- Apr 29, 2025
Top 7 Upper Control Arm Options for the 4th Gen Tacoma
Drafting this up because UCAs are one of those upgrades that keep coming up every time someone talks about lifting the new Tacoma. The stock arms work fine at factory height, but once you add a lift, alignment and geometry can go out of spec. Aftermarket UCAs fix that while also adding strength and better joints.Why Upgrade Your Upper Control Arms?
- Correct caster and camber after installing a lift
- Improve suspension travel and ride quality
- Add stronger joints and materials for durability
Dirt King Billet UCAs
High-end CNC billet aluminum arms built for strength and precise alignment correction on lifted Tacomas.
- CNC-machined 6061 billet aluminum
- FK uniballs and heims for strength and articulation
- Corrects geometry for 2–3" lifts
Peak Suspension Tubular UCAs
Tubular chromoly design with sealed ball joints. A solid balance of strength, price, and everyday drivability.
- Chromoly tubing with powder coat finish
- Sealed ball joints, low maintenance
- Improves alignment on lifted trucks
Total Chaos Stock Length UCAs
Well-known in the off-road world, designed for durability and extra travel with aftermarket shocks.
- Boxed steel construction
- Polyurethane bushings
- Compatible with extended travel coilovers
ICON Billet UCAs w/ Delta Joint Pro
Billet aluminum arms paired with ICON’s Delta Joint Pro for articulation and long service life.
- CNC-machined aluminum arms
- Delta Joint Pro combines uniball performance with sealed reliability
- Built for 2–3" lifted Tacomas
JBA High Caster UCAs
Known for their high-caster geometry, making alignment easier on lifted trucks.
- Tubular steel arms
- Ball joint design for easy replacement
- Improves drivability after a lift
Rough Country Forged UCAs
Budget-friendly forged arms that correct geometry and come with maintenance-free joints.
- Forged steel design, stronger than stock
- POM ball joints with full range of motion
- Affordable upgrade for mild lifts
ReadyLift UCAs
Designed for compatibility with ReadyLift’s own lift kits, but also work well on most 2–3" setups.
- Tubular steel with premium ball joints
- Sealed bushings for longevity
- Improves caster and clearance
