JBAoffroad
- Jan 28, 2025
- Website
- jbaoffroad.com
- YouTube
- Visit YouTube
- Parts Offered
- Upper Control Arms
- 2024 TRD Offroad Tacoma
Hi everyone!
JBA Offroad here. Wanted to quickly share our upper control arm for the new Tacoma.
The STD HC UCA is a high performance arm at a reasonable price point.
If you have any questions, fire away!
- Designed specifically for 2024+ Toyota Tacoma models
- Ideal for trucks running a 1”–3.5” front lift
- Corrects caster and alignment issues caused by lifting
- Built from heavy-duty DOM steel for strength and longevity
- Features JBA’s Max 90 ball joints for increased articulation and travel
- Uses patented EZ Lube bushings for easy maintenance and longer bushing life
- Greaseable design helps reduce squeaks and premature wear
- Bolt-on installation using factory mounting points
- Powder-coated finish for corrosion resistance
- Made in the USA and built for daily driving and off-road use
