Fog Lights for 4th Gen Tacoma
Fog Light Buyers Guide for the 4th Gen Tacoma​
I’ve been digging into lighting options for the new Tacoma and figured I’d throw together a guide. The stock lights work, but they don’t really shine (pun intended) if you’re out in bad weather or running trails at night. Fog light upgrades give you better function and style to the front of your rig.
Fog Lights vs Fang Lights​
Fog Lights
  • Wide, low beam pattern built for cutting through fog, snow, rain, or dust
  • Mount in the factory fog pockets
  • Pure function and visibility boost
Fang Lights
Fang light buyers guide here: https://4gtaco.com/threads/fang-lights-for-4th-gen-tacoma.1285/
  • Accent lighting that fills the “fang” slots near the lower grille
  • Usually DRL, sequential turn, or amber/white accent modes
  • More about style, but they complement fogs really well
If you’re choosing one, fogs add the most function. If you want your truck to stand out and be seen, fang lights are the add-on for you.
AlphaRex DoubleTap Dual Color Fog Lights​
Switch between white and amber with a dual projector design.
  • Two colors in one kit
  • Clean projector look
  • Plug-and-play install
Check price online: https://customsunlimited.com/products/24-25-toyota-tacoma-22-25-tundra-sequoia-25-4runner-doubletap-dual-color-led-projector-fog-lights
Heretic LED Fog Kit​
Built tough with a clear lens for max output.
  • Clear beam for everyday use
  • Rugged sealed housing
  • Made specifically for 2024+ Tacoma
Check price online: https://www.hereticstudio.com/products/4th-gen-toyota-tacoma-2024-led-fog-light-kit-clear-lens
Form Lights LED Fog Kit​
A solid option with factory-style fitment and good light spread.
  • OEM-style mounting
  • Bright LED upgrade
  • Plug-and-play wiring
Check price online: https://www.formlights.com/2024-2025-toyota-tacoma-led-fog-lights-pair.html
Cali Raised LED Fog Replacement Kit​
Budget-friendly but a big step up from stock.
  • Drop-in replacements
  • Bright LED output
  • Affordable upgrade
Check price online: https://www.tacomaforce.com/products/fog-light-replacement-kit-for-2024-tacoma
Diode Dynamics SS6 Fog Kit​
High-output pods designed to fit the Tacoma’s new fog locations.
  • Wide fog beam pattern
  • Good optics with cutoff
  • Backed by warranty
Check price online: https://www.tacomaforce.com/products/ss6-led-fog-light-kit-for-2024-toyota-tacoma
RIGID Selective Yellow Fog Kit​
Premium SAE-compliant fog kit with yellow lenses for better performance in poor weather.
  • Direct-fit OEM fog replacement
  • Selective yellow beam reduces glare
  • Durable IP-rated housing
Check price online: https://www.rigidindustries.com/2022-toyota-tundra-selective-yellow-fog-light-kit-37201.html
Final Thoughts​
I think fogs are the first upgrade worth doing, especially if you drive in bad weather or hit the trail at night. They’re one of those simple mods that you actually feel right away: clearer vision in rain, snow, or dust, and a wider spread of light that headlights alone can’t give you.
I second the Cali Raised. Got the amber/yellow as well. For the price and output, you can't beat it! They've been great and I've used them every day for months now with no issues.
Truck Bed Storage Boxes/Platforms for the...
Fang Light Buyers Guide for the 4th Gen Tacoma...
I’ve been thinking about pulling the TRD...
I’m a huge fan of the carbon fiber performance...
I’m a big fan of the carbon fiber look, so I...
Since I’m a huge fan of the carbon fiber...
The mirror covers were one of the first things...
You can never have too much carbon fiber, so I...
The center shift area always felt a little...
