4g tacoma almost genius oil filter design
Riley_monthule
They almost solved the classic oil filter location getting oil everywhere problem. While I do appreciate the funnel to avoid getting oil on the frame and it does work with higher flow it's just barley close enough to still coat the frame a require some clean up. That being said doing an oil change on this thing is dumb easy and they definitely designed it with serviceability in mind which is awesome. First oil change on the new Taco at 1000 miles in the books!
They almost solved the classic oil filter location getting oil everywhere problem. While I do appreciate the funnel to avoid getting oil on the frame and it does work with higher flow it's just barley close enough to still coat the frame a require some clean up. That being said doing an oil change on this thing is dumb easy and they definitely designed it with serviceability in mind which is awesome. First oil change on the new Taco at 1000 miles in the books!View attachment 422
Describe what I’m seeing in this photo.
