DRTFabrication
- Dec 7, 2025
- Gilbert AZ
- Website
- drt-fabrication.com
- 2009 TACOMA
Here is our first 4G tacoma product
We built this bumper to be the go-to high-clearance option for the 4G Tacoma. It’s a hybrid plate + DOM tube design that keeps the weight down while still delivering serious strength, perfect fitment, and max departure angle.
Quick Breakdown:
drt-fabrication.com
Quick Breakdown:
- Hybrid design: DOM + Plate Construction – 1/4" plate structure paired with a 1.75" × .120 DOM main tube and dual 1.5" supports per side.
- Integrated 2x2 Hitch – The hitch is built into a 2" × 2" × 1/4" tube and welded to the 1.75 main tube. chain attachment plates doubling as gussets
- Laminated Recovery Points – 3/8" center plate with 1/4" overlays. Works with ¾" shackles and ⅞" pins. Gussets tied to the 2x2 tube and frame horns span behind the recovery points
- Crossmember Delete – Factory rear crossmember comes out for maximum clearance and departure angle without losing rigidity.
- Sensor-Compatible – Retains the factory BSM sensors x back up sensors
- Lighting Options – rock light mounts on the gusset behind the 2x2 tube and chase light mounts on the 2x2 tube
- Adjustable Plate Mount – Tool-free design lets you move the plate for street or trail.
- Built in the USA – Jig-welded A36 steel for consistent fitment and durability.
Tacoma High Clearance Rear Bumper / 4th Gen / 2024-Current
2024+ Tacoma High Clearance Rear Bumper Maximum Clearance. Hybrid Strength. The DRT Fabrication High Clearance Rear Bumper for the 2024+ Toyota Tacoma is engineered to deliver uncompromising strength and off-road performance in a lightweight hybrid design. Built from a combination of...
drt-fabrication.com
