- Apr 29, 2025
Top 10 Bed Racks For 2024+ Tacoma
I was digging around for bed rack options for the new Tacoma and figured I’d put this together as a resource to hopefully help everyone else out. A bed rack is one of the most useful upgrades if you’re setting up a truck for camping, hauling gear, or getting into overland trips. They make it easy to run a rooftop tent, carry extra cargo, and mount accessories like lights, shovels, or recovery boards. Some sit mid height for a cleaner look and less drag, while others go full cab height for maximum clearance with bigger tents. The right choice really comes down to how you use your truck and how much gear you plan to load up.Things to Consider
Rack height changes both appearance and function, especially with a rooftop tentAccessory mounting depends on whether the rack is a modular extrusion or fixed panels
Steel racks are heavier but very strong, while aluminum racks save weight but may have less strength
Backwoods Adventure Mods
Backwoods built a rack that focuses on strength and simplicity while still having modular features. It offers unique mounting options and even has a storage box option mounted to the side.
- Modular aluminum channels and side rails
- Compatible with rooftop tents and gear mounts
- Clean fit and finish
Cali Raised LED
Cali Raised put together a balanced design that’s not overly bulky but still brings plenty of mounting points. It’s a good middle ground if you want utility without going all in on size or price.
- Steel construction with powder coat finish
- Multiple mounting slots for lights and gear
Xtrusion Overland
The XTR1 is one of the most modular racks available, thanks to its extrusion system. If you want to rearrange mounts or build a very custom layout, this one offers the most flexibility.
- 80 20 aluminum extrusion system
- Adjustable crossbars and modular slots
- Lightweight but strong build
CBI Offroad
CBI designed their rack at cab height or roof rack height so you can pick depending on your setup. It gives the truck a taller stance while opening up clearance under the crossbars.
- Cab height for RTT clearance
- Rack height for flush mounting with a Prinsu Rack
- Powder coat or bare metal finish
Roof Rack Height: LINK HERE
Westcott Designs
Westcott kept their aggressive styling to balance looks and function. It’s a good option if you want utility but don’t like the full profile of bigger bed racks.
- About 12 inches over the bed rails
- Straightforward bolt-on install
- Works with rooftop tents and bed accessories
Victory 4x4
Victory’s rack is aggressive-looking and built tough. It offers more mounting points than most while keeping a strong steel construction for heavier loads.
- CNC cut steel design
- Powder coat finish with modular add-ons
- Plenty of accessory mounting slots
- Works with Softopper
UpTop
upTOP Overland’s Full-Height TRUSS Bed Rack is built for strength and versatility, making it a solid choice if you’re running heavier gear or a rooftop tent. The design uses interlocking panels so you can adjust it to fit different bed lengths.
- Interlocking side panels adjustable in 1" increments
- Full height design for maximum clearance and load support
- Rated for 400 lb dynamic and 1,200 lb static capacity
Softopper
The EXO rack is built to work with Softopper bed covers, which makes it unique compared to the others. If you’re running a Softopper and still want rack capability, this one is worth a look.
- Compatible with Softopper setups
- Functional mounting without bulk
- Subtle design compared to full racks
Rough Country
Rough Country’s rack is one of the most budget-friendly options on this list. It doesn’t bring the side mount options like some of the other brands, but it covers the basics if you just need RTT or gear mounting.
- Bolt-on steel construction
- Mounting slots for gear and tents
- Simple straightforward design
Go Rhino
Go Rhino offers a rack that combines rugged looks with solid utility. It stands out visually while still being fully capable of carrying tents and accessories.
- Steel uprights with accessory slots
- Works with rooftop tents and cargo mounts
- Aggressive styling and design
Final Thoughts
There’s a wide range of racks here that cover different needs, from low profile daily setups to tall full capacity builds. Some focus on modularity while others keep things simple and strong. Think about the height you want, how much gear you plan to carry, and how you’ll use the truck to decide which setup makes the most sense.
