Riley_monthule
- May 20, 2024
Alright everyone I just did the first oil change on my Tacoma and thought I'd post a guide since I can't seem to find a good one anywhere yet.
Update & Edit: I'm actually going to change my oil interval recommendation to 3-4k miles or every 6 months based on the new "The Car Care Nut" (Video Link) video on YouTube where he specifically talks about the new Toyota turbo engines. I've also done a deep dive into the science of oil changes and why they're so important and this recommendation adds up. I'm just a moron on the internet though so I'll explain my logic.
Oil is used not only to lubricate the turbo but to also cool the turbo along with the coolant. This higher heat degrades the oil faster so turbo engines generally need more frequent oil changes. Cold starts on direct injected engines also allow more gas to seep past the piston rings which again degrades the oil faster.
Think of how well gasoline cleans up an oil spill. It breaks down oil very fast. That's also why if you don't reach 3-4k miles in 6 months you still want to change your oil. The gas and oxygen in the oil are still breaking it down over time.
Now for everyone saying "I'm going to follow what Toyota says and do the 10k oil change intervals, they know best"...
Recommended oil change intervals are regulated by the EPA nowadays to be better for the environment not what's best for your truck. Fewer oil changes mean less waste oil and supposedly better for the environment. So in summary Toyota recommendations don't mean squat for making your truck last forever.
As for the environment, if more oil changes mean you get 100k extra miles out of a truck that carbon tax was paid off decades ago that sure seems better for the environment than buying a new vehicle which creates a ton of extra carbon. Actually, 5.6 metric tons to be exact
Also good to remember on any turbo vehicle that if you're doing fast driving like highway driving or especially spirited driving/off-roading to let the car sit for a minute or two before shutting it off. The turbo gets extra hot during these periods and if you immediately turn your engine off it'll bake the oil in the turbo oil lines.
Over enough time this will clog the passages just like clogged arteries and destroy the turbo. In my 24 Taco owners manual this is actually mentioned and recommended. Alright, I think I've made my case. Happy oiling!
Step by Step Photos:
- Oil filter: 90915-yzzn1 (otherwise known as the N1 filter)
- Oil: 6Q of Toyota SAE 0W-20
- Take both "skid plates" off. 4 bolts each.
- Take oil filter off and place drain pan underneath. My filter was wayyyyyy too tight from factory so you might have some trouble taking it off. I ended up putting a screwdriver through the end of it to get leverage and turn it off.
- Prefill new filter as much as possible and screw it on hand tight.
- Find the oil drain plug. I included a pic below of the location. Drain the oil and be careful. On mine no matter how I positioned the drain pan the oil would hit it and perfectly rainbow onto the ground. A filter mat placed in the pan would help this. Drain the oil completely, replace the blue washer on the drain bolt and put it back in. The official factory torque spec is 30lbs but that felt like way too much so i just did 15lbs which has been fine and felt plenty tight.
- Put 6 quarts of Toyota SAE 0W-20 in.
- Check the dipstick to make sure the oil is in and at the proper level
- Start the truck and look under it to make sure theres no leaks and everything working correctly
- Turn the vehicle off and replace the skid plates
- Enjoy your new oil change knowing you're taking proper care of your vehicle!
- Change the oil every 5k miles!! I know Toyota says every 10k but if you plan on having the truck for over 100k miles especially with a turbo engine 5k is the way to go. This debate is endless but the car care nut and the motor oil geek on youtube both know more than you and agree that 5k miles is the correct interval.
