that replaces the factory dash tray with a clean, purpose-built mount for the Cali Raised 8 Switch Control System. No cutting, no drilling—just factory-style integration that looks and feels OEM.
Highlights:
  • Fits all 2024+ Toyota Tacoma trims
  • OEM-style snap-in design – uses stock mounting points
  • No modifications required – drop-in install with no tools needed
  • Injection-molded ABS plastic – 1/8" thick, built to handle heat and trail abuse
  • Factory-matched texture – blends right into the interior
Install Overview:
  • Installs in under 10 minutes
  • Compatible only with the Cali Raised LED 8 Switch Control System
  • Designed to replace the center storage tray in the dash
Does it fit other switch types?​
No—this specific panel is molded to fit the Cali Raised 8 Switch Control System only. If you’re looking to run standard Toyota-style tall switches, check out our alternate switch panel for 2024+ Tacomas.
What's the benefit of this panel?​
It gives you clean, central control over your rig’s electrical accessories with no mess of universal mounts or holes drilled in your dash.
For a factory-style solution to manage your trail gear, check out the OEM Style Switch Panel for 2024 Toyota Tacoma—designed for the Cali Raised 8 Switch Control System and built to handle serious use.
This weekend, I’m going to replace the stock...
After trying out several other suspension lift...
Hey everyone, so I'm planning a small project...
I know some owners might have been considering...
Finally, for those of us who have removed the...
So I just had a Tacoma TRD Pro for a week and...
Installing the Lasfit side-steps solo was a...
